Cooler Master X Silent Edge Platinum 850 W
988 (4.53/day)
My use case for zero psu noise is a quiet room.
It's not a car where I enjoy the vibration, sound noise and other noises.
54 (0.06/day)
I have had a passive Seasonic for many years. Might get a new one soon, and always good to see more alternatives. I like zero noise and knowing there is no movable part (the fan) that can break.
399 (0.51/day)
If you want a silent PSU you're (imo) just better off getting a very premium power supply with proper fancontrol. Get something A++ Cybenetics rated and preferable something overkill or, even better, check the profile as reviewed by Cybenetics and base it off that.
One good example is the Cooler Master X Silent Max Platinum 1300, https://www.cybenetics.com/evaluations/psus/2493/.
This thing is silent until you pull 1150W or so and will handle anything you throw at it for about the same price.
5,356 (3.70/day)
Colorado, U.S.A.
Software Windows 11 Home
166 (0.09/day)
The price difference between the 850 and the 1100w is 50€.
399 (0.51/day)
I doubt it run silent till 1150W unless taking advantage of the computer case fan.
I mean it states this has been tested at an ambient temperature of 30-32°C but not for how long.
30°C is very high for an ambient temperature considering 20°C is more realistic.
But they say nothing about for how long so... question mark?
5,356 (3.70/day)
Colorado, U.S.A.
As jonneyGURU said
"Whereas, Zero RPM fan mode will wait until there is so much heat to dissipate, the fan kicks on at 400W and the air coming out of the back can be used to melt heatshrink tubing."
4,872 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
30c is normal for a chamber, when I ran two walk in chambers they stayed at 30c simply from the lights (pre-LED) even with the door wide open
via cybenetics
We measure the fan's noise from one meter away, inside a hemi-anechoic chamber whose internals are entirely covered in specialized soundproofing material. Background noise inside the chamber is kept below 6 dB(A) during testing, with humidity being close to 50%. We should stress however that to obtain the fan speed results we apply the same conditions with our efficiency readings (operating temperature >30 °C) and we take the fan's output speed throughout the PSU's entire operating range. This allows us to calculate the unit's overall noise output and provide the corresponding Lambda certification.
13 (0.00/day)
I have bought this PSU in the EU (1100W) variant. Yes, it is ultra niche and also overly expensive. It is a dumb buy. It is also completely inhouse designed and manufactured in Taiwan, a cooperation effort of CoolerMaster and Infineon.
Feeds Core 9 Ultra 285K, RTX 5090 (on the way, there is a substitute inside currently), 21 fans at ultra low RPMs, two D5s and an array of five Optane 905P drives. The machine is inaudible during the usual work and gaming and extremely silent during ultra heavy loads. I have developed a strong hatred for PSUs that do this "swoosh" sound every time a fan spins up. This is what I was looking for.
Very happy with the result, would buy again.
P.S.: My friend has this SeaSonic Fanless 520W PSU that he owns from maybe 2013-14. Thing has endured 10+ years of everyday service under multiple configurations, currently on the most recent build with Ryzen 7 9700X + RTX 4070Ti Super. I would like to stick to my CM in a similar way, given the standards or connectors will not change.
4,872 (0.97/day)
434 (0.10/day)
it's a really cool piece of tech, but in most cases having a decent fan that's not too loud is just better.
7 (0.29/day)
Processor Ryzen 7 9800X3D
Motherboard MSI MAG X870 Tomahawk WIFI
Cooling Custom watercooling loop with Watercool MO-RA3 420
Memory 96GB DDR5-6000
Video Card(s) Zotac RTX 4090 AIRO
Storage Micron 7400 PRO 3.84TB + KIOXIA CD6-R 7.68TB + Micron 9200 ECO 11TB
Display(s) Dell UltraSharp U4025QW
Case Fractal Design Vector RS
Audio Device(s) Canton CT 800, beyerdynamic DT 990 Pro, Audio Technica AT3035
Power Supply Cooler Master X Silent Edge Platinum 1100
Mouse pwnage Stormbreaker
Keyboard Ducky One 3 SF, MX SILENT RED
I've actually bought the 1100W unit.
I had the Seasonic 600W fanless before and I've been waiting for a passively cooled ATX 3.x PSU to replace it so I'm not at razor's edge with my 4090. The 700W fanless wasn't a worthwhile upgrade in that situation.
I see two usecases for a PSU like this:
1) Enthusiasts like me who have a custom watercooling loop that allows for a dead silent system at any load (yes, I managed to silence the pump)
2) Hardware reviewers who do noise measurements in an anechoic chamber. Being certain that there is no PSU fan that could possibly kick on is useful in that scenario
Yes, it's ultra niche. Which is part of why it's so darn expensive, because there's no production at scale. I think that's perfectly fine, though - I'm just glad that it exists at all.
I expect that there's significant overlap between people who buy this and people who buy the MoRa IV 600 (though I'm sticking to my MoRa 3 420... for now...)
cooler master X silent Max platinum 1300w is $100 cheaper on amazon, it's the same platform they just removed the fan and called it passive
Not quite. They also replaced some of the heat sinks with larger versions that'd collide with the fan on the 1300W.
It's a small change, but it's there.
