Does fanless motherboards have faulty design?
899 (0.55/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
Hello everyone!
Since I believe a sturdy and a cool motherboard is the most important part of the system, I've decided to buy the MSI Meg x570s ace max, the second most expensive motherboard for MSI only after their flagship Godlike.
But I carefully monitor the chipset temperature, and while the system is idle, the temp is 56C at minimum, if I move big files from usb to hdd and vice versa, the temp easily escalates to 70C. My old tuf x570 chipset was much lower thanks to its fan.
So do you think this fanless x570 designs are faulty? Isn't the idle temp of 60C too much?
11,878 (2.27/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Hello everyone!
Not really, most likely it Was tested plus chips are fine upto 95°C usually so your not beyond that and finally you report no issues besides your perspective on temperature, if it's not broken or giving issues I wouldn't worry.
Mines actively cooled by a small ass fan and does see similar temperature levels anyway.
420 (0.12/day)
System Name Blackbelt 2
Processor AMD FX 8350
Motherboard ASUS M5A99FX PRO R 2.0
Cooling Cooler Master Hyper TX3 evo
Memory 8GB Corsair Value Select DDR3
Video Card(s) ASUS R7260X DC2OC 2GB
Storage INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM
Display(s) DELL ST 2240L
Case Cooler Master Elite 311
Power Supply CORSAIR VS Series 550W
Software Windows 7 Ultimate 64 Bit
Benchmark Scores 3DMark 11 6532
Or if it bothers you too much, you can try fixing some stick-on ram heatsinks onto the hot components...i have a cheapo asus prime a320mk whose vrms temps shoot upto 67 C at idle and upto 79-83 C at load...i stuck some ram sinks to the vrms and the temps dropped by 3 to 5 C at load...
just be careful you dont bridge any exposed components and short the motherboard..
And you can try directing a fan towards your vrm heatsink if your motherboard already has a heatsink on the board...
899 (0.55/day)
Turkey
System Name MSI-MEG
Memory 32 GB
That's a very, very nice work! But my problem is not about VRMs, but the passive cooled chipset
420 (0.12/day)
All the same, you can get stick-on chipset heatsinks too like these...some of them even come with 40mm fans..
You can also install gpu heatsinks onto you motherboard chipset if you have an old or dead graphics card..
you will have search a bit for the proper size and fit.....i am sure you will be able to do it easily..
12,481 (1.90/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
IMO, I would much rather have a fanless motherboard. I hate fan noise and the smaller the fan, the more racket they tend to make. A quality motherboard will have quality heatsinks.
So then it is up to you, the user, to put that motherboard in a quality case that provides sufficient cooling to extract the heat radiated off those heatsinks. And of course, it is up to you, the user, to properly configure that case cooling to ensure there an adequate "flow" of cool air through the case.
So I say before you even think of changing out heatsinks, you look at your case cooling. The folks at MSI are not stupid. They would not put inadequate heatsinks on their boards.
58 (0.05/day)
Processor Core 2 Quad Q9650
Motherboard XFX nForce 780i SLI
Cooling Zalman
Memory 4x1GB Ballistix DDR2-1066
Video Card(s) 2x Quadro FX 4800
Storage 2x WD RE3 500GB RAID 0
Display(s) Apple Cinema HD
Case Chieftec Dragon
Audio Device(s) Sound Blaster X-Fi
Power Supply Corsair 500W
They only started putting fans on most motherboards in the past what like 10 years? Super high end and server boards had em but out of the 13 motherboards I own, only 1 has fans. I often put heatsinks on bare chipsets, since some of the older ones don't even have cooling on the northbridge/southbridge but I've never needed active cooling on a chipset - cases with enough airflow and fans can cool the small heatsinks just fine
1,352 (0.27/day)
[Formerly] Khartoum, Sudan.
System Name 192.168.1.1~192.168.1.100
Processor AMD Ryzen5 5600G.
Motherboard Gigabyte B550m DS3H.
Cooling AMD Wraith Stealth.
Memory 16GB Crucial DDR4.
Video Card(s) Gigabyte GTX 1080 OC (Underclocked, underpowered).
Storage Samsung 980 NVME 500GB && Assortment of SSDs.
Display(s) ViewSonic VA2406-MH 75Hz
Case Bitfenix Nova Midi
Audio Device(s) On-Board.
Power Supply SeaSonic CORE GM-650.
Mouse Logitech G300s
Keyboard Kingston HyperX Alloy FPS.
VR HMD A pair of OP spectacles.
Software Ubuntu 24.04 LTS.
Benchmark Scores Me no know English. What bench mean? Bench like one sit on?
The rule of thumb regarding motherboard temperature readings: Ignore them.
There are ways through which you could slash that figure by a few digits, but you'd just be nitpicking. These chips can survive much worse than this.
And passive cooled chipsets is the norm these days. Active cooling is the exception (and I dare say a gimmick. VRM coolers notwithstanding).
