Cross by Red Harbinger
l3p
408 (0.08/day)
Netherlands
System Name L3p D3sk
Processor Intel Core i9 7980Xe
Motherboard ASUS Rampage Extreme VI
Cooling H2o
Memory Corsair Dominator Platinum SE 64GB 3400Mhz
Video Card(s) Nvidia Titan X (Pascal) 12GB
Storage Intel 750 Pci-e 1.2TB
Display(s) Asus ROG PG348Q 34" Gsync
Case Aluminium plate 2000x1000x3
Audio Device(s) Bose QC 35II
Power Supply Corsair HX1000i
Mouse Finalmouse Lightweight Pro
Keyboard Corsair K70 RGB
Benchmark Scores http://hwbot.org/community/user/l3p?tab=submissions
The first inspection of the desk.
This was so important for us, some times I forgot to take pictures for the buildlog.
Here are the first issues I walked into, we're human too :)
(All these things have been changed in the new design)
Again this is a real old design of the legs, still had to test some stuff for the acrylic.
A weld at the top of the desk .. oops, the cover wont fit like this..
And a funny one .. the holes and grommets for tube or fillports to big.
This should have been changed but slipped through.
Without a grommet the fillports fall through.
I'll find something on that for now.
Also a funny one, after assembling the supports they aren't horizontal.
PSU mount fits almost every PSU ... except this one :).
HDD trays really look good, personally won't use them in this build.
When I removed them.. oops .. no covers.
Also raised all fan/rad holes, more space for cable management.
And me as the only European in the team.
Off course the other side of PSU plug fits, but for in case people want to have their power socket inside.
Sometimes pretty exhausting... "what if they"... :)
Personally going to use these instead of the PSU mount. Less noise and easy to move.
We will supply these too.
Inspecting the desk, best is to just start building a pc inside.
So lets start with the fans and rads.
For this setup I needed over 160 bolts and nuts :)
Back rads.
Side rads.
Lighting not overdone, I like the Cooler Master fans.
Another way to feed your PC.
Lets take care of some working light :)
And installing some grommets.
Here I was still planning to do a single pc build, still had all the space for 2 fan controllers.
Pump controller from previous project for the looks :)
Rads seem to be brown with flasher on.
Had a spare fanguards, might be nice to keep it there.
This is something I'm REALLY happy with in the design.
In my previous desk it took me dozens of hours cause I didn't have this.
The first cables.
The bridge also has mounting options for 12x2.5" HDD/SSD.
Personally I'm not going to hide them. :)
And the rubbertape for under the glass panel that will be used to protect from scratching, breaking and noise.
1,585 (0.28/day)
Los Angeles/Orange County CA
System Name Vulcan
Processor i6 6600K
Motherboard GIGABYTE Z170X UD3
Cooling Thermaltake Frio Silent 14
Memory 16GB Corsair Vengeance LPX 16GB (2 x 8GB)
Video Card(s) ASUS Strix GTX 970
Storage Mushkin Enhanced Reactor 1TB SSD
Display(s) QNIX 27 Inch 1440p
Case Fractal Design Define S
Audio Device(s) On Board
Power Supply Cooler Master V750
Software Win 10 64-bit
Well I need a new desk. Where do I send my $50? :D :laugh: :eek:
  • Like
Reactions: l3p
5,614 (1.01/day)
San Diego, CA
System Name White Boy
Cooling CORSAIR H100
Display(s) 1 Dell 30U11 30"
Case BIT FENIX Prodigy
Audio Device(s) none
As always your builds are the best of the best! I will be following this one closely!:toast:
  • Like
Reactions: l3p
l3p
408 (0.08/day)
Netherlands
Cooling H2o
Mounting blocks ... love it!
First the mainboard.
And the cards on it for a picture..
Added some extensions.
Glad I took time to test the hardware in front ;)
Ordered an EK-Bridge for the GPU's
Never used them before.
I like it.
Cut out the grommets.
And put them backwards in the 'firewall'
Seems the BP fillports stay in place perfectly now.
In the new design the holes and grommets have been changed.
First fittings in place.
The mess.
Might be an idea for a drainpoint in the bottom later.
Another funny thing ..... Glad this will be solved with the rubbertape under the glasspanel. :)
First cables and extensions.
Flipped all fans from rear radiators. (again 64 bolts...)
Did this so the airflow from the fans work with the PSU flow.
