Do you re-use the power (supply) cable?
  • Total voters
    45
  • Poll closed .
8,253 (1.18/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
i have loads of kettle plugs i just leave the old one connected and add the new one to by stash..
trog
194 (0.07/day)
The one time I remember replacing a power cable was when the cable that I was currently using melted and kind of caught fire. Luckily I was around to prevent a house fire.
I have a ton of these cables around, but as luck would have it I had apparently blindly chosen to use the thinnest, crappiest one of the bunch, paying absolutely no attention to what it looked like. Upon later investigation it seemed like the inside contacts on the cable were bad, so that's most likely what caused it to burn.
I always reuse power cords, just after that incident I pay attention to what they actually look like before plugging them in :D
2,259 (1.00/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
i reuse if its in good order ive 3 meter one ive been using through 4 or 5 of my own builds its a gray thick one where my sockets are is good 7ft away from my gaming rigg and i dont like using multy socket EX when powering the rigg.
freeagent
9,684 (4.14/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Yeah.. the main reason I don't use the new ones is because they feel like they are dipped in plastic. Just so cheap. And if they cheaped out on the jacket, what else did they cheap out on? How much of that strand is really copper and how much is aluminum lol.. probably no alu, but still.. feels so cheap.
13,651 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
This is really an odd question - but not really.
It really is not the age that matters but the condition. And for sure, the condition may depend on the quality when new.
There are some really cheap cables I won't use, even if brand new. Then I have some that are at least 20 years old I won't hesitate to keep using.
While the size of the conductors (wires inside) matter, it is really the insulation that matters most. Is it still flexible? Or stiff? Is it cracked and/or brittle - especially where it enters the connector? Has it been exposed to the weather or sun?
If in doubt, throw it out.
I didn't and won't take the survey because the only options given are absolute, and too limited.
I would pick, "None of the above" or "Depends on condition".
2,097 (0.52/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
Depending on the cable but some might be better quality even if they are older than the cheap stuff made today.
8,253 (1.18/day)
back in the day these things were made to mostly power 3 KW electric kettles.. based in this principle old ones are probably better than new ones..
trog
474 (0.30/day)
System Name Dusty
Processor 5900x
Motherboard MSI B550 Tomahawk
Memory Corsair Vengence LPX 32GB
Video Card(s) MSI RTX 3070 Gaming X
Storage yes
Case Fractal Design Define R6
Power Supply EVGA SuperNOVA 750w
VR HMD Oculus CV1
Pretty sure I automatically rotate to a new one. Whenever I buy something that comes with a new cord I generally use the new one and discard the old one. Simply because I do not need any more cables in my boxes.
We have recycle boxes for cables at work so I just bring them with me there and throw them in the pile, at least they get used to something else instead of sitting at home with me for 20 years in a ever growing pile of cables.
I never had the though of not using a old cable that looked to be in good condition though, never really crossed my mind.
13,651 (2.01/day)
Nebraska, USA
Mouse Logitech M190
I'm the opposite. I use the old because it is already straightened out and ready to go. Then I toss the new one, because it is already in a nice, compact, tied up bundle, in a storage bin labeled "AC Power Cables". When the bin gets full, they get recycled. We have a nice electronics recycling center in my area that pays me for the copper while keeping it (and other hazardous waste) out of the landfills. A win-win.
40 (0.02/day)
Hello !! I know this is an old thread, but I want to ask something, if anyone knows.
How many matting cycles those 3 pin ac power cables have ?? I've searched everywhere but I couldn't find an answer.
I have a seasonic gx 750 with the original ac cable for one year now. I unplugged an plugged in again like 6-7 times and I don't want to damage the socket. If it will become loose in a future and a new cable fix it, that's ok, but don't want to ruin the psu.
Are the matting cycles more than 30-40 for example ?? Does anyone knows ??
Can the psu's power socket got damage from that reason, in first place ??
Thanks in advance !!
508 (0.26/day)
I use the thickest cable and that seems to be one of the older ones, most new PSU cables are thin compared to it.
Agreed. Again this is what I have seen as well as companies are cutting corners everywhere. If the cable is not broken, if it was me I would use it.
ir_cow
4,726 (0.79/day)
USA
Don't reuse cables! the pin configuration are often different on the PSU end even if it fits. Companies have gotten better of either leaving it the same for multiple generations or tell customers its okay. But if no information exist, besides doing a voltage test yourself, don't reuse them.
I killed a SATA drive using resusing Seasonic Gold on Seasonic plat.
Solaris17
Super Dainty Moderator
27,226 (3.82/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
He's talking about the one from the wall to the PSU.
As for me, If my new PSU comes with a thicket gauge I switch to it. I continue to use that one unless a larger one comes along.
