Deep clean on motherboard after water cooling mishap
143 (0.03/day)
New Zealand
System Name The Beast
Processor Intel Ivy Bridge-E Core i7 4930K 4.4Ghz 12MB LGA2011
Motherboard ASUS Rampage IV Black Edition X79 E-ATX/ Asus B150I Pro
Cooling OVERKILL CUSTOM WATER
Memory 2x Kingston HyperX Beast 32gb 2333mhz (64gb total) / Corsair Vengance 16gb
Video Card(s) 2x GTX 1080ti Poseidon / Evga 780 ti S
Storage 2tb Seagate, 120gb Crucial ssd x2 raid (OS) 3x500gb
Display(s) SAMSUNG LU28D590DS 4K 28" UHD 3840x2160 1ms x3 Resolution 11,520x2160
Case Lian Li DK-02 Desk (ATX & Mini-ATX)
Audio Device(s) Onboard sound, Astro 5.1 headphones and amplifier, THX Surround
Power Supply Corsair HX1000i / Corsair HX750i
Mouse Razer Ouroboros
Keyboard Razor Death stalker ultimate, Razor Orbweaver
Ehhhh.. If you don't have the cover for your socket I would advise not washing a motherboard in a dishwasher. der8aeur can do it, but you really gotta know what you're doing. Seeing red in the socket is a big red flag for me (pun not intended :D) . You could try flooding the motherboard in IPA and using a plastic syringe to clean out all of the crevices and holes that fluid got into.
I'm going to do that tomorrow. But being King's birthday weekend the only local shops I believe have 70% isopropyl. There is acouple places that will stock crc contact cleaner however. I'll see how much is in that. (What I've been using to flush) this time I'll just be spraying over and into a container
142 (0.17/day)
Processor AMD Ryzen 2700X
Motherboard MSI X470 Gaming Pro Carbon
Cooling NH-D15 SE-AM4
Memory 4x Kingston 8GB DDR4-2666
Video Card(s) 2x EVGA GTX 960
Storage Kingston SA400 480GB, LSI 9260-8I RAID[2x WD4005 4TB, 3x Kingston SA400 480GB]
Display(s) Scepter P30, Samsung T22B350
Case Phanteks Enthoo Pro
Power Supply Seasonic Prime Titanium 650w
Mouse Logitech MX Master 3
Keyboard Corsair K60 RGB Pro RGP01110
I wouldn't use the spray stuff because of the inhalation hazard from simply the amount of stuff you'd have to spray at one time. You could go into the shop, explain what happened, and that you want to make a contact cleaner bath and see if they have anything for that, I'm betting they do, and it should be cheaper per liter than the spray stuff
Solaris17
Super Dainty Moderator
27,538 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Iv used CRC sensor/MAF cleaner and it worked great. For something like this I have also done denatured alcohol in a small plastic bin (you can buy it by the gallon) and a soft tooth brush. Cleaned all the nasty bits
I generally only used maf cleaner on the socket where I couldn’t go with a tooth brush.
don’t forget to change all thermal pads or repast all of the board coolers.
2,754 (0.67/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
Main thing to watch for is to make sure whatever spray cleaner you get is plastic safe.
If it doesn't say it on the can, leave it where you found it.
Also be aware most, if not all spray cleaners will create a cooling effect in the area the board is sprayed and that in turn will attract condensation to the board.
You have to be sure it's dry before hooking up power to the board.
1,131 (0.78/day)
Bavaria ⌬ Germany
System Name ✨ Lenovo M75q-1 [Tiny]
Display(s) DELL S2722DGM
Software Windows 11 Pro (Debloated)
Man that looks really nasty. Like you had a visit from Jason Voorhees. :laugh: Also the reason why soft tubing is way more safe than hard tubing. Plus non dyed/non conductive liquid.
I think the bast way to clean it would be a ultrasonic bath in a "EC Formulated Cleaning" solution, like the guy in the following vid is doing. Then let it evaporate for a day and put it in the oven for a few hours (hot air, not plastic melting temperatures, up to 80 degree celcius should be safe).