3M Velcro for the RGB controller
Found her spot :)
Feeds for the fancontroller and pump on their spots
Powersocket for 2 PSU's, screens and speakerset.
Adjusted the cable length.
RGP plug brought to other side of desk too.
Preview with 'PSU-cover'
A solution for the missing HDD-bay covers .. and a nice spot for the ssd's since I'll be using the other side of the desk for another pc now.
Simple ..
But effective :)
5,614 (1.01/day)
San Diego, CA
Man this build just keep getting better and better!
1,039 (0.17/day)
Frankfurt/Main - Germany
System Name Shaman of Sexy
Processor AMD Phenom II X4 955 BE@4Ghz EK Supreme Block
Motherboard M3A79-T Deluxe Anfi-Tech Waterblocks
Cooling Magicool 360 + 120 + 120 Slim scythe slipped Laing DDC-1/T
Memory 4GB Corsair Dominator CM2X2048-8500C5D
Video Card(s) Sapphire ATI Radeon HD 4870 X2 EK 4870 X2 Block
Storage RAID 0 Seagate
Display(s) Samsung 226BW 22"
Case CoolerMaster Cosmos RC-1000 in mod progress
Power Supply Coba Nitrox 750W
Software Windows 7 Ultimate
Benchmark Scores http://service.futuremark.com/compare?3dmv=1056967
l3p
408 (0.08/day)
Netherlands
Cooling H2o
And another update with quite some photos :)
Unpacked the reservoirs and put them on their spot.
Also some more changes in the prototype .. more grommets for itx and m-atx.
Starts to look like something.
Also cut the heatfins again.
I personally like it.
Also an idea for the speakers.
I know speakers should be positioned in front but tested it and I don't notice it :)
Coincidence the finish of the sub is exactly the same as the desk powdercoating.
First some extra holes for the fan/pump controller.
Next prototype will have some mainboard grommets there.
Glad those trays are aluminum :)
Building in the speakers.
There won't be any cable visible from the speakerset when I hide the sub + all cables in the legs.
Measuring.
Adjusting the speakers for long M4's
And finishing it.
Too bad the cone is blue, anyone any idea if cones are paintable?
A solution so the fancontroller and RGB controller are ALWAYS on, no matter if there's one or two pc's running
Works perfectly :)
Extra power/reset buttons.
Next proto there will probably be a bracket here.
Also finished the holes for pump/fan cables.
For this build I will seal the unused 5.25" slots. Next proto this will be different.
The glue will be transparent when dried.
Cut away some in the grommets, looks better.
And some further again.
Still in love with the bottom mainboard covers :)
Time to move on with all sata cables.
Also found out I didn't have sata extension cables yet for the right system.
So ordered them too.
For the SSD rack I will use cheap Velcro, I would damage the SSD's with 3M velcro when removing them :)
Works perfect.
Because we didn't have PCI-covers yet I ordered these.
Because I chose real thick radiators because I thought I was going to do a single pc build I'm having small problems finding a spot for the second PSU.
Sleeving the yellow sata extension cables
Lets first use some black isolation tape.
Even if you only see 3cm .. .yellow .. no way :)
Also used the rubbers for the second PSU.
Lovely music while modding :)
Securing the pumps.
Tube ready to go, first fittings find their spot.
Had to remove mem again, quite narrow to get the fittings in properly
And a little further again.
Ok ... and then 11 days ago Asus requested if they could show 'Cross' on the Dutch Firstlook 2012 Event... not as a desk but built in their stand.
Off course, I was so honored! This only happens once a year!
And ... if I could built in the Maximus V Formula....
I did agree off course, been some real busy days the last week.
So at this moment I'm a bit behind on the log, so some photos could show up but will make this up this week!
For who does have pictures .. please hide them for a while :D
(I did ask them to step away :D )
t_ski
Former Staff
11,960 (1.74/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
Looks awesome as always. I would not recomend painting the speaker cones, as it will affect the sound quality. Unless of course, that looks are all that matters for the build.
