EKWB Halts Nickel-Plated Water Block Production
6,824 (1.20/day)
Viking Land
System Name CosmosII
Processor Ryzen 7700
Motherboard Gigabyte b650 gaming x ax v2
Cooling BeQuiet Pure Rock v2
Memory Corsair Vengeance RGB DDR5-6000 2x16GB
Video Card(s) Inno3d RTX 4070 Ti Super
Storage 1tb Corsair MP600 Pro XT
Display(s) 34" Ultrawide
Case Cosmos II
Audio Device(s) stock onboard thing
Power Supply RM850E
Software ½½
In EK's defence, the "massive damage" that most of use are reacting to was caused by soaking the block in a Sodium Cloride solution, not from real world use. The amount of corrosion that amounts to "massive" was artificially caused in 8 hours, but in reality isn't even close to what you would see after a year+ of real use.
I'm not saying there isn't a problem, because there is, I'm just saying that the "massive damage" isn't really that massive and the images that most people are freaking out about aren't anything that really happened to someone that was using the product normally.
read what i wrote ;)
it was to EK's reputation, not the blocks i was talking about :)
Thatguy
666 (0.13/day)
ground the waterblocks. we deal with this problem in the automotive world all the time with coatings and corrosion. It is almost exsclusively cuased by faulty grounds and excess current (static or others types)being carried around by water and conductive coolants.
3,647 (0.50/day)
System Name TheReactor / HTPC
Processor AMD 7800x3d 5050Mhz / Intel 10700kf (5.1ghz All Core)
Motherboard ASrock x670e Taichi / ROG Strix z490-e gaming
Cooling HeatKiller VI CPU/GPU Block -2xBlackIce GTX 360 Radiators - Swiftech MCP655 Pump
Memory 32GB G.Skill 6000Mhz DDR5 / 32GB G.Skill 3400Mhz DDR4
Video Card(s) Nvidia 3090ti / Nvidia 2080ti
Storage Crucial T700 2TB Gen 5 / Samsung Evo 2Tb
Display(s) Acer Predator xb271hu - 2560x1440 @144hz
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
Aren't they grounded as soon as you hook them to the motherboard? I do not think it would be ok to place a static charged chunk of copper on top of a CPU/GPU. I'm pretty sure the power -supply is responsible for grounding...
Update: My blocks looked great. Nice and Bright, nothing wrong with them. I did find a couple several nozzles that looked pretty rusted out and that must have been the cause. I replaced them with better quality ones and hope that is all that was wrong. Man, this thread had me worried. LOL.
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Ah, yeah, I read it differently, but yeah I get what you meant.
Either way, the people are freaking out about what seems like really bad corrosion to the blocks that never happen under normal usage.
23 (0.00/day)
this is fairly old news.
and its not several complaints, it's more like hundreds.
theres a lot more information about this on ocau and xs forum.
to sum it up: it's a problem thats been known about for months, they say user error, users are saying its poor machining and impurities in the nickel.
also theres a lot of uproar about the duration they claim they'll honor RA because of this.. basically stipulating a date which is a breach of the trade practices act in a few countries.
information on ocau and xs-if you like it neutered and deleted:slap:
specific thread on trade practices right here
http://www.realredraider.com/vbulletin/showthread.php?t=48071
posted on june 7th and i personally have not seen that info posted anywhere else,
oddly enough rrtech has been getting a lot of traffic from slovenia:)
Cold Storm
Battosai
15,010 (2.36/day)
In a library somewhere on this earth
System Name Haro
Processor AMD 1700x
Motherboard AsRork x370 Taichi
Cooling EK Custom Loop - CPU only
Memory 32gb G-Skill Trident Z
Video Card(s) EVGA 1080 Superclock 2
Storage Too Many
Display(s) Viewsonic VX2450WM-LED 24" & LG 32 IPS
Case Cooler Master Cosmos II
Mouse SteelSeries Rival 500
Software Win10 Pro
Benchmark Scores i5 750 4.62ghz pi runs // Evga FTW p55
People wouldn't act that way if EK, Eddy, didn't go the route he went.. Yeah, that one thing can mess up a system... But, if Eddy lived up to it being a fault.. it would have went a totally different way.. No.. he says F.U to people and Sidewinders.. saying liars to everyone, then after weeks of "covering it up" he comes and changes the things that should of been done in the first place.. I guess if you get forums, sites and other companies to say there is something wrong, you listen.. But, after saying people are liars, and how he's went threw it.. My money will never go towards his greed.
