EK Water Blocks D5-Powered Ek-Quantum Reflection O11D Distribution Plate Goes Mini
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
Soft tubing if done right is more flexible obviously but also in that you don't have to drian the system to change thermal paste unlike hard tubing.
I'd likely never use hard tubing except in a place where disconnecting wouldn't be needed to deal with cpu or gpu and maybe reservoir so you're left with rad to rad connections hard tubing maybe.
MxPhenom 216
ASIC Engineer
13,168 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
I guess it depends on what he means by "performance"
I don't find hard tubing any harder to manage than soft. Its about the same for me. Maintenance may actually be a bit easier since hard tubing doesn't leach and water seems to stay cleaner longer so flushing and cleaning intervals seem to be longer.
Now, unless you're talking about using quick disconnects for soft tubing builds, but I have never used those even with my soft tubing builds.
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
I wasn't referring to QDC's but I do use them in all builds to separate cpu/ gpu and add/ remove a good automotive glass gas filter quickly
Getting air our of radiators takes a lot of time.
I was only speaking about changing thermal paste before as being ezpz leaving a little slack on the soft tubing to accommodate removing cpu water block without disassembly...
