- Mar 6, 2009
- 5,976 (1.05/day)
- Cybertron aka Canada
Processor | Intel Core i5-3570K |
Motherboard | Asus P8Z77-V Pro |
Cooling | Noctua NH-D14 |
Memory | 8GB Mushkin Blackline DDR3-1600 |
Video Card(s) | Gigabyte GTX 670 |
Storage | Intel 520 60GB, Seagate Barracuda XT 2TB |
Display(s) | BenQ 24" XL2420T |
Case | Corsair 550D |
Audio Device(s) | Sennheiser HD600, Audeze LCD-3F, Mytek Stereo 192 DSD, La Figaro 339, Burson HA-160, Geek Pulse X |
Power Supply | Corsair AX650 |
Mouse | steelseries Sensei MLG edition |
Keyboard | Cooler Master QuickFire Pro |
Software | Windows 7 64-bit Home Premium |
not really, the perforated expansion slots (they really do shed degrees off your video card) are designed to let video card and power supply heat that radiates up to get forced out from the front intake, this isn't possible with the HAF series unless you have a lot of positive pressure or pop the rivets out of the hard drive rack with a drill and re-seat it 90' so it faces forward the 200 and 230mm fans have almost zero static pressure if you put your hand at the back of the hard drive rack you won't feel any air but even if you replace it with a quality 120mm it will still be restrictive because the perforated holes in the hard drive rack are actually above where a hard drive bracket gets mounted so no real air touches the hard drive even so the air from the front intake has to pass through a sheet of metal, plastic, hard drive, another piece of plastic and another sheet of metal.
one of my theories as to why Cooler Master puts hard drive racks on the side is because once you pull the bracket out your looking at the length of the rack plus the length of the bracket this would obviously create clearance issues swapping them out if your system is fully assembled (ie video card)
