DDR5 Corsair
10 (0.01/day)
I come from a i5 8500 with DDR4 Corsair Vengeance LPX (Hynix chips) and understand that this ram doesnt play nice with
ryzen 5000 series, so I want to avoid this situation now that i want to go for next gen, r5 7600 or i5 13400f. I want to be able to
use it with both platforms. And no RGB sh*t.
What do you think about these? B-dies?
ir_cow
4,802 (0.80/day)
USA
Ryzen 7000 is DDR5 only. After this year's Intel 14th gen, Intel will be DDR5 only as well.
DDR5 won't work on Ryzen 5000 series. The posts reads as if you want to use DDR5 for a DDR4 only platform.
For DDR5, Hynix is actually the best :)
18,584 (2.66/day)
System Name AlderLake
350 (0.51/day)
System Name Can it run Warhammer 3?
Processor 7800X3D @ 5Ghz
Cooling Enermax Liqmax III 360mm
Memory Teamgroup DDR5 CL30 6000Mhz 32GB
Video Card(s) Gigabyte 4090
Storage Silicon Power XS70, Corsair T700
Display(s) BenQ EX2710Q, BenQEX270M
Case NZXT H7 Flow
Audio Device(s) AudioTechnica M50xBT
Power Supply SuperFlower Leadex III 850W
I'm using Corsair Vengeance DDR5 6000 speed (rated for 6400). Vengeance only supports XMP not EXPO, and XMP profiles do not work on my 7800X3D+Gigabyte B650 Aorus Elite combo. I had to manually set it.
If you go AMD I'd buy EXPO capable RAM that is listed as supported by the motherboard you get. Max 6000 speed.
10 (0.01/day)
Nope, I didnt make myself clear. It is known that Corsair Vengeance LPX DDR4 doesnt work all the well with Ryzen 5000 series. I want to avoid such problems when buying DDR5 modules, now that i want to upgrade to Ryzen 7600 or i5 13400. I want some ram that will work well with both platforms. I will avoid EXPO memory, cause i may need them in actual or future intel configs. So I need the "jack of all trades" when it comes to compatibility.
I believe there are Vengeance modules that support only EXPO profiles.
18,584 (2.66/day)
I'm not so sure about that but you might want to check this:
tabascosauz
8,229 (2.32/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
DDR4: higher end Hynix good for value and OC, B-die daily
DDR5: Hynix good, Samsung bad
On the AMD platform you won't notice much (at least right now) because you hit the 6000 wall, and both can still tighten timings a bit. On the Intel platform you will immediately notice that the Samsung has zero OC headroom.........but at the same time 13400F is a last gen part, and locked models locked VCCSA means RAM headroom is limited somewhere below 7000 anyway.
212 (0.17/day)
Colorado
Processor AMD Ryzen 9 9950X
Motherboard Asus ROG Crosshair X670E Gene
Cooling Full Custom Water
Memory 48GB DDR5
Video Card(s) Nvidia RTX 5080 FE
Storage Crucial T700 2TB Gen5 SSD
Display(s) Asus PG32UQX
Case Primochill Praxis WetBench
Audio Device(s) SteelSeries Arctis Pro
Power Supply SeaSonic Prime SSR-1300TR2
Mouse G502 Lightspeed
Keyboard Keychron Q1 Max, Drop + Matt3o MT3 Susuwatari, Gateron Pro switches
Software Windows 11 Pro 23H2
Manta XPrism Dual profile memory. https://v-color.net/products/manta-xprismrgb-48gb-dual-7200mhz-ddr5-extremeocmemory
The kit is Hynix A-Die 2x24GB, @ 7200MT/s Intel XMP, or 6200MT/s AMD EXPO.
43,903 (6.80/day)
Just buy some crucial or mushkin, patriot and call it a day
10 (0.01/day)
