Cooler Master Mobius 120 Fan
1,237 (0.28/day)
California, unfortunately.
System Name Sierra
Processor Core i5-11600K
Motherboard Asus Prime B560M-A AC
Cooling CM 212 Black RGB Edition
Memory 64GB (2x 32GB) DDR4-3600
Video Card(s) MSI GeForce RTX 3080 10GB
Storage 4TB Samsung 990 Pro with Heatsink NVMe SSD
Display(s) 2x Dell S2721QS 4K 60Hz
Case Asus Prime AP201
Power Supply Thermaltake GF1 850W
729 (0.34/day)
Moscow, Russia
Processor Intel 12600K
Video Card(s) Palit RTX 4080
Display(s) Dell S2721qs
Case Phanteks P300A Mesh
Mouse Glorious Model D-
30 bucks and you can't even flex with noctua brown on the plebs.
486 (0.56/day)
System Name The Phantom in the Black Tower
Processor AMD Ryzen 7 5800X3D
Motherboard ASRock X570 Pro4 AM4
Cooling AMD Wraith Prism, 5 x Cooler Master Sickleflow 120mm
Memory 64GB Team Vulcan DDR4-3600 CL18 (4×16GB)
Video Card(s) ASRock Radeon RX 7900 XTX Phantom Gaming OC 24GB
Storage WDS500G3X0E (OS), WDS100T2B0C, TM8FP6002T0C101 (x2) and ~40TB of total HDD space
Display(s) Haier 55E5500U 55" 2160p60Hz
Case Ultra U12-40670 Super Tower
Audio Device(s) Logitech Z200
Power Supply EVGA 1000 G2 Supernova 1kW 80+Gold-Certified
Mouse Logitech MK320
Keyboard Logitech MK320
VR HMD None
Software Windows 10 Professional
Benchmark Scores Fire Strike Ultra: 19484 Time Spy Extreme: 11006 Port Royal: 16545 SuperPosition 4K Optimised: 23439
The description of a "Loop Dynamic Bearing" as a sealed bearing with oil inside is the same description of 99% of the non-magnetic bearings that have been used in cheap fans for decades already so that's just marketing BS-speak.
So this is a Mobius 120mm:
Specifications from Cooler Master:
Flow: 63.1 CFM
Max RPM: 0-2050
Bearing: Loop Dynamic (whatever that means)
Max Loudness: 22.6dBA
Price: US$33 at newegg
and this is a Sickleflow 120mm:
Flow: 62 CFM
Max RPM: 650-1800
Bearing Type: Rifle
Max Loudness: 27dBA
Price: US$10 at newegg
The Mobius fan seems like a bit of a rip-off, eh? Sickleflow has a stellar reputation for a reason so I have a hard time believing that the Mobius fan is worth it. Its max loudness is a good deal less than the Sickleflow but that 0RPM state would be a lot more bothersome than one might think. It's a lot more jarring to go from silent to not silent and that would be more noticeable than if the fan's idle is 650RPM, regardless of the dBA level. This is because a fan that idles at 650RPM forces your brain to ignore it as background noise and become accustomed to it. A spinning fan ramping up would be less noticeable than a fan being off and then turning on, especially if you're sensitive to noise (which I'm not but many seem to be).
Yeah, I'd give the Mobius fan a hard pass. Cooler Master already has a great solution that makes more sense and that's before talking about solutions from Arctic, Noctua and Thermaltake.
Premium price for a premium product.
Cooler Master Sickleflow is also a premium product for 1/3 the price.
VSG
Editor, Reviews & News
3,725 (0.94/day)
I mean, there's a reason why I didn't talk a lot about the bearing. The product page is hilarious with animations that probably cost more to make than to come up with the fan design.
486 (0.56/day)
VR HMD None
But it's not brand new!
Well, that's true. We all know that everything new is better, eh? Especially if it costs WAY more! :laugh:
I get the feeling that it's the same bearing as in the Sickleflow but they changed the wording to make it sound like technomagic.
Just ask this guy:
"Tell me Captain Sheridan, do you believe in magic? You know, like 'Loop-Dynamic Bearings' and 'Ring Blades'?"
- Technomage Elric, Babylon 5
2,671 (0.94/day)
Just ask this guy:
They do not have a name as you understand the concept. They are called the Fan. The Fan of God. The Fan of death. The Fan that reaches forth and cools your PC... They are cooling, they are cooling! :rockout:
9,217 (4.08/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
There is a reason why I stay with Artic fans. After all of these years you can only do so much in terms of blade builds and speeds to achieve the CFM's in a fan.
