Chinese nuclear battery
21,714 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Don't really understand the negativity
I'm all for tech that has a chance of feasibility. But this one really doesn't have any of the hallmarks of that, is the issue.
I would absolutely love to be proven wrong though.
Count von Schwalbe
Nocturnus Moderatus
3,284 (2.78/day)
Knoxville, TN, USA
Betavolt didn't invent anything. They might have improved the semiconductor layers used to collect the beta particles. Might be more practical the way they make it.
Ni-63 is a pure beta emitter, half-life 100 years. A good choice for this type of application - beta decay is not too hard to capture, and that is the entire point of this device. Also, it lasts a while.
The trouble is, it is slightly less than 1 watt per cubic foot, in terms of output. It could hardly be otherwise, with that long of a half-life. Si-32 would be a decent alternative to increase the power output, as each beta particle has about 3x the energy, but it decays to P-32 - which is much more energetic (8x more than Si-32, and a half-life measured in days). I doubt it could be shielded acceptably.
Carbon-14 is about the only other more energetic pure beta emitter than Ni-63, and it has a 5000 year half-life. Not likely to produce an appreciable amount of power.
468 (0.30/day)
Belgium
System Name MSi Coffee Lake
Processor i7-8700k
Motherboard MSI Z370 GAMING PRO CARBON AC
Cooling NZXT something AIO loop
Memory 16GB Kingston HyperX 2133 C14 Fury Black
Video Card(s) TITAN Xp Jedi Order Edition
Storage Samsung 960 Evo NVMe
Display(s) Medion 23'
Case Cooler Master Stryker
Power Supply BeQuiet 600W
Mouse Logitech Trackman T-BB18
Keyboard Generic hp
Sure, let's mass produce billions of these things so everyone can have them.
I would like one for my radiation detector.
23,165 (6.10/day)
Well if it's crowdfunded, i'm sold. Never heard of this before with a workable device. why so negative, this is a good thing.
Fool & Money parted is what they call that
Stop being so naive
Do you really think nobody ever thunk of this?
3,685 (0.85/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
9,661 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
This is nothing new, those deep space probes that are still functioning after decades, that's what they run on.
Anyway, I really do not want to see the words "Chinese" and "nuclear" used together in a sentence, thanks.
1,131 (0.81/day)
Bavaria ⌬ Germany
System Name ✨ Lenovo M75q-1 [Tiny]
Display(s) DELL S2722DGM
Software Windows 11 Pro (Debloated)
I also stumbled over one of those click bait articles. :shadedshu: While the technology is interesting, there is no way this will find it's way into consumer products in the near future.
The battery is f.e. currently used in the Mars Rover Curiosity, but for mobile devices the battery would be simply too big. For 1W the battery would be around the size of a brick, for a 10W smartphone that would make it 10 bricks. Just to get things into perspective. I think the future for mobile devices will be more efficient (display)tech, a solar panel behind the display & a smaller more efficient battery with turbo charging capabilities.
1,475 (0.29/day)
[Formerly] Khartoum, Sudan.
System Name 192.168.1.1~192.168.1.100
Processor AMD Ryzen5 5600G.
Motherboard Gigabyte B550m DS3H.
Cooling AMD Wraith Stealth.
Memory 16GB Crucial DDR4.
Video Card(s) Gigabyte GTX 1080 OC (Underclocked, underpowered).
Storage Samsung 980 NVME 500GB && Assortment of SSDs.
Display(s) ViewSonic VA2406-MH 75Hz
Case Bitfenix Nova Midi
Audio Device(s) On-Board.
Power Supply SeaSonic CORE GM-650.
Mouse Logitech G300s
Keyboard Kingston HyperX Alloy FPS.
VR HMD A pair of OP spectacles.
Software Ubuntu 24.04 LTS.
Benchmark Scores Me no know English. What bench mean? Bench like one sit on?
Imagine a phone that never needs charging, or drones with unlimited flight time, and electric cars with unlimited range.
None of these applications will use nuclear -directly- in the foreseeable future.
