Recent rumors hinted at a 32 GB variant of the Radeon RX 9070 XT being in the works, which were quickly dismissed as false information by AMD's Frank Azor. However, reliable sources seem to point to the contrary, stating that a 32 GB variant of the RX 9070 XT, likely dubbed the RX 9070 XTX, is under active development indeed. The source, as pointed out by Wccftech, has a decent track record with AMD-related claims, which sure does add weight to the assertion. Unlike previous XTX-class cards from AMD, which boasted higher clock speeds and core counts, the 9070 XTX is almost certain to feature the same core count as the XT, since the latter already utilizes the full Navi 48 chip - unless, of course, there is an even higher-end chip under wraps.
The VRAM amount seems to indicate that the card will likely be positioned to appease AI enthusiasts. There is also the possibility that the rumored card will be launched under a different branding entirely, although that is not what the post at Chiphell states. Interestingly, Frank Azor did specifically mention that a 32 GB "RX 9070 XT" card is not on the horizon - he did not state that a higher-end XTX card isn't either, which sure does leave room for us to speculate. Benchlife has also chimed in on the matter, claiming that they are aware of AIB partners working on a 32 GB RDNA 4 card with the Navi 48 GPU, which in some ways, confirms the information that came out of Chiphell. The RDNA 4 cards are set to see the light of day soon enough, it seems the wait won't be much longer. However, if the 32 GB card is indeed in the pipeline, it's likely still further down the road.
