EK Water Blocks May Be Preparing a Thermoelectric CPU Cooler
251 (0.05/day)
I used TEC when I super-overclocked my Q6600 years ago.
Good times when we had Abit and DFI around.
MpG
17 (0.00/day)
Wow, this takes me back. Giant Mountain Mods case with 4 triple rads on a Stinger waterblock, with an auxilliary 24V PSU powering a TEC, all to cool my Q6600 a couple degrees cooler. My wallet never did forgive me.
This should be amusing if it gets released. As stated already, the failure of peltier cooling was never a question of immature technology, but in how unsuitable they are for high output/small area applications like CPU cooling.
2,270 (1.22/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
Theres a dude at ocforums thats been running tecs on his rigs for years. If memory serves he uses a combination of wcing and heatsinks to run his rig with them 24/7. If i remember ill link his latest system.
silentbogo
5,620 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Well, that looks more like a realistic TEC setup. Thermalright Ultra 120 can easily dissipate >200W, that's exactly what I used with my X5650 with all of my overclocks, and I always hit the power barrier or instability before reaching anywhere near critical temps. It's perfect for cooling something like a 200W TEC. Add 3 of those, and you'll get around ~600W cooling capacity for hot side, which will give you a decent headroom on the cold side w/ reasonably overclocked 8700K at 1.35V. Plus, he went with the safest variant - chilling water instead of chilling CPU directly, which in case it fails, still runs as a decent (but slightly gimped) LC loop.
It was probably easier, cheaper, less space-consuming, and more aesthetically pleasing just to buy an aftermarket chiller. Someone here on TPU also ran a chiller.
@Knoxx29 , paging Knoxx29... :D :D :D What's your take on this?
3,866 (1.93/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 85C temp limit, CO -8~14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
Curious what EK are doing about condensation. Regardless of what tech they're using, Linus posted temperatures at or just above freezing, so condensate is by far the biggest concern I have (and my concerns over the ridiculous energy cost of TEC or the complixity/environmental concerns of pressurised refrigerant loops aren't exactly minor concerns in the first place).
We really don’t know what they’ve done with that block, I suspect that TEC plate is in the center of that block plate surrounded by water (hot side). Any exposed TEC cold plate/side would only be the area touching the CPU IHS ( only center of the entire block plate) and may not be from side to side.
Did you notice the thickness of it?
I’m not sure I explained it right...
