- Nov 18, 2010
- 7,607 (1.42/day)
- Rīga, Latvia
System Name | HELLSTAR |
Processor | AMD RYZEN 9 5950X |
Motherboard | ASUS Strix X570-E |
Cooling | 2x 360 + 280 rads. 3x Gentle Typhoons, 3x Phanteks T30, 2x TT T140 . EK-Quantum Momentum Monoblock. |
Memory | 4x8GB G.SKILL Trident Z RGB F4-4133C19D-16GTZR 14-16-12-30-44 |
Video Card(s) | Sapphire Pulse RX 7900XTX. Water block. Crossflashed. |
Storage | Optane 900P[Fedora] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO+SN560 1TB(W11) |
Display(s) | Philips PHL BDM3270 + Acer XV242Y |
Case | Lian Li O11 Dynamic EVO |
Audio Device(s) | SMSL RAW-MDA1 DAC |
Power Supply | Fractal Design Newton R3 1000W |
Mouse | Razer Basilisk |
Keyboard | Razer BlackWidow V3 - Yellow Switch |
Software | FEDORA 41 |
Here already is so much wrong posted again... as I said... seldom who understand how to compare two audio products, and has nothing to with listening tests. Is a pure torture test, like Cmaris does with his PSU's. No feelings, huge amount of data and possible faults. Even the news post stating that this thing does not have a rollable OPAMPS is a blessing, not a con. Most people don't understand the physics and parameters, that influence noise and distortion plot from variable device characteristics. It is not a child play... go roll some parts in your power supply too, afraid? I wonder why, they don't differ that much actually, especially the AXI DSP based series...
People living in the past, complaining with drivers, should understand, that on most parts it was not Creative fault, but Microsoft. Most of complainers haven't had a card at all, others most probably had a broken product, that needed RMA. Second hype wagon with USB's DAC's do not understand that they are fed on marketing, that is based bashing older solutions in order to SELL, they are the same and suffer from same issues. Including rail noise, jitter, distortion, heavy latency and most importantly - poor design!!! Poor sheep.
So why one earth this PLUS is needed remains strange. This cards selling point is his discrete headphone amplifier section, nothing complicated, but so robust and properly set it excels and leaves into dust many solutions, especially with problematic headphones that are not easy to drive.
They are screwing again with Microsoft software stack, as such features like DTS and DDL are now intended to be in the market and as separate audio stack feature. I am afraid they are risking with the fact, Microsoft will get annoyed again. I am also sure the latency will be horrid again with those things. It not meant for gaming, so basically it is marketed a gamer card, yet these things do not fit there really. You will get shot before you heard the footsteps.