12,481 (1.90/day)
Nebraska, USA
Mouse Logitech M190
Not even "most"! And it was long before that too.
Way WAY back, motherboards used to come with fans typically on the chipset's Northbridge. They typically were thin and tiny 40mm fans that had to spin at 100mph to do any good. This high speed spinning resulted in very annoying high-pitch fan noise. It also resulted in the fan's bearings failing prematurely - often. :(
So motherboard makers starting using bigger and better passive (no fan) heatsinks. Plus chipsets started getting integrated and more energy efficient (thus producing less heat).
And for sure, the vast majority of motherboards these days do not have fans. Instead, most motherboards rely, as they should (IMO), on quality, efficient heatsinks and quality case cooling.
I will also note there are a couple reasons motherboard designers cluster heat sensitive and heat generating devices around the CPU socket. One is for shorter distances which means faster speeds. But it also means those devices can take advantage of the air turbulence caused by the CPUs cooling fan.
Edit comment: fixed a couple typos.
INSTG8R
Vanguard Beta Tester
7,975 (1.11/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
It just runs hot, period. Even with my fan set to the “Max” I can choose (Performance) it still hits 61C sometimes higher. Literally the hottest thing in my case after my GPU…
12,481 (1.90/day)
Nebraska, USA
Mouse Logitech M190
I don't know about "sometimes higher" but 61°C is not "hot".
INSTG8R
7,975 (1.11/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
1,065 (0.31/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
bill beat me to it. i've burn my fingers on north bridges all the time hello. nvidia!! yes nvida use to make chipsets!. its been since x570, which tripled the TDP from x470 (~5w vs ~15w) that they started to appear again. the X570S has ~10watts which is suppose to help keep the cooling passive as before.
no, not really. i myself has been surprised how much energy (power/heat) it takes to push data around a bus. but to be sure i tried googling AMD's specs and couldn't find anything. :banghead:
5,471 (0.77/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Logitech G613
INSTG8R
7,975 (1.11/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
40,435 (6.51/day)
Erm some Skt A and 478 boards had them
Keullo-e
S.T.A.R.S.
11,496 (2.73/day)
Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550M Aorus Elite
Cooling Alphacool Eisbaer w/ 2x 240 rads
Memory 32GB Kingston HyperX Fury DDR4-3466
Video Card(s) Asus GeForce RTX 3080 TUF w/ EKWB FC
Storage ~4TB SSDs + 6TB external HDDs
Display(s) Acer 27" 4K120 + Lenovo 32" 4K60
Case Define Mini C
Audio Device(s) Asus TUF H3 Wireless
Mouse MX518 og
VR HMD Oculus Rift CV1
Benchmark Scores It runs Crysis remastered at 4K
Back in the day having a small and annoying chipset fan was in the majority of boards. Many probably remembers the chipset cooler from DFI Lanparty NF4 boards for example?
Core 2 era boards had much more innovation what comes to motherboard cooling than modern boards:
286 (0.17/day)
Hello everyone!
From what I've read, even X570 boards with a fan don't seem to kick-in properly until around 60C, so if it has a max of around 70 I'd say you're fine. What are the gaming temps like?
I could be wrong, but I've never seen detailed chipset specs published publicly from AMD, like Intel do, but I assume MSI would have them when they designed the board.
40,435 (6.51/day)
Yup when MSI was a badass contender, same with Gigabyte...
12,481 (1.90/day)
Nebraska, USA
Mouse Logitech M190
I don't know about the majority - but certainly many.
It should also be noted that "back in the day", "large" case fans were 120mm - most were just 80mm, some only 60mm. And many cases had just one case fan in back for cooling - along with whatever extra air flow the PSU fan could provide. In fact, some cases didn't even have one case fan. They depended entirely on the PSU fan.
Keullo-e
S.T.A.R.S.
11,496 (2.73/day)
Finland
Case Define Mini C
Mouse MX518 og
Yeah, 80mm fans were common and there was usually just one intake and one exhaust. And yeah, 120mm fans started getting more common in the mid-2000s.
58 (0.05/day)
Cooling Zalman
12,481 (1.90/day)
Nebraska, USA
Mouse Logitech M190
You did say "most" but that still is not true. Most motherboards made in the last 10 years do NOT have fans, only large (compared to older boards) heatsinks.
You also said "only" which is not true either since fans were common many, many years prior to that.
Keullo-e
S.T.A.R.S.
11,496 (2.73/day)
Finland
Case Define Mini C
Mouse MX518 og
For consumer boards excluding AM4, I remember only some X79/X99 boards having chipset fans for the last 10 years and they're HEDT, not your average gaming platforms.
11,878 (2.27/day)
Manchester uk
VR HMD Oculus rift
While I do agree with you on the whole regarding motherboard small fans, they were at one point a necessity as you know but modern ones from my present example have improved, I do run a load and temp with moderate fan curve's but under load or idle they're not noticeable.
I have a boards with no such fan's too and it's fine too.