Nuclear may be energy efficient, but it's not weight efficient. I couldn't find weight info about this thing (only looked through four articles, tbh), so I guess it's not going to make for stellar power/weight ratio, which is critical for about anything that is A: moves, and B: operates within the (strongest ranges of) Earth's gravitational pull.
Size-wise, lithium CR2032 can give more power output at 70% of the volume. Around ~550 microwatts (well, microVA, to be exact. But at this big a difference, does it matter?) at 787mm^3, compared to 100w@1125mm^3 (man I hope I didn't mess up my units somewhere). Gets worse if you consider instantaneous draw spikes (something I don't think nuclear batteries/generators can do).
Lithium holds (much) less energy, true. But a device that runs for 10 minutes will always trump one that doesn't run at all.
289 (0.34/day)
Processor Ryzen 5 7600X
Motherboard Asus Proart B650
Cooling Noctua U12S
Memory Corsair Vengeance DDR5 32GB (2x16GB) 5600MHz C36 AMD Expo
Video Card(s) Sapphire RX 7800 XT Nitro+
Storage Samsung 990 Pro 1Tb
Case Fractal Design Pop Silent
Audio Device(s) Edifier r1900tII
Power Supply Seasonic Prime Platinum 650W
0.1W may not sound like much but add a few of those ON TOP of a lithium battery and you may never need to charge your phone again on mild to medium usage scenarios.
Imagine a phone that charges 10-50% overnight on its own.
Also won't ever get stuck in a middle of nowhere with a dead phone.
1,475 (0.29/day)
0.0001 watt*
"Few" would be the volumetric equivalent of a cinder block.
I guess there is a market for 80's Motorolla aesthetics...
de.das.dude
Pro Indian Modder
9,173 (1.71/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| J1nnx took Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
the world already has nuclear batteries. its called RTG and they power some the rovers on distant lands.
1,475 (0.29/day)
I prefer my energy cells nuclear and delivered from the rear end...
Count von Schwalbe
Nocturnus Moderatus
3,284 (2.78/day)
Knoxville, TN, USA
Most radiation detectors don't pick this up.
6,111 (1.14/day)
System Name RemixedBeast-NX
Cooling Dell Standard
Memory 24GB ECC
Mouse Logitech G700s/G502
Keyboard Logitech K740
VR HMD Linktr.ee/remixedcat // for my music ♡♡
Software Linux Mint 20
Benchmark Scores Network: APs: Ubiquiti Unifi AP-AC-LR and Lite Router/Sw:Meraki MX64 MS220-8P
great like we need another galaxy note 7 x9001...
2,898 (0.57/day)
You seem to not understand some of the physics here...so let me give you a tour of why this is stupid. Not a little stupid, very stupid.
First off, this is not novel or new. There are horror stories of old soviet era equipment breaking down with thermal nuclear batteries. It's RTG...and it's great if you want a constant source of power and heat as long as your power draw is minimal and you can choose a blend of radioactive isotopes that you can wrap in sufficiently dense material to absorb the daughter particles from the radioactive decay inside the unit. This is how it's "safe..." but there are some pretty gnarly stories of what these safe long life batteries do in the wild.
Wikipedia on RTG
Summary and youtube video link on Soviet shenanigans
Now let me explain the technical side here...you have capacity, size, or duration. It's a triangle. The isotope blend that gives you more output requires either a larger size, or a shorter duration. This is how things like light houses were powered for years...by a reactor the size of a car that ran a lightbulb. If you want a lifetime pacemaker battery you need to either have a very small output, or a much larger battery. The article you linked to doesn't actually disagree with this...they just indicate Elon Musk levels of BS selling snake oil science.
Let me also suggest that this is not safe...it's a matter of relative danger. If you want to understand check out videos on youtube by Plainly Difficult... The gist of this is that radioactive stuff is very safe until anything vents...and the second you lose shielding you get lots of dead people.