431 (0.11/day)
System Name Blackbelt 2
Processor AMD FX 8350
Motherboard ASUS M5A99FX PRO R 2.0
Cooling Cooler Master Hyper TX3 evo
Memory 8GB Corsair Value Select DDR3
Video Card(s) ASUS R7260X DC2OC 2GB
Storage INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM
Display(s) DELL ST 2240L
Case Cooler Master Elite 311
Power Supply CORSAIR VS Series 550W
Software Windows 7 Ultimate 64 Bit
Benchmark Scores 3DMark 11 6532
You could try getting the MB cleaned at some electronic shop or PC repair centres for a small fee....it will be a burden off your mind.....can also have it tested while you are at it....as a last option...
44,144 (6.81/day)
Take the cmos battery out first
5,413 (3.68/day)
Colorado, U.S.A.
Software Windows 11 Home
The fumes from which make me sick; but isopropyl alcohol is good.
I'd scrub it with water, follow up with isopropyl alcohol and then blast it dry.
Could be done in 10 mins
2,294 (1.21/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
That's how you kill boards man! Trying to datavac or compressed air dry a mb will 100% end in death. Trust me. I've tried it, and failed. The only sure fire way of drying mbs is to do it exactly like Bones suggested. Otherwise, I guarantee you will end up forcing water under the memory, gpu slots and CPU socket. As well as any other small components that aren't flush mounted.
1,457 (0.34/day)
Australia
OP, I realise you don't have a big budget for upgrades but reading over the hints & tips supplied to fix your problem, Is it really worth it in the end?
You do realise today you can get a base model B760 board (as am example) with a low end LGA1700 cpu that will perform about the same if not better than that 2013 X79 board you have back in its day? I mean this is decade old tech right?
Also, if you intend going onto the internet with your old board ( presuming you can get it up & running) there are security issues with DDR3 tech rigs (like Rowhammer exploits for example) to consider today. Heck, it's even been known that DDR4 can suffer row hammering since 2021 already. With constantly increasing levels of cyber threats multiplying every day its something I would not take lightly.
Not trying to discourage you, just saying that from a broader perspective it might be in your best interests to consider the risks here with bringing this old board back to life in this day & age. :)
5,413 (3.68/day)
Colorado, U.S.A.
So water does not get under if one just soaks, no blowing?
2,294 (1.21/day)
Of course, that's why the same drying method applies regardless. 2 days in direct sunlight (either in a window or outside, weather dictating)with a house fan blowing on it. This is likely overkill but it's what I know works everytime.
5,413 (3.68/day)
Colorado, U.S.A.
Drying will leave deposits, while blowing will remove them; not that those deposits are normally an issue. Or put it another way: the manufacturers don't use drying in sunlight.
I prefer to remove liquids as soon as possible to avoid corrosion.
Outback Bronze
Super Moderator
2,176 (0.44/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
486 (0.58/day)
System Name The Phantom in the Black Tower
Processor AMD Ryzen 7 5800X3D
Motherboard ASRock X570 Pro4 AM4
Cooling AMD Wraith Prism, 5 x Cooler Master Sickleflow 120mm
Memory 64GB Team Vulcan DDR4-3600 CL18 (4×16GB)
Video Card(s) ASRock Radeon RX 7900 XTX Phantom Gaming OC 24GB
Storage WDS500G3X0E (OS), WDS100T2B0C, TM8FP6002T0C101 (x2) and ~40TB of total HDD space
Display(s) Haier 55E5500U 55" 2160p60Hz
Case Ultra U12-40670 Super Tower
Audio Device(s) Logitech Z200
Power Supply EVGA 1000 G2 Supernova 1kW 80+Gold-Certified
Mouse Logitech MK320
Keyboard Logitech MK320
VR HMD None
Software Windows 10 Professional
Benchmark Scores Fire Strike Ultra: 19484 Time Spy Extreme: 11006 Port Royal: 16545 SuperPosition 4K Optimised: 23439
I think that it's probably toast. It's things like this that save me over $100 by making me never want liquid cooling.
