cheap gigabyte elit aorus-do both nvme slots work AND both pcie slots together?
617 (1.24/day)
brother wants me to build him a pc. 5600x and 5700x. internet, watching YT some gaming, mostly midrange not heavy aaa games, some video editing at 1080p.
was looking at the gigabyte b550m auro elite
and wondering if you could use the 2nd nvme slot at the bottom AND use the 2nd pcie slot at the bottom at the same time? I realize it will be slower.
manual if anyone can take a look see.
I didnt see it say you could use both. I know another member mentioned the msi mortar max which i considered and it lets you use only 1 of the slots. either 2nd nvme slot or 2nd pcie
204 (0.12/day)
WorldWideWeb
System Name ROG
Processor i5-11400F
Motherboard ROG Strix Z490-H Gaming
Cooling Be Quiet Pure Rock (BK009)
Memory Kingston Fury RENEGADE KF3600C16D4/16GX (KIT 2x16)
Video Card(s) GTX1060 6Gb AERO ITX OC
Storage NVMe WD Black SN750 ; Samsung EVO 840 SSD and Mechanical TBs...
Display(s) iiyama Black Hawk G-Master GB2745HSU
Case CM HAF-X
Audio Device(s) Yamaha AV Creative DTT2200
Power Supply Corsair RM-1000
Mouse SteelSeries Rival
Keyboard MS Sidewinder X6
Software Windows 10/11
There's nothing in the manual reporting any disable devices/slots.
The PCIe slot will use 3.0x4 from chipset and the M.2 slot will use CPU PCIe 4.0
Unless a user with same mb model and config reports it...
EDIT: Four...? You just mention one disk in bottom slot and another disk in pcie slot with adapter...that's 2 disks.
Shouldn't be an issue on modern mb using the 1rst pcie x16 slot also with an adapter or are you thinking in multiple disk adapters... and no GPU, careful with BIF support.
Ruru
S.T.A.R.S.
13,279 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
I can test that, though I have only x1 add-on cards. I have two NVMe drives on that board currently.
And yeah like said above, the bottom slot is from chipset anyway.
edit: Found an old GPU and seems to work in that slot; my both NVMe drives work as well.
250 (0.18/day)
System Name Silicon Graphics O2
Processor R5000 / 180MHz
Cooling noisy fan
Memory 384 MB
Storage 4 GB
Case the one with the old logo and proud of it ;)
Software IRIX 6.5
Yes, you can use them simultaneously as the block diagram on page 5 of the linked manual indicates.
However, the cumulative bandwidth will always be lower than PCIe Gen3 x4 since that is the link speed of the B550 chipset. Unless you want to capture video via a capture card in the chipset x4 slot onto an NVMe drive in the chipset M.2 slot, you probably won't notice that bandwidth limit.
For both gaming and video editing use, it is common to install the OS on the M.2 drive connected to the chipset and store your game library or video assets on the M.2 drive connected to the CPU.
