DTS Sound Unbound
3,029 (2.08/day)
United Kingdom
I enabled AEQ earlier, and set gain at 4, so far it seems better for multichannel (APO4-Off preset), still testing it.
Updated presets:
The Ferather one will be in the next update.
Results:
AEQ - Very good, but can cause decay with low quality audio.
SFX, MFX as 'ANY' instead of 'Stereo', same as above.
Best results:
MBHL Enable - 1
MBHL Anticlip Enable - 1
MBHL Anticlip Level - 4
MBHL Distortion Preventable - 8
945 (0.53/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
Will it work on my Asus tuf Mobo which comes with DTS custom (lite version)?
3,029 (2.08/day)
United Kingdom
It will override your Custom. Try this version, it will bolt onto your custom. However for a custom, you will need to take note of the FX keys being used, and their position.
Once you do the .reg files, you will then need to re-enter these keys in order to make your custom work as intended, as well as DTS:X.
You might need to tinker slightly, as 'some' FX's need to be first at some point for detection.
This version will work also with Windows drivers, as well as AMD and so on.
{A515262A-68B3-441A-A310-0D145362EE87} (Interactive), must always be last on EFX (final out).
89 (0.04/day)
How to modify acer xml to asus xml
acer xml cannot be used
3,029 (2.08/day)
United Kingdom
That should not be the case, it's likely you have an issue elsewhere, still you can try changing it, please note, most OEM presets are not fully optimized:
Place the preset into the 'WIN10\APO4' folder, then run the install.
