It does specify the HDMI ports are 2.0 only - it's like many modern displays where they don't use many optional display port features so they're vague on what version it is
DP 1.4 on one of my displays only supports DP 1.2 bandwidth because the monitor doesnt support either compression method
DP standards have a lot of optional features, so DP 1.2, 1.3 and 1.4 can all have the exact same bandwidth - just with optional features like compression or HDR
While i'm covering some of the details below i'm not defending CM - i also agree they need to state these things more clearly
As to why i asked about the monitor used, the manual on the website is quite clear that HDMI can't do the high refresh rates - it's extremely detailed about the required pixel clock rates and bandwidths for each mode, and what ports support them
That 776MHz pixel clock shows it's DP 1.4, or at least using the DPC compression because DP 1.2 cant pass 600