807 (0.67/day)
People's Republic of Banania
Processor Threadripper 3955WX
Motherboard M12SWA-TF
Cooling Arctic Freezer 4U SP3
Memory G.Skill Trident Z DDR4-3733 (2x8GB)
Video Card(s) 5700XT + 3x RX 590
Storage A lot
Display(s) ViewSonic G225fB
Case Corsair 760T
Audio Device(s) Sound Blaster Z SE
Power Supply be quiet! DPP12 1500W
Keyboard IBM F122
Software 10 LTSC
30-40? nah, way more than that
The inlet's pins are pretty solid and will only damage if you exceed its current rating, which isn't possible with PC PSUs. If the cable is good then the coupler will have stiff contacts that won't become loose, though cheap cables often have bad contacts that are too loose or small to mate with some inlets, they're not built to standard properly. I have a cable that's like that and it's terrible quality.
I also have a death cable that comes with 3 coupler pins but instead of leaving the earth pin without a wire they've connected it to the neutral side of the coupler in question. Thing is, the AC plug can fit in two ways so you don't know which of the pins will be hitting the live contact, so there's a 50% chance the case becomes live, if you touch it barefoot RIP. Whoever thought it was a good idea is beyond dumb.
If there's no earthing just leave the pin alone dude.
I've used the same PSU cable for 10+ years until now, because it won't fit my new PSU that has a C20 inlet. I can still use it for a lot more things though. If I repair something it's cheaper to use a C17/18 pair rather than its earthed counterpart, as there's no earthing where I live, same goes if I repair a PSU, I have a box of inlets and cables for repairs.
40 (0.02/day)
@ir_cow
I don't talk about reusing a cable, I'm talking about how many times can i unplug and plug in again the main AC power cord that connects the psu to the wall socket before damaging (if it can) the psu socket.
@caroline!
Thank you for the info. I'm not sure if i understood your second paragraph. I live in Greece (EU) and we have different plugs. Here some photos I've found on google pic1 pic2 pic3
The pic3 is the power strip that i use now. The wall socket, the power strip and the psu cable are all earthed
The cable seems to have good quality and its not loose in any way, its very stiff.
If the the matting cycles are more than 40, for example i will say 100 or 150, then i'm fine !! 10-15 plugs-unplugs per year, for 10 years warranty !!
ir_cow
4,726 (0.79/day)
USA
Oh if its the power cable to the PSU, usually not a problem. Just have the right Amp rating on it.
johnspack
Here For Good!
6,049 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
Think I've used one or 2 that were a good 30 years old. I save everything! God I've been using computers a long time.....
AsRock
TPU addict
19,174 (2.98/day)
UK\USA
Cooling D15
Never replaced them, in fact all mine are in their original boxes haha, the ones i use one is a angled which works great with the torrent case and the other is even old but is about 2-3 thicker much better quality than any new ones of today.
NAD AV's has really thick cables and believe that's were most of mine came from, real heavy duty ones.
freeagent
9,684 (4.14/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
The PSU cable I am using right now is actually from a ~2000ish 20" Sony Trinitron Wega type monitor. God I loved that thing. I would probably be using it today lol..
85lbs of visual pleasure.. and the power cable is mighty girthy.. it will drive my Monitor Audio sub no problem.
The screen did the fade to white and it was sadness :cry:
1,233 (0.21/day)
Yeah, for the past 2 decades I've been using a few thickass 14AWG ones that are probably older than I am. Got them from a box of cables I purchased in a garage sale back in the early 2000s. I reckon the cables are from the mid 1980s.
13,651 (2.01/day)
Nebraska, USA
Mouse Logitech M190
I have found in most cases, the newer the cable, the more cheaply it is made. :( So almost all immediately end up in my recycle cables bin.
If, when inserted, it doesn't wiggle in the sockets, and if there are no cuts or cracks (or bite marks) in the insulation, it is completely serviceable - assuming it is no smaller than 18AWG (though I prefer the larger 16AWG).
5,299 (3.73/day)
Colorado, U.S.A.
Software Windows 11 Home
I rather like flexible cables, not because they are thin but for the soft plastic used; so I tend to stick with using those, no matter how old so long as not damaged.
6,400 (1.55/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
I have & am using some power cords from back in the DOS days, and have an ever-growing collection of new(er) ones in my parts box too, hehehe :)
Once I collect a few moar, I may just strip most them down & sell the wire parts to the metal recycling place outside of town, at least that way, someone else can start collecting them !
807 (0.67/day)
Storage A lot
Case Corsair 760T
Keyboard IBM F122
Software 10 LTSC
@ir_cow
@caroline!
Only one of the images loads but here's what we use. Only the finest commie tech, and the small one is European, think they use them for small appliances there.
Since there's no ground it can be plugged in two ways so in the PSU side you don't know which of the contacts in the coupler becomes live, thus if you short any pin to the ground there's a chance the PSU, case and everything becomes live and shocks you.
5,299 (3.73/day)
Colorado, U.S.A.
I believe the power supply transformer means the output floats.
