Bruhimnoob
18 (0.01/day)
any body has a pack of impulse responses, i used hesuvi with equaliser apo and dts dch drivers and senheiser impulse resonse(.irs) by renaming it to .wav and it works,the sound quality has significantly improved
3,122 (1.96/day)
United Kingdom
You should also be able to do that with the DTS:X .bin files right?
57 (0.04/day)
hmm i try turn off dts x ultra but cant turn on again
edit:
fixed with reinstall
@Ferather yes my laptop is acer
If the DTX Ultra says its offline, just minimize the Window to task bar. Then make it big again and it should say its online. I had the same problem, seems to be just an visual bug.
3,122 (1.96/day)
United Kingdom
He seems to have an off bug, I did notice this on a friends PC but could not replicate it. They fixed it with app uninstall, restart, re-install.
57 (0.04/day)
Drivers.... sometimes just weird...
Ok, I was off for two days and you changed so much^^
Do I have to pay attention to something special when installing your current driver version? or as usual, cleanly uninstall and then the new driver? want to test them now.
3,122 (1.96/day)
United Kingdom
I recommend removing, but you can update. The mini update pack is just preset updates, DTS DSP and SRS options, they will be in the next main update.
56 (0.02/day)
Indonesia
System Name Acer Aspire E5-475G
Processor Intel(R) Core(TM) i5-7200U @ 2.50GHz
Video Card(s) NVIDIA GeForce 940MX,Intel HD Graphics 620
Audio Device(s) Onboard Realtek ALC255
Software Windows 11 Pro Insider Preview
enable for dts:x ultra support headset and show playback device in realtek audio console
3,122 (1.96/day)
United Kingdom
Aha thanks, @Bryan Ü, some info for you. I will try this and see if I can use it in the .dat file.
Edit: All options but option 8 of image 1 is already enabled, I just enable 8?
56 (0.02/day)
Indonesia
i think is oem lock so few laptop disable this
edit u must enable all
57 (0.04/day)
Ahhh I see.
When do you have the next major update planned? then I'll wait until then.
3,122 (1.96/day)
United Kingdom
@andreaspujihar, so option 8, the rest is already on, thankyou. I will pass this onto anyone with that issue in the future. :)
@Kabal81, when ever Realtek release their next driver, which could be tomorrow or in a few weeks.
Edit: The releases come with DTS files, sometimes they are updated.
342 (0.18/day)
PM!
56 (0.02/day)
Indonesia
update i get bsod enable support dts need reinstall driver
how to enable dts x ultra on headphone endpoint??
edit i try uninstall dts ultra and restart dts apo4 and show headphone
342 (0.18/day)
I had to use Ferather's included version of Sound Unbound in MediaFire repo. Turn off auto updates for that app. Then i have to manually reinstall it each and every time I log in to get DTS X Ultra spatial mode.
56 (0.02/day)
Indonesia
hehehehehe i already block update
2 (0.00/day)
hi,
I always need to recheck dts and other thing in the "RTK Device Tool" why ?
windows 10 20H2 & motherboard msi b450 gaming plus with alc892 ,it always autoinstall some stuff related to A-volute/nahimic with any driver compatible maybe it's the issue ?
(HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462CB86&REV_1003)
342 (0.18/day)
hi,
Have you turned off auto-updates?
nonick
17 (0.01/day)
@Ferather Hi, maybe you know why with these drivers output sound (speaker, headphone/earbuds) goes through mic input (others hearing what they saying through me)? :D
I have these problems with Alan drivers but only if I not used headphone/earbuds output device.
3,122 (1.96/day)
United Kingdom
@andreaspujihar, When I enabled separate headphones, I just restarted the computer and it worked as it should thereafter. Might be because you are tweaking it to work.
@roflmaooo, Should already be enabled unless you deleted the .dat file, the left text should be flashing red, otherwise you press save after changes.
@nonick, Odd, what ALC, can you please post a screenshot of 'System Information' > Components > Sound Device.
I also just put out another update, its a roll-up of previous changes plus new defaults for APO3 and APO4.
nonick
17 (0.01/day)
Now i reinstall default drivers, because cant use discord normally. With default drivers than I set default communication device to headphone problem solved.
I dont remember if I tried on your driver ..
3,122 (1.96/day)
United Kingdom
ALC887 rev. 1003, hmm try ALT1 driver rather than main.
Dim
6 (0.00/day)
Hello, wonderfull work! I ve an ASUS Rog Strix e gaming X570 with S1220A, I ve installed ALT 2, and have no problem! post 1 is perfect!
I have 3 questions:
1 Where can I find the file to have the DTS X Ultra? see attached file. EDIT: Found on microsoft Store!
2 how can I have speaker and headphone separately?, I don t find where I can enable it... I have just speaker
3 And to finish, where do I put the folder DTS Ultra Presets?
Thanks a lot!!
    .jpg
56 (0.02/day)
Indonesia
I have 3 questions:
Thanks a lot!!
2. check #163 but dont enable dts
Hmm I think all dts and srs must separately headphone and speaker
But in dolby atmos u don't need separately except hda
Dim
6 (0.00/day)
Another question: How to use paragon? I ve downloaded the ISO but I don t know what to do with it... I put it on USB and start on it to backup windows?
Thanks for your answer :)
