Does DLSS draw more power?
960 (0.52/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
When I activate DLSS option in many games, the fps increases substantially. Is that because DLSS draw more power or it decrease the gpu calculation intensity? Does it increase the load on GPU processor? Can someone clarify please?
1,138 (1.68/day)
Processor Ryzen 7800x3d
Motherboard Asus B650e-F Strix
Cooling Corsair H150i Pro
Memory Gskill 32gb 6000 mhz cl30
Video Card(s) RTX 4090 Gaming OC
Storage Samsung 980 pro 2tb, Samsung 860 evo 500gb, Samsung 850 evo 1tb, Samsung 860 evo 4tb
Display(s) Acer XB321HK
Case Coolermaster Cosmos 2
Audio Device(s) Creative SB X-Fi 5.1 Pro + Logitech Z560
Power Supply Corsair AX1200i
Mouse Logitech G700s
Keyboard Logitech G710+
Software Win10 pro
When I activate DLSS option in many games, the fps increases substantially. Is that because DLSS draw more power or it decrease the gpu calculation intensity? Does it increase the load on GPU processor? Can someone clariy please?
It lowers the render resolution - that's it.
960 (0.52/day)
Turkey
System Name MSI-MEG
Memory 32 GB
Do I get better picture quality in contrast to Anti aliasing?
to keep it simple, Is it good or bad??
1,138 (1.68/day)
Software Win10 pro
Do I get more quality picture in contrast to Anti aliasing?
You're comparing apples to oranges.
A better question is : Does dlss at 100% render res (dlaa) look better than dlss at 66% render res (dlss quality) ? Yes, dlaa looks better than dlss quality.
7,572 (3.24/day)
California
System Name His & Hers
Storage lots of SSD.
You have a 3080 why not just try it yourself. It's a very subjective thing that comes down to which is worse to you the downsides of DLSS or the downsides of TAA.
Typically power draw is the same or margin of error assuming the gpu is at 100% load.
freeagent
9,564 (4.10/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
7,572 (3.24/day)
California
The thing is anyone who needs the extra performance is gonna use DLSS and anyone who doesn't is going to use DLAA there really is no reason if you have a GeForce card to stick with TAA anymore vs either regardless.
960 (0.52/day)
Turkey
System Name MSI-MEG
Memory 32 GB
I actually did but could not find a difference in consuming power. Don't know how this dlss tech gives me more fps though.
7,572 (3.24/day)
California
DLAA is going to give you slightly lower performance but look better
DLSS Q is going to render the game at 66% and then upscale it to 100% typically giving you 20-30% more performance assuming you are gpu limited.
3,796 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
If you running uncapped frame rate I expect power to be very similar, might be bit higher due to the DLSS processing.
If capped framerate e.g. 60fps, power draw should drop noticeably. If using frame gen, it can lower load on CPU too.
DLAA is probably the best modern way to deal with trash TAA at the moment.
