CPU Cooler Test System Update for 2024
W1zzard
Administrator
28,384 (3.73/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
some example TDP's should be given
Added this table, is that what you had in mind?
what about a test that’s noise normalized to 35dba on an open bench to see what cools good with low noise?
Yeah, we have plans for testing at lower noise levels, it gets complicated and expensive very quickly
Just put the rpms in parantheses after dB readings in the same chart.
Fantastic idea, exactly what I was looking for
sKam
21 (0.04/day)
Hmm, the only thing is that 45dBA sounds a tad bit high to me. Typically I want my fans to spin at at most 1000-1100 rpm or so what according to the 50% PWM noise/rpm relationship seems to be about 40dBA or so. I'll just mentally add a couple degrees to the noise normalized chart but perhaps you could poll for a noise normalized noise level?
Maybe combine it with a video so we can make a better judgment on how many dBA's measured reflect our perception of "acceptable".
I do question how many people unironically need the full max RPM chart, if you're planning on using this data in some kind of way you're probably only concerned how much W it can cool and how noisy it is. Or worded differently, if the cooler can adequately cool the CPU when needed if all the reins are loosened. Think you can simplify the testing somewhat at no cost.
Maybe I'm wrong however.
I'm looking forward to the test results :toast:
exactly ... the same for me
2 (0.00/day)
COTS air coolers and AIO coolers are great and all, but can you also do a comparison with some custom water cooling setups?
23,513 (6.13/day)
Custom water is custom.. what is there to gain? So many variables...
2 (0.00/day)
I just think it would be an interesting comparison. Let's say a CPU-only loop with 240mm or 360mm radiator, common MCP 655 pump, Heatkiller block, etc.
For some reason nobody ever compares COTS coolers with custom water coolers. I want to know what kind of temp difference I should be expecting, or if AIO already does 90% of what custom can do.
7 (0.00/day)
Italy
System Name LegoPc
Processor Intel Core i7 13700K
Motherboard Asus ROG Strix Z790-E
Cooling Arctic Liquid Freezer III 420
Memory 2x16Gb G.Skill Trident Z 6400
Video Card(s) Gainward NVIDIA GeForce 4090 Phantom
Storage Kingston 2Tb fury renegade, SSD Samsung
Display(s) LG OLED 42C2
Case Lian Li o11 dynamic evo XL
Audio Device(s) Razer BlackShark V2 Pro (2023) - ???????????
Power Supply Seasonic Prime Titanium 1,3KW PciEx 5
Mouse Razer Deathadder V3
Keyboard Razer Blackwidow V3 Pro
I would like to know how my Arctic Liquid Freezer II 420 performs compared to the Galahad II Trinity Performance at the same noise level....
14 (0.01/day)
Could you please test thermalright line of coolers? FC 140, FS 140, PS120... Also, there are a few corsair coolers that almost no one reviewed, like H150i PRO XT.
1,831 (0.52/day)
North Dakota
System Name Office
Processor Ryzen 5600G
Motherboard ASUS B450M-A II
Display(s) Dell S2719DGF
Case Fractal Define 7 Compact
Power Supply EVGA 550 G3
Mouse Logitech M705 Marthon
Keyboard Logitech G410
Software Windows 10 Pro 22H2
I second @mechtech, would love to see something more silent than 45dba. Personally that would be way too loud for my taste. So a 35dba normalized test would be great.
The 15 cm test distance is very close, akin to placing your ear right next to the PC; 45 dBA feels like a reasonable value. Consider:
SPL drops by 6 dB with every doubling of distance from source. 45 dBA as tested becomes 39 at 30 cm, 33 at 60 cm, and 27 at 1.2 m; pretty quiet by most measures.
(I know that SPL and dBA aren't equivalent, but the math is the same.)
W1zzard
Administrator
28,384 (3.73/day)
Memory 48 GB
Fan speed/pwm/dB charts can be merged for shorten the page. I don't think we really need a seperate ascending order rpm chart. Just put the rpms in parantheses after dB readings in the same chart. I understand this can be important for some fans those dont scale well with lower pwm signals but I don't think we need seperate charts just for those presumely 'bad' fans.
Added. Is this what you had in mind?
hello. I would like to know if they have an environment chamber to be used in the methodology?