Lei
1,143 (0.84/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
People are losing their psu with roach invasion, dead gpu by rat pee and fitting ram sticks right left around. Breaking cpu pins, a fallen vase on a broken monitor, using psu cables on a different brand.
You can use these fittings:
6,881 (1.43/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
We all can create functional art. When you create to many points of failure it loses its luster.
  • Like
Reactions: Lei
2,294 (1.21/day)
Some people enjoy the rush of jumping out of planes. Others prefer watching clips on their phones of people jumping out of planes.
3,602 (1.74/day)
Power Supply Corsair RM750x
Mouse Logitech M575
I use isopropyl alcohol as a drying agent as well however capillary action of the alcohol might be hindered if water is already drawn into and filled in tight spaces so a bit of heat, airflow, and drying time is your friend.
dgianstefani
TPU Proofreader
5,365 (2.03/day)
Swansea, Wales
Benchmark Scores Legendary
More than the same. Any 12th/13th gen cpu will have at least double the single core performance, triple if you're talking about the Raptor Lake K series parts. Then there's the platform, PCIe, USB, NVMe, etc.
An i3 12100 with DDR4 which is the lowest end system worth building today would be better in every respect.
I can appreciate the desire to restore old high end hardware, but it's not practical to run that system even if you got it working. The hardware has unfixable security issues widely known about since zero day patches for newer hardware have been issued for years, and the patchable software security patches written into any modern OS will cripple it even further.
Selling one of your SLI 1080 Ti and the 3930K/RAM would literally give you the cash to buy a modern platform, keeping the rest of your system. SLI doesn't even work these days.
$250 USD and you've got a system that is more than twice as fast in single core and almost twice as fast in multi, while sipping power and supporting AVX2.
It's not even close dude.
486 (0.58/day)
VR HMD None
I suppose that's true. I was just referring to the fact that I have no need for liquid cooling and neither do most people not using an Intel 13th-gen CPU.
Lei
1,143 (0.84/day)
usually in my shirt
Things are getting power hungry.
2- it's better to leak on some low end hardware which doesn't need cooling for the sake of learning curve rather than trial and mishaps on pricy 13th gen
3- it depends where you live too, Sweden, Alaska, or Singapore, Texas, Sahara
I killed my GTX670 by using too much pads on its back. I think I toasted it. Pads insulated it rather than cooling it. I didn't leak on it.
I didn't leak on 1070 either, but I was more confident thinkering and goofing around with it than my next card.
Basically to whom says "I'm not hot enough to use liquid cooling", I'd say "that's exactly where you should start learning and experiment, not when you need it"
Only once I took my CPU block out for an inside wash. I came back from sink and water was all over the floor. I forgot to turn the pump off....
But it was a leak test and PC was off. And my reservoir is outside the case, so all the water was running from the tube unattached from cpu block. The tube was on the floor too.
How could I remove the cpu block while pump was running and then throw the pipe down? :wtf:
I think pump wasn't strong enough to flow the coolant (I have long tubes) so after block was removed, it could flow
2,730 (1.26/day)
PNW, USA
System Name Metalia
Memory 2x32GB DDR4-3600
I've 'saved' at least 2 laptops from 'written-off, post-spill incidents'. (In other words, revived eWaste laptops from obvious liquid damage.)
All I did was take a bottle of 91% Isopropyl Alcohol and a fresh soft-bristle toothbrush to the entire board, focusing on where there was clearly corrosion/residue. Don't be stingy w/ the alcohol, and do this outside or somewhere well-ventilated. (I did not, and later realized that I put myself at great risk for a fire, and got a bit light-headed. Oops)
On your board, since there's an LGA socket involved: I'd safely cover the socket before any 'work' on it.
Also, for the socket and impossible crevasses I'd highly recommend some CRC QD Electronics Cleaner.