I'm also going to call shenanigans on a lot of stupidity here...that people often miss. A nuclear battery cannot ramp up, it's always going down. I'm sure a lot of people have had an electronic device that absolutely chewed through battery capacity, because it's potential. That is the potential difference between the two poles can be pulled out quickly or slowly....but nuclear batteries do not. Imagine if your cell phone was stuck in the 90s...when they had a brick of battery and managed a few hours of life...which is because they ran full tilt at all times. Bleh. This is also why we don't have magic tech like thorium powered cars (another nuclear decay battery), which is because nobody in their right mind would have a car that has to output energy constantly whether at 100 Mph or at 0...meaning that you would basically require your nuclear battery to either output enormous heat when idle.
-Edit-
Maybe a slightly less mewling repeat article that is Chinese propaganda would be in order:
Tom's Hardware article
It's actually showing diamond sheets converting the decay of Nickel into Copper via stacked sheets. Holy crap, that's using a conductive crystal lattice with introduced beta decay to generate your power. That would theoretically be great....but then you're looking at something that isn't commercially viable. Why not? Well that's different tech that hasn't been made feasible in almost a decade. Proof, maybe this 2016 article:
2016 Magic carbon battery tech...
So...without proof what I'm seeing is a lattice that would generate energy in two ways. Thermal variation generates piezo effects and some beta decay might generate some power...that you need the carbon lattice to convert and would slowly be turned to an unstable isotope that itself would decay into Nitrogen over time.
So...yeah. I went down the rabbit hole, and what I see is not a new beta decay model. What I see is people assuming that despite the last 7 years not providing that as viable and the power output being much closer to an RTG than the theoretical beta decay...which based on a much older article would last thousands of years instead of 20.
The "we can withstand any temperature, and tolerate output variation" is also a dead give-away in my book. Radioactive decay cannot be currently modelled...so being able to generate variable output is often made possible by using the generating thermocouple as a storage medium of sorts. That's great for an RTG...but a true beta decay based battery has no buffer. If you get 100 decays in 60 seconds, then 1000 in the next 60 seconds, then you have nothing to do but deliver unclean power. In a thermocouple you meter that by the energy produced being a function of the delta between hot and cold...so variation in thermocouple end temperatures offers the variability. Beta decay...doesn't have that feature....unless they mean dozens of layers will always average out to a known range...but it's not like that's a practical way to meter conversion.
-Edit end-
Let me top this off with one final note. This is a dumb proposition by a start-up that will die in less than a year...if they make it that long. Hopefully people can finally understand it...but I'll explain this simply. I don't power my blender with a V10 engine, my phone doesn't have a bio-reactor, and my electronics that matter are powered by a stable chemical reaction. None of this is because "I don't want a brighter future." All of it is because of the same logic that sees me not spreading napalm on my lawn to both shorten and dispose of grass clippings. You don't use the wrong tool for the job, and RTG is not the right tech for ultra small batteries.
Let me also introduce you to a simple calculation. e=mC^2. Note that a nuclear battery, which is not 100% converting mass into energy, has to derive that from somewhere. Imagine that 5 Watts, which is 5 Joules per second, over 50 years. 50 years * 31,536,000 seconds/year * 10 Joules/second * 1/0.1 (assuming a 10% conversion of mass from mother particle to daughter particles during decay) * 1/0.5 (assuming a 50% efficiency in converting the energy into usable electrical energy based on a very generous interpretation of RTG) and suddenly that small battery being capable of every powering a modern phone for 50 years requires that you stick a laptop battery level weight to the thing...and if I do that I'm already capable of not needing to recharge my phone but once a month even with the propensity for the phone to vary wildly in energy consumption to provide the best performance and battery life depending on the situation. In three words, "I call shenanigans."
_________________________
As a reference;
1) Hyperloop is not Elon Musk's idea...it was dreamt up and tried ages ago. Heck, Jules Verne referred to a vacuum train.
2) Hyperloop as of the date of this post is officially dead...so Musk has proven "it is really simple" isn't really true.
3) Speaking of dead, and poor taste in words, how's that automatic driving going? Hmmm.... That bad. Oooh. That is...discouraging.
4) The US knew where to stick RTG. Both the US and Soviets used these generators in long term space missions. This is why today we are still getting data from probes.