A chamber is not used, the room temperature is controlled and tracked though
243 (0.06/day)
Processor Ryzen 7 5800x3D
Motherboard Gigabyte B550 Gaming X v2
Memory Corsair Vengeance LPX 2x32GB 3600Mhz C18
Video Card(s) XFX RX 6800 XT Merc 319
Storage Kingston KC2500 2TB NVMe + Crucial MX100 256GB + Samsung 860QVO 1TB + Samsung Spinpoint F3 500GB HDD
Display(s) Samsung CJG5 27" 144 Hz QHD
Case Phanteks Eclipse P360A DRGB Black + 3x Thermalright TL-C12C-S ARGB
Audio Device(s) Logitech X530 5.1 + Logitech G35 7.1 Headset
Power Supply Cougar GEX850 80+ Gold
Mouse Razer Viper 8K
Keyboard Logitech G105
334 (0.12/day)
USA
System Name pr0n box, Version 11
Processor i7-14700K heating the house
Motherboard Gigabyte Aorus Z790 Elite X Wifi7
Cooling Corsair H150i Elite Capellix XT (360mm AIO)
Memory 32GB Corsair Vengeance RGB DDR5-7200 CL34
Video Card(s) 7900XTX 24GB XFX Merc 310 Black -- OC bios 444W ~2800mhz
Storage Samsung 990 Pro 2TB NVMe
Display(s) Samsung G95SC 49" Ultrawide, 5120x1440p240, HDR10
Case Corsair 3500X with Noctua fans
Audio Device(s) Beyerdynamic DT990 Pro, FX-Audio DAC X6, DTS Headphone:X
Power Supply be quiet! PurePower12M ATX3.0 1200W Gold
Mouse Corsair M65 Ultra
Keyboard Corsair K57
Benchmark Scores valid.x86.fr/32wsdg CPU-Z 914/14852 userbenchmark.com/UserRun/68933478
I’m surprised the 360mm AIOs are now outperforming the 280mms since they are roughly the same surface area. Is this because they are putting more powerful fans on the 360s or what? Looks like the Galahad mostly just has powerful fans.
I agree more cpu coolers would be nice to see, like EK and especially some 420mm AIOs with respect to huge heat loads and the nice heat load charts in the new methodology as it applies to Intel present gens.
alfablac
7 (0.01/day)
Weird that the ALF was not included there. At least the 360. It's the best overall, cheap and I think it gets up to 298W
67 (0.11/day)
I would like to see some ITX coolers (Noctua L12S and Thermalright AXP120-67 come to mind, but there are smaller ones than that too) - they won't be able to cool them but you can probably still see how much listed wattage they can cool.
I would also like to see a space-cooling ratio chart noise normalized (and maybe price normalized too hehe)
crazyeyesreaper
Not a Moderator
9,828 (1.68/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
For those stuck on the 45 dBA noise choice. You do realize that distance is highly important you consider 45 too high but fail to keep in account distance. If I drop back to 2 feet from say 6 inches and add a side panel noise levels depending on cooler can drop by as much as 5-7 dBA. That is with all other sides of the chassis open. Meaning at 2 feet in a proper case with say a Tempered glass panel you can pretty much be guaranteed the cooler will end up at around 40 dBA. The noise floor in my home in a rural suburb is 35 dBA (I can't eliminate natural noises so that is as low as it goes for now. While we are looking into ways to improve things. It's not like I have thousands of dollars to double the amount of drywall on my walls and make other improvements to further isolate the room. So with what I have on hand the current setup was the best way to show a difference between the coolers and give an accurate result.
stuen4y
5 (0.01/day)
The new setup looks good and relevant so thank you for the update.
I agree there are at least a couple of Thermalright coolers missing - PS/PA120 and FS/FC140 (to be honest less concerned about the frost ones as they don't seem to perform that well overall compared to PA/PS). You could add a single tower Thermalright in the mix too for the budget pick. With the performance/price Thermalright has been offering in the past 1.5-2 years, it's pretty much impossible to beat so should 100% be on the charts.
483 (0.10/day)
Quodam loco Albanianae
System Name The Dark side of the room
Processor AMD Ryzen 9 5900X
Motherboard MSI MEG X570 Unify
Cooling Custom loop watercooling (Bykski CPU-XPR-POM-M-V2, Alphacool Eisblock GPX, Freezemod PU-PWM5B18W)
Memory GSkill Ripjaws V DDR4 3600 CL16 (4 x 16GB)
Video Card(s) XFX Speedster QICK 319 Radeon RX 6700 XT
Storage 1 x Kingston KC3000 1024GB (boot drive) + 2 x Kingston NV2 2TB (games & storage)
Display(s) LG 34WP65C Ultrawide 3440x1440 @ 160Hz freesync premium
Case Thermaltake Core P90 TG (slightly modded)
Audio Device(s) onboard Realtek® ALC1220 with Logitech Z906
Power Supply MSI MAG A850GF 80 Plus Gold
Mouse Roccat Burst Pro black
Keyboard Sharkoon Skiller SGK60 (with brown Kalih switches)
Software Windows 11 pro
Benchmark Scores It's a form of exhibitionism...;-), but fun in a way But showing off is triggering.............
Properly testing with consistency at an almost scientific level is really complicated, shown by the fact how you struggle with the questions which methodology and what parameters. You guys toke quite a challenge on you, my respect for that.