Aside note:
An ultrasonic cleaner filled w/ an electronics-compatible solvent like Isopropyl Rubbing Alcohol would be 'ideal'.
Big warning here though when you agitate and warm alcohol, it fumes heavily; those fumes become a fire/(minor) explosion risk! There are ways to mitigate the risk, but unless you're regularly cleaning boards, the complexity and costs aren't really worth it.
If you were to go that route, I'd be doing it outside, away from anything flammable, on a long extension cord.
(I'd also have to be willing to 'write-off' both the ultrasonic cleaner and board before attempting. Meaning, I'd treat this method as a last-resort after manual cleaning)
edit:
My $0.02 on post-waterwash 'drying'
A dehumidifier is a great thing to have around.
Just last week I spilled coffee in my cheapo goodwill-find Red Dragon mech KB. All I did was unplug the keyboard, take it to the kitchen sink, doused it in Dawn and took a big soft-bristle brush to the whole thing. Did about 5 'passes' of scrubbing @ angles and rinsing before a final rinse and setting the thing up on the exhaust of my dehumidifier.
Before the end of the day, I had my keyboard back on my desk, working. (Notice, that at no point did I even remove the keycaps. Top-tier laziness, but it worked out.)
Be aware:
most tap water is full of minerals and other 'ions' that can leave behind high-resistance shorts during drying. If I were to ever attempt a dishwasher-ing or a sink-cleaning of a board, GPU, etc. I'd be rinsing it in distilled water and again in alcohol before leaving to dry.
  • Like
Reactions: Lei
486 (0.58/day)
VR HMD None
Well, if I need to, I'll get a bigger air cooler. ;)
I live in Canada where the temperature can go from -35°C in winter to +35°C in summer.
I never use pads. If I take a card apart and the pads on it are bad, I replace them with actual thermal paste. Pads are inferior to paste and are only used because they're much quicker and easier to apply. They make the manufacturing process less expensive that way.
I built my first PC in 1988 and have been building them ever since. I once bought a Zalman AIO (it was on some stupid sale for less than $40CAD) for my FX-8350. It made a difference of only about 6°C when running Passmark burn-in and had no effect on the PC's performance whatsoever. It certainly wasn't worth the risk of having liquid coolant inside my PC case. The most strenuous thing that I use my PC for is high-end gaming so my CPU never gets overly hot to begin with. Even so, I've used benchmarks like 3DMark, Unigine Superposition, Prime95 and Passmark burn-in. I've never experienced any thermal throttling with air cooling. Sure, if I had a garbage air cooler (the old Intel stock cooler comes to mind), I might have had some throttling but AMD air coolers have always been pretty robust (with the possible exception of the Wraith Stealth).
What's really funny is that I gave my AM3 platform to my mother to upgrade her HTPC so it could use W10. I ended up removing the AMD AM3 box cooler from her PC because it sounds like a jet engine and it reminded me why I kept using the AM2 cooler from my Phenom II X4 940 with it. Knowing what her use-case is, I just threw in the cheapest AM2/3/4/5 cooler that I could get my hands on. It only cost me $13CAD but whenever I check her CPU temperature, it never goes much over 30°C. Here's the cooler:
Arctic Cooling Alpine 23 CO Compact CPU Cooler - $15 (Oh no, it went up by $2! LOL)
It claims to have a 100W TDP limit and the FX-8350's TDP is 125W but my mother only uses her HTPC to browse the net, read emails, play music and watch movies. I'd be surprised if she used more than 60W of CPU power.
Right now, I just use an AMD Wraith Prism on my R7-5800X3D:
It keeps the CPU cool enough at all times to avoid thermal throttling, has nice-looking RGB and it cost me nothing. Kinda hard to beat that, eh?
Hey, we all make mistakes because we're all human. That's another reason why I prefer to limit risk as much as possible. I know that I could very easily make a bone-headed mistake that can cost me dearly. Air cooling works and it doesn't have that risk associated with it.
5,413 (3.68/day)
Colorado, U.S.A.