5) Seriously...RTG is insanely freaking dangerous. The second the outer shell decays at all you go from "no radiation" to liquified internal organs. I support nuclear power, and these things scare the crap out of me such that proposing I stick one in a pacemaker inside of me is a stupid risk. Why in hades do you think that this is safe because somebody told you so...when even a small amount of research proves they lied about the origin of the idea, the author did a terrible job highlighting the obvious trade-off between output-size-lifetime, and the available stories on RTG are the stuff of pure nightmare fuel? People fear spent reactor water, that can be distributed into the ocean at levels which don't exceed background, why in Hade wouldn't they fear a very literal item that if they failed like the cheap lithium batteries we have now would quite literally cause a national disaster requiring superfund dollars (if you're in the US) to clean?
468 (0.30/day)
Belgium
Processor i7-8700k
Keyboard Generic hp
Count von Schwalbe
Nocturnus Moderatus
3,284 (2.78/day)
Knoxville, TN, USA
I hope my radiacode 102 will pick up radiation from any accidental source.
Probably - the source I was looking at said "wipe" scintillation was the only way to pick up Ni-63. The Radiacode appears to use the scintillation process, but I am not sure exactly how it all works.
G-M detectors won't pick it up.
2,192 (1.04/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Software Windows 10 Pro X64
Benchmark Scores Who cares
Nickel-63 only emits low energy beta, so is it really that dangerous?
Betas/electrons:
0.1 mm of plastic will absorb all emissions.
If the battery is using NI-63 is seems to pose a really low level threat.
470 (0.10/day)
Quodam loco Albanianae
System Name The Dark side of the room
Processor AMD Ryzen 9 5900X
Motherboard MSI MEG X570 Unify
Cooling Custom loop watercooling (Bykski CPU-XPR-POM-M-V2, Alphacool Eisblock GPX, Freezemod PU-PWM5B18W)
Memory GSkill Ripjaws V DDR4 3600 CL16 (4 x 16GB)
Video Card(s) XFX Speedster QICK 319 Radeon RX 6700 XT
Storage 1 x Kingston KC3000 1024GB (boot drive) + 2 x Kingston NV2 2TB (games & storage)
Display(s) LG 34WP65C Ultrawide 3440x1440 @ 160Hz freesync premium
Case Thermaltake Core P90 TG (slightly modded)
Audio Device(s) onboard Realtek® ALC1220 with Logitech Z906
Power Supply MSI MAG A850GF 80 Plus Gold
Mouse Generic
Keyboard Sharkoon Skiller SGK60 (with brown Kalih switches)
Software Windows 11 pro
Benchmark Scores It's a form of exhibitionism...;-), but fun in a way But showing off is triggering.............
I don't know much of nuclear power so making any comments about this subject would be pure speculation.
However I do remember the debacle with the Samsung Galaxy Note 7 batteries, imagine if these nuclear batteries are in a smartphone and catch fire.... :eek:
The concept of 'melt-down' would get a whole new perspective...:roll:
2,550 (1.58/day)
Bulgaria
While interesting with a battery that could last 50 years and that would be great if it could lets say powering a car or more stuff like a smartphone.
However i am not that knowledge of this. But nuclear and a battery you have close to yourself. I think radiation exposure and radiation sickness. So do i really want this thing in my smartphone or car. I am not so sure i want to, even if the radiation levels are harmless also over longer periods of time. Just the thoughts of a nuclear thing close to my body, makes think no apselutely not.
You are all made of atoms and they have nuclei.
21,714 (3.40/day)
Olympia, WA
System Name Pioneer
why would they catch fire with no Li-Ion energy source? It's not like Nickel really burns...
Anyways no one with understanding is seriously concerned about the radiation from this thing (if it isn't breached anyways). It's more about the anemic output potential.
470 (0.10/day)
Mouse Generic
Please relax o_O,
it was just an attemp to throw in some humor with words to this serious thread where opinions seem to collide based on several reactions giving a level of decay to the core essence of this subject. .
If this battery isn't heating up, some of the discussions are for sure ;).
21,714 (3.40/day)
Olympia, WA
System Name Pioneer
Please relax o_O,
No worries. I wasn't angry just trying to explain the small bits I do understand.
