Close call... 5090 Burnt Cable
3,310 (0.55/day)
System Name Panda? Storm Trooper?
Processor Intel 285K Overclocked
Motherboard ASUS STRIX Z890-A GAMING WIFI
Cooling AC Core 1 CPU Block | Heatkiller Radiators 2x 360-45mm 1x 240-30mm |AC Core 120mm Reservoir
Memory 48GB 8400MHz Corsair Vengeance DDR5 CUDIMM CL40 -
Video Card(s) RTX 5090 32GB Palit Gamerock w/ Alpha Core Waterblock
Storage 4TB WD Black NVME Gen 4 + 14TB WD HDD
Display(s) ASUS PG32UDCP 32" QD-OLED 240hz/480hz
Case HYTE Y70 Panda + ColdZero AF Front Panel
Audio Device(s) 2i2 Scarlett Solo + Schiit Magni 3 AMP
Power Supply ASUS Thor III Platinum 1200w
Keyboard NEO75CU White + PBTFans Neon R2 Glitter + BSUN Macaron Switches
You wouldn't think it would happen to you until it does... I was reading about 12VHPWR volts on HWINFO and people were saying that you should worry if it's around 11.5 or below at full 600W Load... WHICH my card was using this EZDIY Fab connector... and at idle it was at 11.913.... So I checked my connections and the cable was VERY hard to remove, once I got it out I found the below.. the PSU cables and connector on the card itself is fine but this connector almost got fried.
Anyway moving on, I decided to then plug in the corsair 12v6x2 cable my PSU came with.. now its idling at 12.045 and Load 11.802-11.731 original was 11.9/11.5 MASSIVE Difference!
Becareful out there everyone aesthetics just isn't something to play with on this card unfortunately.
Solaris17
Super Dainty Moderator
27,522 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Its a good warning and lesson. You are braver than I. I told myself when the 4xxx series launched I will never use the pretty or 3rd party cables.
64 (0.84/day)
System Name Bargain System
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550 Gaming Plus
Cooling Deepcool LT720 360mm
Memory 32GB Corsair Dominator Platinum DDR4 3600Mhz
Video Card(s) AX Gaming RTX 5070 Ti | Sapphire RX 9070 XT Nitro+
Storage Western Digital SN850X
Display(s) Acer Nitro 34" Ultrawide | Samsung Odyssey G5 27"
Case Lianli O11 Dynamic Evo White
Audio Device(s) HiVi Swans OS-10 Bookshelf Speakers
Power Supply Seasonic Prime GX-1000 80+ Gold
Mouse Razer Ultimate | Razer Naga Pro
Keyboard Razer Huntsman Tournament Edition
I am using this 12VHPWR cable from Seasonic on my Prime 1000w power supply. It might not be pretty but it is cheap and made by the manufacturer of the power supply, I am betting that Seasonic know what they are doing. :)
If it is up to me I would advise people to stay away from third party adaptors, they might look pretty and neat for tidy cable management but it is not worth the risk.
3,563 (1.12/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
It doesn't really matter whether it's an official cable or not, the Nvidia reddit has reports of both equally burning up with the 5090.
It's all fun and games until Nvidia denies your $2,500 card's warranty for user error or it happens just outside of warranty.
The connector is just trash.
147 (0.06/day)
lol you are literally one 5090 in the wild and got melted. WTF
it's not about cable. It's about that garbage is 400W standard, not 600.
Only way to run 5090 is power limit to 400W TDP
3,310 (0.55/day)
Further more.. my card is now able to pass timespy at 3100mhz+ core clocks... it wasnt able to do 113+ on afterburner before now it does 220+
AND the coil whine is almost completely gone with the ezdiyfab cable the coil whine was super loud!
3,310 (0.55/day)
3,569 (1.73/day)
Power Supply Corsair RM750x
Mouse Logitech M575
So now the big questions...
  1. Did you attempt to clean the GPU part of the connector afterwards before using the new cable? (with some kind of contact cleaner)
  2. If not cleaned aren't you still concerned that even with a new cable attached you might have unbalanced load between the pins because of debris or impurities on the surfaces of the GPU power pins that may increase contact resistance?
11,080 (1.75/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
I had the same issue with stock cables and the 4090 dongle - same issue except at the dongle and not at the card -- cable melted and melted a PSU power port. There doesn't seem to be any reliable way of fully avoiding the issues - I don't buy the whole "it's third party cables" bs. Derbauer recreated it as well and anything that pulls under 450W doesn't seem to have any issues at all.
Solaris17
27,522 (3.84/day)
Alabama
VR HMD Quest 3
6,358 (2.86/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
3,310 (0.55/day)
Yeah dont I doubt it either ive already got a undervolt profile which pulls below 450w that ill be sticking to for 24/7 use even then still concerned.
14,486 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Is this after you installed the water block?
I was just wondering if running cooler allowed it to draw more power?
3,310 (0.55/day)
With the way its behaving.. and me seeing new heights in 3dmark this is totally new behaviour from since day 1.
There were bits of white plastic on the walls of the most burnt connector but the pins and housing were visibly fine. My biggest telling sign is the massive improvment in 12pin voltages and general stability. But will be undervolting the card for the rest of its life for 24/7 use moving forward and will wait for a card thst doesnt use 12vhpwr in future lol
with FLIR. I would watch livestream of it
I bet youre the type to laugh at your own friends misfortunes
81 (0.01/day)
France
System Name Sillencio
Processor AMD Ryzen 7600
Motherboard Asrock B650M Lightning
Cooling Thermalright Phantom Spirit ARGB
Memory G.Skill FLARE 5200MHZ EXpo
Video Card(s) Sapphire RX 7600 Pulse
Storage WD NVME 1TB
Display(s) AOC 27" LED - e2752Vq
Case Coolermaster Silencio 652S
Power Supply EVGA 750GT GOLD
Mouse ADVANCE 210
Software Windows 11 64
14 (0.00/day)
The Burgh
System Name Daily Driver
Processor Ryzen 7 7800X3D
Motherboard Gigabyte B650 Aorus Elite AX V2
Memory G.Skill TridentZ 32 GB @ 6000MHz
Video Card(s) Gigabyte RX 6800 XT Gaming OC
Storage Samsung 850 EVO 500 GB, Samsung 990 Pro 1 TB
Display(s) LG Ultragear 3440x1440 144 Hz
Case Corsair Carbide Air 540
Audio Device(s) Logitech Pro X
Power Supply EVGA SuperNova P2 850w 80+ Platinum
Mouse Razer Viper V3 Pro
Keyboard Wooting 80 HE Zinc Alloy Black
Does Nvidia provide their own 12v6x2 cable with the 5090?
3,310 (0.55/day)
452 (0.57/day)
On my 5080 I needed 90 degrees cable as well, thankfully I have be quiet PSU and they sell that cable for their PSUs:
Not very pretty but so far no problems and I saw that 5080 can also burn.
Glad that your GPU still works!
I know that every cable can burn basically but well in case of warranty they cannot claim that I used wrong cable
3,310 (0.55/day)
Yeah cant find a corsair one but will stick to the og psu cable for now since its droop is only around 300 whereas the third party one was 600 mv droop lol
