EK Releases EK-Leak Tester - a Superior Leak Testing Solution
1,720 (0.32/day)
Steel City, UK
If you have extension you can use this as compression test for your car. Nice EK
7,595 (1.48/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
What's with the Imperial vs Metric trolling? Are we 13?
1,487 (0.32/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
run the pump without the board being powered on, no harm no foul. Detect a leaky, shout it off start ova. No power to the board it can get wet all day long and work fine.
625 (0.24/day)
I'm pretty sure you could make one these from parts at a hardware store for $10.
Then do it. You can also build the entire watercooling loop, rad, block and all from junk yard parts. Fantastic. Pat yourself on the back.
19,371 (3.54/day)
Bunch of Muppets with lack of for sight.
Go look at your wet fitting on your boiler they all have O rings but also a restraining clip because the pipework is under pressure 2 to 3 bar.
I wonder why they add restraining clips. Maybe because it would be stupid to rely on only the pressure generated from the O ring thumb tight threads.
This is a bad idea and anyone who would use such a thing needs to pull out all the restraining clips from their boiler.
Must not need them.View attachment 128439
It amazes me people are actually considering buying this (tool)
Its a risk that isn't worth taking.
If there is a leak the fluid will lubricate the O ring increasing the risk it sliding off the pipe.
Has to be the worst idea i have seen in a long long time and yet people are praising the idea.
Just mind boggling to me.
If you do use this be sure your loop is empty..................
What are you going on about? You dont think this device was tested to work with their products as they described?
If these posts are legit, sounds like you're a fear monger at best. You arent even posting pics of ek parts, but random O rings on....????
The bottom line is if you use this properly, it will work as described. If you put too much pressure through it, your doomsday scenario could happen.
5,004 (0.81/day)
NC, USA
System Name Cosmos F1000
Processor Ryzen 9 7950X3D
Motherboard MSI PRO B650-S WIFI AM5
Cooling Corsair H100x, Panaflo's on case
Memory G.Skill DDR5 Trident 64GB (32GBx2)
Video Card(s) MSI Gaming Radeon RX 7900 XTX 24GB GDDR6
Storage 4TB Firecuda M.2 2280
Display(s) 32" OLED 4k 240Hz ASUS ROG Swift PG32UCD
Case CM Cosmos 1000
Audio Device(s) logitech 5.1 system (midrange quality)
Power Supply CORSAIR RM1000e 1000watt
Mouse G400s Logitech, white Razor Mamba
Keyboard K65 RGB Corsair Tenkeyless Cherry Red MX
VR HMD Steam Valve Index
Software Win10 Pro, Win11
We use this kind of thing to test cooling systems and refrigerant systems. Air has a lower viscosity than coolant so any leak will show up sooner with a gas than liquid.
Yeah, but that price is excellent for a solution like this. In process engineering, way pay many magnitudes more than this for equivalent tools. Calibrated flow meters are costing us half the value of my house.