Artic fans;
Not great, but good enough and dirt-cheap.
Eddie58
18 (0.02/day)
My Arctic P12 fans had a horrible hum/whine on most of the RPM range except for very low and very high values. Replaced them with some cheap Thermalright TL-C12-C fans which don't have a hum and perform slightly better than the Arctics.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
I'll never understand anyone who thinks this
I have zero RPM modes on all my GPUs and most of my PSU's and not once - not ONCE - has that transition EVER been audible.
You'd be nuts to get something like this and have a fan curve that tells the fan to go from silent to 2000RPM without inbetween steps
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
I just realized with agressive CPU boost algos and high TDP.
We have a real turbo lag in our PCs now too. We have to wait till the fan spins up to keep the CPU cool for higher turbo.
Just lol...
1,861 (0.53/day)
North Dakota
System Name Office
Processor Core i7 10700K
Motherboard Gigabyte Z590 Aourus Ultra
Video Card(s) Intel ARC A750
Display(s) Dell S2719DGF
Case Fractal Define 7 Compact
Power Supply EVGA 550 G3
Mouse Logitech M705 Marthon
Keyboard Logitech G410
Software Windows 10 Pro 22H2
The fans on my 3050 grunt/rattle on startup, so it can potentially be an issue. But they're functionally inaudible at 700 RPM, so easily enough solved.
486 (0.56/day)
VR HMD None
Rock on brother! :peace:
Well, I know that it's more noticeable to me and I honestly don't care about fan noise. When I'm gaming, I hear the game, not the fans.
It depends on what you're doing I suppose. If you're gaming, it's probably because you hear the game. For me, I could have six case fans going and after a minute or two, I won't notice any of them. They just blend into the background. Everyone's made differently I guess.
You'd be nuts to think that I had that in mind.
9,217 (4.08/day)
Case Veddha T2
Mouse MX Anywhere 2
Anecdotally, I've dealt with enough GPUs to say that a sizeable minority of them with 0-rpm modes do have audible startup spinout. Several different Zotac and Palit cards seem to do it when new by design (or bad fan-control). The oldest cards I have in large numbers are Gigabyte RX570 cards and most of those now also grunt when they spin up/down and that's likely age. I sell them on ebay to keep them out of landfill so I've already tested about a dozen since the year started.
It is still a minority though, and I've been taking whatever sensibly-priced GPUs I can source since early 2020 so I've dealt with far more different SKUs than I'd like to under normal circumstances.
Mussels
58,412 (7.78/day)
Oystralia
If thats gigabyte, you can blame their terrible QA for that - lotta reports about the fan blades warping/stretching at higher speeds and grinding into the fan frames on the start/stop
1,861 (0.53/day)
North Dakota
System Name Office
EVGA, actually. I was somewhat surprised.
Mussels
58,412 (7.78/day)
Oystralia
I had two EVGA 970's i had to resell due to insane coil whine, they weren't always perfect
bad fans are bad fans, and shouldnt be blamed on zero-RPM - hell enough people use compressed air cans, over-rev the shit out of the fans and break the bearings and then blame anything but themselves when they click and grind and take forever to settle back into position each boot
1,259 (0.21/day)
I wouldn't be. Apart from some of their higher end SKUs like the Kingpin, Classified, or some FTW stuff, the component choice on most of EVGA's cards never screamed "high quality" to me. It's mostly average, or during the Geforce 8-Geforce 200 days downright bad for some SKUs.
e.g. This terrible 9600GSO
or this awful GTS 250
1,861 (0.53/day)
North Dakota
System Name Office
Yeah, pobody nerfect, though I'd had several to this point, and the 3050 was the first one to have something obviously wrong with it out-of-the-box. Getting OT, though.
486 (0.56/day)
VR HMD None
What made EVGA legendary wasn't necessarily their quality, especially not in the early days with GeForce-8 or the 9000-series but their incredible level of customer service. If you had a problem, EVGA would fix it, and FAST! They even had a thing where you could trade your card in for a new one and that went on for years. This assurance made a lot of customers buy their cards which made EVGA extremely rich.
As a result, EVGA had the budget to make their later cards innovative and of high quality. It used to be said that "EVGA is to GeForce what Sapphire is to Radeon".
30,507 (7.07/day)
I disagree on both points. Quality has been excellent since about 2004.
VSG
3,725 (0.94/day)
Keep the discussion on the topic please, this is the reviews comment section.
