Do i lose power / rpm when connecting a fan splitter to motherboard ? ( 1 plug to 4 fans )
13,360 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
is it bad to put a fan above the gpu against the case airflow maybe?
Probably not a good idea to go against the airflow. It may help the GPU a little but it may also hinder cooling for the CPU, RAM, chipset, VRMs and other heat sensitive devices.
You could try it, monitor your other devices and see what happens. But if me, I would not do it. Good case flow typically helps the CPU too.
287 (0.66/day)
System Name SYSTEM
Processor RYZEN 7 5700X
Motherboard TUF B550M GAMING PLUS
Cooling AG620 CPU COOLER
Memory 16GB RAM DUAL CHANNEL 3200MHZ STOCK
Video Card(s) RTX 4070 GIGABYTE 12GB WINDFORCE
Storage 1TB HDD 256GB SSD
Display(s) LG ULTRAGEAR 144HZ
Case AIGO DARK FLASH
Audio Device(s) MOTHERBOARD AUDIO
Power Supply XPG ADATA PYLON 650W
Mouse REDRAGON COBRA M711 V2
Software WINDOWS 11
how would you suggest ? do you think i should try first 2 top exhaust or 2 bottom intake to start ? mainly to help ssd temps
thanks
13,360 (1.99/day)
Nebraska, USA
Mouse Logitech M190
I prefer front to back air flow or bottom to top. If using top too, have it exhaust unless you have a radiator up top too than needs intake.
You want a slight positive or over-pressure. This means slightly more intake than you have exhaust. With a slight positive pressure, the excess pressure will try to escape out the cracks, case seams and ports. That's a good thing because it helps keep the case interior clean of heat-trapping dust and it also prevents dust from getting jammed into the ports and (if you have one) DVD/Blue-ray tray.
I say slight because too much pressure can result in stagnant pockets.
Every case is setup so you will just need to try different configurations while monitoring your temps to see what is best.
One last thing - it is critical to keep your electronics properly cooled. But it is NOT necessary to keep it as cool as possible. A CPU running at 35°C, for example, will not be more stable, perform better or have a longer life expectancy than if running at 30°C.
287 (0.66/day)
System Name SYSTEM
Software WINDOWS 11
i don´t know if it is worth adding more fans anyway , it only peaks 72 degrees at extreme benchmark conditions
while gaming it reaches about 55 to 60 degrees averages
i did not want to put it hanging on gpu tbh
3,343 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Hey guys , this is a old pic but it is the same as i use now
I´m wondering , is it bad to put a fan above the gpu against the case airflow maybe?
when doing 9 loops with 64gb , it peaks at 72 degrees ( the 66 degrees were at 1gb data)
how can i accurately help the temps without hindering airflow ? sorry it is because i´m bit tired of benchmarking , assembling PCs etc ...]
should it put it below , bottom or left / right side above the gpu ?
thanks
Oh you have some space constraints from the CPU air cooler. You could lay down a thin 12v PWM based centrifugal fan on top of your GPU and point the exhaust at your SSD.
Small USB powered versions of these fans also exist if that's easier
287 (0.66/day)
System Name SYSTEM
Software WINDOWS 11
Small USB versions of these fans also exist if that's easier View attachment 370289
too bad i already bought a 120mm normal case fan
i wanted to do it the conventional way if possible ( i think this type of fan is not even possible to buy in my country lol))
3,343 (1.69/day)
Mouse Logitech M575
If your desperate to cool your SSD perhaps make some cardboard duct work to channel part of the middle fan air flow to your SSD and fill the top position with your new fan. Problem solved.