Lol.. Ek is in constant look at RRtech.. Nice.. Oh, well.. RRtech showed where it's really at..
23 (0.00/day)
this is too funny.
joined this forum in 2004 and that post above was my 1st:laugh:
cya again in 7 years or so.
Thatguy
666 (0.13/day)
Um, no. Also the coolant is whats carrying the electricity, if it is truely the problematic a sacrificial zinc anode in the tank with a earth ground will take the corrosive abuse off of the waterblocks. Nickel coating is a pretty good choice in reality BTW.
HammerON
The Watchful Moderator
8,402 (1.44/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
Well I will be checking my EK Supreme HF Nickel when I get home. It has been running for about 7 months w/ distilled water and silver coil. Thank goodness it is in a separate loop from my motherboard water block and gpu blocks (which are all Koolance water blocks:))!
Anyways, reading through a couple threads over at XS I found this post to be very interesting:
http://www.xtremesystems.org/forums...ating-Issues&p=4873956&viewfull=1#post4873956
582 (0.09/day)
Melbourne, Australia
System Name What the Sigma
Processor i7 7700
Motherboard Gigabyte H170-HD3
Cooling LGA1151 Noctua NH-U12P
Memory 32GB Kingston DDR4 3600 CL15
Video Card(s) Gigabyte Vision OC RTX 3080ti 12GB
Storage 2GB Lexar Gen3 NVME / 1x 120GB Intel 520 / and some spinny bois
Display(s) 3x DELL S2721DGF
Case Antec P182
Power Supply Corsair 750w
VR HMD Oculus Quest 3
ah well, I was following the threads as they were developing.
also, my comment about warranty was how it has been for weeks, I only read here and on ocau today that they're extending the RMA period. It's no suprise though, since if they didn't, they'd be looking at a law suit.
the rest of what i said stands. :shadedshu
Wile E
Power User
24,318 (3.61/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
People that throw bolt-ons on their cars should also know the Magnuson-Moss Act. I've had a couple dealers try to void a warranty because of a cat-back.
5,004 (0.80/day)
NC, USA
System Name Cosmos F1000
Processor Ryzen 9 7950X3D
Motherboard MSI PRO B650-S WIFI AM5
Cooling Corsair H100x, Panaflo's on case
Memory G.Skill DDR5 Trident 64GB (32GBx2)
Video Card(s) MSI Gaming Radeon RX 7900 XTX 24GB GDDR6
Storage 4TB Firecuda M.2 2280
Display(s) 32" OLED 4k 240Hz ASUS ROG Swift PG32UCD
Case CM Cosmos 1000
Audio Device(s) logitech 5.1 system (midrange quality)
Power Supply CORSAIR RM1000e 1000watt
Mouse G400s Logitech, white Razor Mamba
Keyboard K65 RGB Corsair Tenkeyless Cherry Red MX
VR HMD Steam Valve Index
Software Win10 Pro, Win11
Dissimilar metal based corrosion is a serious threat. Its not like we can remove the electrolyte path either. Solid news btarunr. Thanks again.
And thank you Cold storm for spreading the news.
If we ran mineral based hydraulic fluids like 5606 we might be able to solve that corrosion issue. It's also good to run in high pressure systems. I wonder if it could be run in current loops and if it transfers heat like the automotive coolant we are using in many loops today. Of course it couldn't work as well as the distilled water method but its anti corrosion properties would help if corrosion starts becoming a bigger issue.
You would think EK would have tested these nickel coatings(or plating) before selling them out on the market and having them corrode.
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
I agree, I don't think it was handled properly, the moment a problem came up he should have looked into it.