  • Like
Reactions: l3p
stinger608
11,251 (1.90/day)
Wyoming
System Name 2023 Ryzenfall
Processor AMD Ryzen 5800X
Cooling SilverStone AH240 AIO
Case Corsair Air 540
Audio Device(s) On board
Okay, once this frigging crazy awesome system is completed you are going to ship it too me........Yessssssss you are..........you must............:laugh:
Just frigging awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Like
Reactions: l3p
43,327 (6.75/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
SUBSCRIBING! :toast:
  • Like
Reactions: l3p
HammerON
The Watchful Moderator
8,400 (1.45/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
This is just insane:toast:
I am amazed (even still after you other builds) of the detail level and ingenuity:)
SUB'D
  • Like
Reactions: l3p
5,614 (1.01/day)
San Diego, CA
Amazing! FLAWLESS work as always!:toast:
  • Like
Reactions: l3p
43,327 (6.75/day)
i know that "Desktop" Computer will rarely heat up as bad as most machines due to the space its encased in, but thing is how easy will it be to keep it dust free?
3,539 (0.67/day)
Netherlands
System Name AP201 | N2Plus | NUC
Processor AMD Ryzen 5 3600 | Amlogic S922X | Intel Core i5-7260
Motherboard Gigabyte B550M DS3H |Odroid N2+ | NUC Board 7
Cooling Inter-Tech Argus SU-200, 3x Arctic P12 & 1x Corsair 140mm case fan | stock heatsink+fan | stock HSF
Memory Gskill Aegis DDR4 32GB | 4 GB DDR4 | 16 GB DDR4
Video Card(s) Sapphire Pulse RX 6600 (8GB) | Arm Mali G52 | Iris Plus 640
Storage SK Hynix 240GB, Sam. 840 + 850 EVO (2x (250 GB)| Samsung 850 Evo 500GB | WD Green 240 GB
Display(s) AOC G2260VWQ6 | LG 24MT57D |
Case Asus Prime 201 | Stock case (black version) | Stock case
Audio Device(s) integrated
Power Supply BeQuiet! Pure Power 11 400W | 12v barrel jack | 19V laptop brick (Asus)
Mouse Logitech G500 |(runs mostly headless) | no-name ergo mouse
Keyboard Qpad MK-50 (Cherry MX brown)| (runs mostly headless) | Blaze Keyboard
Software Fedora, Windows 10 | Gentoo Linux | EndeavourOS
Good point being made there ^.
l3p
408 (0.08/day)
Netherlands
Cooling H2o
Well I guess like any other pc, just undust it every once a while or use dustfilters on your fans :)
This week 2-3 updates :)
Because the desk had to be running and presentable I still needed some things quickly.
Because of the 4 reservoirs and 2 systems I needed more tube and stopfittings.
Thanks again for the nice discount Freddy!
And from Mayhems.
And something I had here already a while to flush my other desk, that'll have to wait :)
Love experimenting.
Gotcha! :)
Thanks for all the support Michael!
Also needed for the second pc, again Bitfenix extensions.
And something new I got from EK.
My first CSQ design block.
Again thanks a lot Eddy en Gregor!
The package I got 3 days before the event.
Very nice and complete package.
Ready to swap.
I do like it.
Rogier .. TOP!
Tomorrow another update with tubing and filling.
5,614 (1.01/day)
San Diego, CA
Easy for a pre paid (sponsored) system, to give the kid a name
Sour grapes much !?!?:shadedshu
I can't wait to see how this project end up!
  • Like
Reactions: l3p
3,145 (0.65/day)
Processor 8700k Intel
Motherboard z370 MSI Godlike Gaming
Cooling Triple Aquacomputer AMS Copper 840 with D5
Memory TridentZ RGB G.Skill C16 3600MHz
Video Card(s) GTX 1080 Ti
Storage Crucial MX SSDs
Display(s) Dell U3011 2560x1600 + Dell 2408WFP 1200x1920 (Portrait)
Case Core P5 Thermaltake
Audio Device(s) Essence STX
Power Supply AX 1500i
Mouse Logitech
Keyboard Corsair
Software Win10
Except you forgot that l3p started from scratch with his builds and he EARNED the sponsorships, he literally crafts wonders and I am strongly convinced that many can't reproduce his level of craftsmanship.
His attention to details and unique touches like the Corsair SSD rack or utilizing original pieces of the Mars II cooler on the custom waterblock make his build above top notch.
3,539 (0.67/day)
Netherlands
QFT radrok. :)
  • Like
Reactions: l3p
l3p
408 (0.08/day)
Netherlands
Cooling H2o
Quite a puzzle with what I wanted with the in and outlets of the multi reservoirs and both loops mirrored.
It became a multireservoir extreme :)
Measuring the reservoir brackets.
Going to have the tubes to the pump of the left loop in the bottom.
Again happy this part is aluminum.
Done!
And the first tubes.
Also quite a puzzle again with all the small distances.
