CPU heating up after thermal paste application
2,253 (1.01/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 3700x . 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. Rog b450 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
I use GD900
me too. ive been using it for 3 years or more its around the same as MX-4 cooling wise and you get 50g for £6 straight from china in my view its a nobrainer. OP i know others have said but you have applyed 80% too much bud.
64K
6,773 (1.71/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
I've never used that much thermal paste and I put a little over the size of a pea right in the middle of the CPU IHS. I don't use the spread with a credit card method because I think this creates more of a chance for air bubbles to get trapped. Air is a horrible means of transferring heat. The way it was explained to me is that even though an IHS seems flat to the naked eye when looking at the IHS under a microscope you can clearly see pits in the metal and some unevenness. The point of the TIM is too fill in those pits and unevenness. It doesn't take much.
What will happen if I don't put a thermal paste in my processor and  heatsink? - Quora
9,914 (1.84/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yeah too much, too much paste will make the heat transfer worse
the less is better, using dot/pea size or i usually using small dabs. so far so good
3,514 (1.18/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
That is not a good advice, you will get worse thermal if you don't put in enough paste vs putting too much paste.
The extra paste just get squeeze out the side because of mounting pressure.
Gamersnexus did a video about this, too much paste is not an issue for desktop CPU, not enough paste is
Also how you mount the cooler is very important, just make sure to distribute the mounting pressure equally.
9,914 (1.84/day)
Jakarta, Indonesia
Case Icute Super 18
too much paste is not good when you need to replace the newer one
actually just for sure you need to test it before fix it to avoid too much paste excess
13 (0.00/day)
Reporting back guys,
Finally issue is resolved. Everyone was correct about the fact that base of my heatsink wasn't making proper contact with IHS. my heatsink plate had came off lose although only by ~2 mm (unnoticeable) hence why i couldn't for my life figure out what I am doing wrong in my application.
With that fixed my temp are ~ 15C lower than what i was facing with lose contact plate.
AND guess what! i think my contact plate had came a bit lose from even before(when i installed my new corsair AIO cooler) although may be barely noticeable as well, hence why i was noticing temps in 80s (while gaming) on my 9900k. With my new paste and tightened plate my temps are with in 70s even under stress test load.
Thanks everyone once again. This forum users are really helpful!
Mussels
Freshwater Moderator
58,413 (7.89/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
we go off topic and argue with each other lots, but we do try and actually solve tech problems here
9,340 (5.24/day)
Louisiana
Keyboard G710+x3
I am sorry is this in reference to my issue? Can you please elaborate a bit more? also i am not sure what u mean by contact issue. All was ok on the stock paste that corsair AIO came with. Issue started only after i put on a new paste.
the suggestion is that when you removed the cooler to do the repaste something happened to stop things going back together properly.. your picture suggests that..
the amount of paste still on the parts also suggests the parts were not mating properly.. excess paste should be squeezed out of the sides and not stay in a big thick looking blob lke your picture shows..
this isnt just about different pastes.. its something else causing the prob;em..
trog
Sorry missed it
Trog summed it up nicely :cool:
