CPU Burn-in
JrRacinFan
Served 5k and counting ...
20,095 (3.16/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
Is this still a "thing" that should be done? If yes, is Prime95 still the preferred method?
Is it now more less personal preference?
PS: I don't feel like going through the process. Excited for my upcoming stuff.
4,815 (3.86/day)
Colorado, U.S.A.
Power Supply EVGA 500W1
Software Windows 11 Home
Was it ever a thing?
JrRacinFan
20,095 (3.16/day)
Youngstown, OH
Storage 20+ TB
tabascosauz
7,972 (2.38/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
If you mean as a stress test to make sure nothing is unstable, sure. If you mean that the CPU only performs optimally after stress testing, then no, it hasn't been a thing in forever, if it even was ever a thing for modern CPUs.
Prime95 doesn't do much on Ryzen for stability, boost clocks always are scaled to the nature of the load applied. Recent generations of Ryzen will either clock significantly lower in P95's core-heavy tests by default (thus making P95 useless), or only be stable at lower clocks in P95 when OC'd compared to other tests/applications (also rendering P95 useless)
4,815 (3.86/day)
Colorado, U.S.A.
True, as a stability test it is a good thing.
Deleted member 185158
Yes, artic silver 5 requires 200 hours of "burn in" time.
Cooler settling and pushout also takes time depending on thermal paste consistency.
JrRacinFan
20,095 (3.16/day)
Youngstown, OH
Storage 20+ TB
9,340 (5.68/day)
Louisiana
Keyboard G710+x3
Only if you want to use a power virus to see how bad your cooling is
Otherwise you can just as well use blender opendata and at least be a little entertained by the rendering images :laugh:
Blender Open Data — blender.org
JrRacinFan
20,095 (3.16/day)
Youngstown, OH
Storage 20+ TB
9,340 (5.68/day)
Louisiana
Keyboard G710+x3
I've never crash gaming after using opendata = no joke :cool:
By the way you can switch it to testing gpu it default is cpu.
freeagent
8,066 (3.73/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Like that old program called cpu burn or whatever or whatever it was called?Nah I don’t think so. I’m not sure if it was ever really a thing or if it was in the imagination.
9,340 (5.68/day)
Louisiana
Keyboard G710+x3
I'll give credit to P95 though they killed silicon lottery :laugh:
Toothless
Tech, Games, and TPU!
9,470 (2.49/day)
Washington, USA
System Name Veral
Processor 5950x
Motherboard Asus Crosshair VIII Hero Wi-Fi
Memory 2x16GB G.Skill TridentZ
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Intel burn test?
JrRacinFan
20,095 (3.16/day)
Youngstown, OH
Storage 20+ TB
I blame both major players in CPU manufacturing, with pretty much locking down overclocking
freeagent
8,066 (3.73/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Intel burn test?
Nope there was a program called cpu burn or burn cpu or something like that. Reaching back to the early 2000s now
9,340 (5.68/day)
Louisiana
Keyboard G710+x3
Yeah I only remember intel burn test.
I never ran it personally.
freeagent
8,066 (3.73/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
It had a little flame on a cpu on the .exe I think :D
I tried it, but I think even Orthos got warmer.. its been awhile :D
2,672 (0.68/day)
Alabama
Processor Ryzen 2700X
Cooling Scythe Big Shuriken 3
Memory C.R.S.
Video Card(s) Radeon VII
Software Win 7
Burn in when the chip is new is really only to test the chip when it's received for seeing if it's defective, runs hot and so on.
Aside from that there is no actual benefit from just doing it.
You could do some stress testing that will reveal any problems with tweaks for example, that will let you know what it likes and doesn't like in those terms.
Just don't try it like I did one (FX-8350) straight from the package brandnew - Stuffed it in, slapped the pot on top, poured in the Ln2 and volted the shiznit out of it - Did rather well.
I don't believe you're set up for that but if you are, hey - Go for it.
I did. :D
9,340 (5.68/day)
Louisiana
Keyboard G710+x3
It has a couple
freeagent
8,066 (3.73/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
JrRacinFan
20,095 (3.16/day)
Youngstown, OH
Storage 20+ TB
@Bones unless it was a placebo (which could be) I swear Burn-in is what made some of my previous CPUs handle voltage better and stayed more stable during high heat load. This was like socket 1156 days tho
7,211 (1.10/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
BURN-IN! Argh.
I lost an AMD K6-III that upgraded a Pentium 4 socket using the amazing PowerLeap adapter. This was the late 1990s. Did I say already that that adapter was amazing?! Bought it in the Funan centre in Singapore.
No thermal management on the AMD K6-III and it got friend. Never an AMD since that very expensive experience.
freeagent
8,066 (3.73/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I remember people saying this in the 462 days, but AMD could already take hella voltage back then. I think I was at ~2.15v for 2700MHz on a 2500M
JrRacinFan
20,095 (3.16/day)
Youngstown, OH
Storage 20+ TB
So pretty much the consensus is that modern CPUs should not require it anymore. Thank you all.
