qubit
Overclocked quantum bit
- Dec 6, 2007
- 17,865 (2.82/day)
- Quantum Well UK
System Name | Quantumville™ |
Processor | Intel Core i7-2700K @ 4GHz |
Motherboard | Asus P8Z68-V PRO/GEN3 |
Cooling | Noctua NH-D14 |
Memory | 16GB (2 x 8GB Corsair Vengeance Black DDR3 PC3-12800 C9 1600MHz) |
Video Card(s) | MSI RTX 2080 SUPER Gaming X Trio |
Storage | Samsung 850 Pro 256GB | WD Black 4TB | WD Blue 6TB |
Display(s) | ASUS ROG Strix XG27UQR (4K, 144Hz, G-SYNC compatible) | Asus MG28UQ (4K, 60Hz, FreeSync compatible) |
Case | Cooler Master HAF 922 |
Audio Device(s) | Creative Sound Blaster X-Fi Fatal1ty PCIe |
Power Supply | Corsair AX1600i |
Mouse | Microsoft Intellimouse Pro - Black Shadow |
Keyboard | Yes |
Software | Windows 10 Pro 64-bit |
^ you're correct on the wattages.
putting what i said in simpler terms:
drawing more than 75W from the slot wont magically turn the slot off, or anything else like that... if the card has no internal mechanism to deal with the power draw, the wiring feeding the slot will just start to overheat, and bad things can happen.
You know, it's really beginning to look like we need an uprated power spec for ATX & PCI-E power delivery. I'm sure we're hitting the same brick wall that CPUs did a few years ago, which is why these latest gen cards are getting held back in the performance they deliver and are not really massively faster than the ones that they replace. I'll bet the new Cayman GPU will have a lot of the same power and heat issues as nvidia's Fermi GPU.
I'm sure that if a 600W power budget (with appropriate cooling) was available, some excellent performance gains could be achieved, like double or more performance and extra rendering features.