Pump for the left loop.
Might change this later..
Mainboard done, reservoirs next.
With flasher.
Left loop with flasher.
And just the RGB LEDs
Exiting for me .. first time filling.
And another adrenaline moment for me, first time enabling the pump. :)
Also need to find another solution for this, now that i'm running 2 pc's I don't need the long sata cable lengths to the raidcard.
Maybe will order other cables later.
Great feeling when you don't have any leaks.
The Mayhems Pastel and red dye additives.
I was warned this could fail with such a big loop ;)
Here I forgot to close one stopfitting after disabling the pump...
Glad is was easy to clean :)
Adding the Aurora, it was a bit scary at the start.
But got the result I wanted one minute later.
Another exiting moment....
But it boots with the desired temperatures :)
And a video of the loop, filling and mixing.
Got the Maximus V Formula in.
Only one day to go, so started right away on the second loop.
Meanwhile testing and installing the left system.
Raw fingers of all that tube :)
Again exiting..
This time premixed before filling.
Mayhems Aurora, cool stuff :)
But also creepy.
Both loops running.
Because there's a team of helpers ready to get the desk one floor down.. quickly close the panels without any management. :D
Ready to go!
Later today the migration.
l3p
408 (0.08/day)
Netherlands
Cooling H2o
20 hours before I bring the desk to the event
Small reminder all photos are linked to bigger format photos :)
You can see on the face expression who's stressed :D
At the right the remains of the little 'incident'.
A filled pc with a length of 1.50m and 80kg that has to go downstairs almost vertically.
My wife taking pics and most of all ... paying attention I don't scratch the wall :p
The fun they had..... :)
Being relieved.
Temporary on a wooden box so I can do the last adjustments, cable management and installing OS+drivers+software etc.
The rubbertape I used for sound attenuation and protecting the glass panel.
Also filed the weld so the cover fits.
With glass panel.
This was a weird moment for me .....
"Desk ... I am your father"
HammerON
8,400 (1.45/day)
Up North
System Name Aki
Software Win 11 Pro
AMAZING:toast:
  • Like
Reactions: l3p
l3p
408 (0.08/day)
Netherlands
Cooling H2o
Firstlook 2012!
It took me 2 weeks to prepare everything for just a 2 day event including taking 3 days off from work ....
Well in my opinion it was completely worth it! :)
Ready to go! The Friday night before the event.
Inspecting the booth.. oops .. I didn't expect the front side wouldn't be able to show.
Too bad .. too late to change, this way they can't touch any of the buttons.
The first "wtf's" from the ASUS crew :)
Last minute adjustments so the glass panel will be flush.
Really cool experience, the constructing of an event, 1 big pile of ants :)
Checking if everything still works.
All just fine :)
Also finding a spot for something from a previous project. On top was no option cause of bending the glass shelf :)
This is how I had to leave it behind.
Believe me, this was pretty scary..
Till tomorrow morning!
Quickly getting everything running 15 minutes before the doors open up.
The relaxed overclockers 'Old Scarface' en 'Leeghoofd' also at the booth.
Here some shots of the event itself, made by my brother in law, still nice and empty :)
Everyone getting instructions :)
Doors are open and first people get in.
ASUS booth still pretty quiet.
Our little corner :)
Fun to see from that close.
Honored this could also be at the booth.
And some shots of the built-in desk now that it's still quiet.
First thing they run off to .. Black Ops II stand ... yup .. 100% gamer event :)
Really enjoyed the OC sessions!
Cards were gone within half an hour :/
For who wants to see more boothbabes .. check here :)
Ok .. here it was too crowded for me :)
Highres picture of all the interest for the desk.
Playing with Nitrogen :)
Here a small video of the desk 5 minutes before closing time.
The result .... I hate fingerprints :p
Astonished how the got the stand 'hardware-less' within 10 minutes.
And back home.
ASUS Benelux, a huge thanks for this opportunity, it really was a great experience!
For now a small break, need to save up some money and and saw in some stuff in the desk :)
3,539 (0.67/day)
Netherlands
Nice pics, and I see a bag from a store with "7 certainties", lol (the yellow Jumbo bag). A future sponsor? ;)
I cannot click on a thanks button, unfortunately (the thank-spamming prevention has kicked in).
  • Like
Reactions: l3p
l3p
408 (0.08/day)
Netherlands
Cooling H2o
Thanks! :)
I will probably remain Jumbo's sponsor the rest of my life and not vice versa :D
