Device IDs of Intel's USB 4.0 Host Controller and Strategy to Phase Out Type-A Revealed
3,471 (0.61/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire AMD Radeon RX 7900 XTX Nitro+
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) Cooler Master GP27Q
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
USB 2 should have died a horrible death few years ago.
I'm quite pissed off at motherboards still giving these useless connectors (well, technology, not the physical thing). Noone uses that crap for anything.
Firmware/OS on various industrial/electrical units. Lots of things really if you're in the right field.
Yep, certain manufacturers are stuck in 1973 or something. There no reason whatsoever for COM being used for anything.
6,396 (0.87/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
This only happens if the USB 3.x controller can actually pass it down the chain. This is not always the case, for example this USB 3.1 A-Key to 3.0 converter cable requires a separate connection to a USB 2.0/1.1 controller:
That adapter is intended for use when your case has twin USB 3.0 ports on a single cable, but your motherboard only has a Type-C header. Since the USB 3.0 mobo header supports two ports, but the Type-C cable/header supports only one, the only option is to have two discrete cables to connect to the mobo. The manufacturer could've gone with two type-C headers, but no mobos have that many, so instead they went with a more usable split whereby you get one device running at 3.0 speeds and another running at 2.0 speeds. In the future, as more and more mobos go Type-C only, we will definitely see adapters of the former type.
While this probably will be the case it's not guaranteed by the USB 3.x specc.
Indeed, the most minimal/pure implementation of a USB 3.0-compliant controller will not support 2.0 or 1.1. But in practice there will always be a 2.0/1.1 controller behind the 3.0, or 4.0, or whatever.0 to fall back to.
6,660 (1.58/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Die Type A, die, like, 'nuff already :D
This article is exactly why I continue to rag on any so-called "new" or "2020" cases that do not have C-type on the front I/O, even though almost every mobo made has had at least 1 on the back plane for quite some time now...
And pleeze don't give me that nonsense about how "C connectors cost so much more than A" ..... this is B.friggin.S....
if there were more of them being used/ordered by the mfgr's, the production of the connectors, cables, and peripherals would quickly get ramped up to meet the demand, and the costs would go down very quickly... just like virtually every other piece of tech component in the past 40 years or so :clap:
And >YES< I need moar of them, since I have multiple USB-C devices that I use everyday with my 'puter...
3,471 (0.61/day)
Czech republic
I was very happy when I learned I could order a new type of connections panel for my Fractal case with all USB3 and USB C rather than mixture of 2+3.
Frick
Fishfaced Nincompoop
20,050 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
There absolutely is. It is super easy and dirt cheap to implement and it is easy to program for. Why make things complicated when there's no need?
And to clarify we are talking about RS-232. The COM port is a port.
Do you mean the A ports? I would hate not having those connectors.
EDIT: Oh you mean USB 2.0. I still like to have one or two ports, I have found USB 3.0 to be a bit more sensitive. Some (old) stuff don't work with some USb 3.0 controllers.
8,304 (1.30/day)
Memory Corsair Vengeance RGB 2x8GB 3600MHz
Mouse Logitech G604s
There is when the companies dont want to bother upgrading equipment.
306 (0.05/day)
EU
The thing is that a great many USB devices absolutely don't need more than USB2.0 speed. Now add the insane cost of USB4(+) cables, and their certification, and you are just being ridiculous.
I mean when something can be done for say $6 using a thin cable and instead you use a $25+ device + $100 cable solution you have to say you took a wrong turn somewhere.
I'm OK with USB-c (although I find it actually more fiddly to insert than the old large USB connectors I must say), but I'm not in favor of making everything USB4(+) compliant.
3,471 (0.61/day)
Czech republic
I would just replace USB2 with USB3 on motherboards. There has to be evolution. USB4 looks just like PCIe 4 - just theoretical numbers that aren't good for anything real (ok, next gen NVMe SSDs in the case of PCIe 4, but that's not the usercase for most people...)
671 (0.17/day)
System Name Work in progress
Processor AMD Ryzen 5 3600
Motherboard Asus PRIME B350M-A
Cooling Wraith Stealth Cooler, 4x140mm Noctua NF-A14 FLX 1200RPM Case Fans
Memory Corsair 16GB (2x8GB) CMK16GX4M2A2400C14R DDR4 2400MHz Vengeance LPX DIMM
Video Card(s) GTX 1050 2GB (for now) 3060 12GB on order
Storage Samsung 860 EVO 500GB, Lots of HDD storage
Display(s) 32 inch 4K LG, 55 & 48 inch LG OLED, 40 inch Panasonic LED LCD
Case Cooler Master Silencio S400
Audio Device(s) Sound: LG Monitor Built-in speakers (currently), Mike: Marantz MaZ
Power Supply Corsair CS550M 550W ATX Power Supply, 80+ Gold Certified, Semi-Modular Design
Mouse Logitech M280
Keyboard Logitech Wireless Solar Keyboard K750R (works best in summer)
VR HMD none
Software Microsoft Windows 10 Home 64bit OEM, Captur 1 21
Benchmark Scores Cinebench R20: 3508 (WIP)
You can still get motherboards with DB25F parallel ports.
847 (0.34/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
Does apple even use USB-C? I don't think they do.
All computers since 2016 (2015 MB) and 2018/2020 iPad Pro lol
22,161 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
I meant in mobile, but should've specified. Doesn't matter they have them there too, lol.
141 (0.07/day)
Yep, And only those. I don't know how can people forget such moves by Apple where they just flat out remove all the ports to sell more of their accessories. MB only has USB C, iPad started to use USB C because of their marketing mentions how it works with cameras, extra device attachments, OTG stuff like that & compete with Surface and other Android tabs.
USB A phase out, I think will be only determined by market. USB A has more stronger port than USB C, the latter is too easy to disconnect. Not sure which port has higher wear and tear resistance, from my experience USB A has more resistance. Simply because of it's tight latching and how USB C cables are prone to kinking at the ends. USB C is expensive for these accessory makers I guess that's why no mouse uses it or a Mainstream RGB top KB like K95 use it either, and all of them use only USB 2.0 spec even DACs which are entry level use micro USB. Plus many of the phones still ship the same cables. It's robust and works. USB IF people are too stupid with their naming and standarization now it hit another peak.
Mobos still have PS/2 for those benchers and some of them allow Win7 installs too..
1,207 (0.70/day)
They don't because the boards still support USB 2/1.1, see the problem ? Yes, you have to move on, if manufactures start releasing boards with just USB 3 you'll see devices supporting only USB 3 as well.
But why?
If it ain't broken, why fix it?
Do we really need "progress" for the sake of itself? Or is there some specific benefit those HIDs could bring using that extra bandwidth?
306 (0.05/day)
EU
But why?
Does solve some confusion I suppose, at some point it becomes annoying to know if you have the right USB port if there are many kinds.
Problem is the chips having to dedicate a lot of bandwidth, and the solution would be 'flex USB', where the port would detect it's a USB2.0 device and then switch over to USB2 and free that excess bandwidth to other uses. Maybe put a small LED on it to indicate so, red for USB2 and blue for USB3 etcetera. (people need to be able to source issues.)
You could do that on the fly or on boot, depending on what's best for system designers.
To the manufacturers: Feel free to use that idea, I relinquish the rights for the good of the user.