The question you're asking here is actually the expectations of what the readers think is logical info regarding CPU coolers. Do you think it is posssible to publish unambiguously interpretable data, despite the huge variaty of individual technical knowledge out there? It's almost mission impossible ;), as most of the readers would translate test results to their real live situation (already in this thread you see basic questions; why is my cooler X not better compared to cooler Y).
We all know the discussions in the past; if you use this or that fan on this or that cooler it performs soo much better, so I personally would like to see how much heat a bare cooler can maximally dissipate, despite the out of the box fan solution of the vendor. That means testing with air going through the cooler with a fixed velocity and temperature.
The heat it can dissipate is a combination of the size of it's release surface and volume of air passing through, where the volume is a variable depending on the dimensions of the cooler. Velocity of the air is another variable but needs to be set, because at a certain point it will have no more added value.
This just basically gives the heat transferring and dissipiation capacity of the bare cooler, but does () not nescesarilly represent the vendors solution with the provided fans.
Yup, I already hear the comments, what about the noise? Well as stated in the article dBA meter A gives a different reading then dBA meter B and there is also the unpredictable personal interpretation or sensitivity for noise. You already mentioned it in your article with the magic words: Percieved Loundness.
Human hearing has a sound frequency range between approximately 20 and 20,000 Hertz. Humans cannot perceive frequencies outside this range as sound. But depending on several variables it is so damned personal on what an induvidual thinks/feels is acceptable that just measuring dBA doesn't cover it.
Frequencies also have a big influence on this percieved loudness, just look at this thread: https://www.techpowerup.com/forums/...-stealth-metal-fan.314467/page-5#post-5157678
so many things about this topic running throug my head, just hard to express them in words, especially in a foreign language.
But you guys do a splendid job, keep up the good work :clap:
41 (0.02/day)
System Name SoppingPC
Processor I5-14600kf @ 5.9ghz all P_cores & 4.5mhz E undervolted 50x ring. Max 145w and 74c r23 cinebench
Motherboard MSI z790 DDR5 Wifi Gaming etc
Cooling Arctic Liquid Freezer II 360mm radiator A-RGB CPU Cooler
Memory 64gb (2x32gb) g.skill cl30 ddr5 xmp 6400 cl32. @ 6600 cl30 38,. 38 , 90
Video Card(s) Asus RTX 4090 3090mhz core +1150mem
Storage Samsung 980 Pro 2tb NVMe, Corsair MP600 2tb NVMe, and 6x other drives
Display(s) LG C3 42" via HDMI 2.1a and eARC + Samsung Q990d
Case NZXT H7 elite premium white. Upgraded rear 140mm case exhaust fans
Audio Device(s) Samsung HW-Q930D atmos eARC 2.1 soundbar, sub, rear Atmos speakers. 17 total speakers
Power Supply Corsair HX1000
Mouse Logitech 502x Gaming wireless. Powerplay mat
Keyboard Logitech G915 wireless
VR HMD Oculus Rift @ 500% graphic upscale
Benchmark Scores Very damn good
ARCTIC Liquid Freezer II 360 latest generation 3 (I think). Best cooler on the market in every context​
408 (0.51/day)
Even with the motivation I've provided?
I try to steer clear of the number game because, well, what you said.
Instead I equate it to an RPM and simply based on my experiences whatever RPM you guys measure/consider/etc. to be 45dBa is imo significantly louder than I'm willing to deal with.
It's not a huge problem, but I question where this particular level was taken from. It seems a bit... Arbitrary... As if someone just decided it on a whim without considering what the audience wants.
Maybe I am just the loud minority though.
And I'm actually somewhat infuriated by everyone complaining about coolers missing from the test or asking for coolers to be added, way to miss the point of this entire discussion guys.
crazyeyesreaper
Not a Moderator
9,828 (1.68/day)
Keyboard Mionix
Which is why the charts have been cleaned up and RPM information added to the dBA charts to make the data more complete, concise, and easier to read. Essentially combining the two into one. For the time being. I also didn't say we were not looking into other options. That is still on the table and actively being worked on but that requires more planning before anything is set in stone.
ecin96
4 (0.01/day)
Noctua NH-U12A is the best quiet cooler {pause for dramatic effect} I've owned so far. Recommended. I'm bias as I dislike AIOs.
My PC: Torrent case with stock fans removed and only 3x NF-A12x25 fans as intake at 500rpm. Seasonic Fanless PSU. I'm fussy with PC noise :) The performance is mostly due to the fan I expect. The new upcoming 140mm Noctua fan and CPU cooler should also be very good when they're eventually released.
334 (0.12/day)
USA
9,340 (5.04/day)
Louisiana
Keyboard G710+x3
You conveniently ignore the bit "It doesn't come cheap" part :laugh:
