EVGA Announces the NU Audio Pro 7.1 Sound Cards
bug
14,022 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Some may. Most, I feel, are perfectly fine with integrated audio these days... in particular the flagship codecs (Realtek ALC1220 for example). To me, it takes an audiophile to want such an item in their PC, not just users with an HTPC. And with that, if you want the best sound, a tiny ITX mobo may not be the best solution in the first place. You can get 'receiver size' chassis that with mATX/ATX boards inside which fits this nicely and fits in with other components (receiver, amp(s), pre-amp, surround decoder, etc).
But yeah, that eliminates using it on ITX, but doesn't really seem intended for such.
That's just the thing: if you're an audiophile, you already have far better DACs that this. Hence my suggestion above: use a digital out from your on-board solution and use your existing DAC. Problem solved. For cheaper.
19,375 (3.51/day)
...which are not ITX/HTPC users, typically. My only talking point was the HTPC thing. I mean, you are right, but this simply wasn't marketed towards that, obviously. But it can still happen if users want using an appropriately sized mobo and chassis.
  • Like
Reactions: bug
1,824 (0.61/day)
NH, USA
System Name Lightbringer
Processor Ryzen 7 2700X
Keyboard Royal Kludge RK71
miniITX no, but consider people with two (or more) GPUs and others with vertical GPUs... mounting one additional PCIe card in those cases is not always easy, let alone two...
Sound cards are a high end/enthusiast level products now days so those cases mentioned above will be more common... And also, companies like Creative, Asus and so on, long ago masterered the single card multichannel solutions...
If you want true 7.1 speaker inputs and don't want to have to use an external receiver, than an additional daughter board is necessary. Personally, the fact that it has the daughter board and has true 7.1 inputs has me honestly entertaining this card
245 (0.10/day)
Usually "PRO" (professional?) audio cards comes with ASIO drivers and usually don't use 3.5mm jacks... I don't see any ASIO support for this card...
bug
14,022 (3.95/day)
You're thinking music production. This is a consumer part.
967 (0.47/day)
I wish there was a modern soundcard that allowed for 7.1.2 or 7.1.4 setups. I could definitely use one to upgrade my Media Center PC and the modest pre-existing setup I have, rather than having to pay a few thousand for a dedicated receiver and speakers just to get Atmos.
4,849 (1.50/day)
Processor Core i7-13700
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro 5600 32GB kit OCed to 6600
Storage 970 EVO NVMe M.2 500GB,,WD850N 2TB
Case Phantek Eclipse P400S
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply EVGA 850 BQ
Software Windows 11 Professional v24H2
My card shows this in the NUA settings app.
Currently using the bundled with the card L/R RCA to mini 3.5mm
12 (0.00/day)
Processor AMD FX 8350 @ 4.8 GHz
Motherboard Asus Sabertooth 990FX rev. 2.0
Cooling Corsair H100i GTX
Memory G.Skill Ares 1866 4x4 GB @ 2133
Video Card(s) XFX Radeon HD 7970 @ 965 core & 1675 memory / Asus R9 280 Direct CUII Top @980 core & 1300 Memory
Storage Seagate Barracuda 1 & 2 TB/ Hitachi Deskstar 500 GB/ Kingston V300 120 GB SSD/ WD Blue 500GB
Display(s) LG EW224 and Acer X203H
Case Cooler Master 690 II Advanced w/ 5 extra fans added
Power Supply Seasonic X850
Mouse Razer DeathAdder Elite
Keyboard G.Skill Ripjaws KM780MX
One GPU, yes, but no, it's not the only card in my PC, as I also have 10Gbps card, taking up the x4 slot.
Also, as I was saying, m.2 slots seems to be favoured over x1 slots, as I only have a single x1 slot.
Because m.2 connections run over the PCI-e bus obviously there will be a drop in slots. Most higher end boards only come with 1 x1 slot but any x1 card will work in any of the following x1/x4/x8/x16 slots. So the need to have a dedicated x1 slot is a not as necessary as many seem to think it is. The limitation to these cards is the generation of the x1 slot, I can't remember off the top of my head but I believe it needs to be Gen2 or newer, only because without rereading it I can't be sure right now. only having 1 x1 slot has been the normal for year except in the low end sector where PCI-e is limited by the CPU the board was designed for. As an average the high end boards get 1 x1, mid and low end range can vary from 1-3 x1 slots. this has not changed in over 10 years. The invent of m.2 slots running on the PCI-e bus obviously takes away usable lanes for slots. I do agree with your statement but only considering the lower end boards being affected by this.
So having 4 out of 6 slots covered with GPU's is an issue with dual sound cars since one will limit the cooling of my lower card.
That is a good point, however, is fairly rare, these conditions. Multi GPU has been going the way of the dodo bird for a few years now. And if you mount your GPU vertically, you have to know there are limitations on PCIe cards, period. That said, in my case, I can run a 'full height' card along with my vertically mounted GPU... it will depend on the chassis if you have room or not.
While multi GPU systems have been becoming less common don't forget that DX12 allows for Multi-GPU cross brand usage. this allows both same brands and different brands to work as one like Crossfire/SLI. Once DX12 matures and developers get used to coding with the new tech Multi GPU's will once again come back and then the issues will arise.
My old Creative card still works and is in my kids system right now for her music which was purchased back in '08-'09 -ish so around 10 years ago. I'd put that card against most cards today for sound quality. Not everyone builds a new system every year or two so longevity is a concern for some. We can't know what will happen tomorrow or 10 years from now so saying a Cube case is a fits all situation is unreasonable plus what of those with the simple m-ATX format? The most common form factor at the moment. In these a 2 card set up will raise issues as well.
Point being a 2 card setup seems silly unless you have a need for everything to be inside the case.
177 (0.03/day)
Sevierville, TN
System Name All Switched Up
Processor Intel Core i9-9900k @ 5.0GHz
Motherboard ASUS Z390 Maximus XI Hero Wi-Fi w/ EK monoblock
Cooling Custom EK Watercooling loop - 2x 360 | 1x 240 Rads
Memory 16GB Corsair Dominator Platinum RGB 3200MHz
Video Card(s) EVGA RTX 3080 Ti FTW3 Ultra w/ EK Quantum Vector Waterblock + Active Backplate
Storage 1x Samsung 2TB M.2 NVMe SSD - 2x Samsung 860 EVO 1TB SSD - 1x Samsung 860 EVO 2TB SSD
Display(s) Viewsonix XG270QG Elite 1440p x2
Case Lian Li O11Dynamic XL - White
Audio Device(s) ifi Zen CAN/DAC | Mayflower Objective2 + ODAC | Sennheiser HD 6XX | HiFiMan HE-5XX
Power Supply EVGA SuperNOVA 1000 P6 Platinum
Mouse Glorious Model O Wireless | Model D
Keyboard Glorious GMMK Pro w/ Holy Panda's
Benchmark Scores yes
Maybe this is the card to replace my loved X-fi Fatl1ty pro...
I still have my old X-Fi Fatal1ty Pro.. aside from the long going driver issues when I first bought it years back, I loved that card.
2,097 (0.64/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
How does this compare with the Sound Blaster Audigy Rx 7.1 which is only 60$ and has a very high quality DSP?
Board architecture, layout, and construction techniques are more refined on the EVGA. Adding to that is the capacitors are far from the only component that impacts sound positively. I was unable to find a shot of the Nu Audio Pro boards. Looking at the older model and Sound Blaster Audigy Rx 7.1 shows some clear differences though.
Quite clearly you can see a lot more effort has been put into isolation and the inclusion of a heatsink. On the inside, the EVGA has a cover that passively cools and isolates from RF, vibration, etc that do impact a DAC. Basically they bear almost no resemblance to one another outside having similar connectors. One of these two sound cards looks like it was (over)designed by a guy who has 13' speakers and a few hundred grand worth of audio equipment in his office. Clearly they are aimed at different end users.
The Sound Blaster has design criteria more in line with using a 1500w PSU, dual GPU, a dozen fans, and OC'ing to the moon that all result in a very dirty ATX power delivery through the board. The EVGA will keep performing considerably better the more controlled an environment you create for it. The person using a 10Gbps card is likely to grasp how important isolation and regulation are and probably make better use of it. Both cards would work just fine, and we should be thankful quite safely nowadays, in either machine. Coming to appreciate the different purposes, looking outside gaming channels for reviews, and seeing what actual audio enthusiasts have to say could go a long ways towards understanding the best option for you.
I'm not familiar with the Sound Blaster software so won't make this any more lengthy attempting a superficial analysis.
In either case, playing a very well recorded flac/wav/DSD music file will be a rewarding experience compared to lossy mp3.
19,375 (3.51/day)
Interesting points. :)
DX12 isnt going to save mGPU. It has been around for several years now and with that mGPU is still out of favor and not gaining ground. Further maturation of something already mature wont really help. Nobody is pushing SLI or CFx.
I dont believe I mentioned cube cases, though any with a vertical mount (and the right mobo, could fit this..depends on room of course). My case isnt a cube, note. :)
Who8MyRice123
1 (0.00/day)
Dear EVGA, how many free PCIe slots do you think we have?
Also, seriously? Two cards to do the job of a single one??? Maybe an Audio SLI connector for "Better Audio Processing" is next?
Yea lemme just remove my graphics card EVGA... oh wait.
627 (0.23/day)
I think it says more about the state of motherboards, which is why I still enjoy the Z77/X79 era, especially when PLX chips were a thing (before they got bought out). Even the vast majority of EATX/ATX boards don't bother at all anymore to include 7 actual slots, regardless of lanes; shame. I personally friggin HATE the M.2 trend in the PCIe area; you can do so much more with adapters. Dump the M.2 slots, like someone boards do, in the PCH, DIMM or back instead. PCIe slots are way more versatile. Even the highest end consumer boards right now, with CPUs that offer more lanes, don't bother to have boards made like the ASRock X79 Extreme 11 anymore (and look, even has the previous standard Core3D Creative chip). I've lost a lot of interest. But then again, I actually bother to use them all.
7 x PCI Express 3.0 x16 slots (PCIE1/PCIE2/PCIE3/PCIE4/PCIE5/PCIE6/PCIE7: x16/0/16/0/16/0/16 mode or x16/8/8/8/8/8/8 mode) (2 x PLX PEX8747 Bridges to support 4-Way SLI™ in Gen3 x16/16/16/16 mode)
4,849 (1.50/day)
It's more a continuation of consolidation of chips towards a single in the smartphone era.
Dru
9 (0.00/day)
It's like complaining that you need to buya higher wattage PSU to power a new powerful GPU. Go another route that suits your build and budget and let others enjoy stuff they can accommodate.
12 (0.00/day)
You sir, Are obviously not an enthusiast that wants it all going by this comment.
INSTG8R
Vanguard Beta Tester
8,098 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
The Slot thing is a bit of “false flag” as the card is USB 3.0 on a card as biffzinker showed us earlier and not a true PCI interface but some kind of bridge thing happening.. I was really quite interested in the 5.1 model until I saw this.
12 (0.00/day)
Ok you definitely have me scratching my head with this comment. Yes I did go back and read the post you refereed to SO I am educated enough to comment. It is a two (2) card set up that needs two (2) free PCI-e slots to hook into. Weather or not the card acts as a usb device has no bearing on how it hooks to the motherboard. Two (2) cards requiring Two (2) PCI-e slots will need Two (2) PCI-e slots regardless of what the card emulates on itself once hooked into the the two (2) PCI-e slots.
INSTG8R
8,098 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
But it appears as a USB device so it’s being bridged to PCI so basically it’s essentially a USB external DAC strapped to a board. All that great design being middlewared via USB to PCI that has to comprise bandwidth and possibly
latency and just being a poor design regardless.
4,849 (1.50/day)
It works as a high-end soundcard just fine for me.
INSTG8R
8,098 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
Yeah I just question the “interface” I really wanted the 5.1 card but this USB nonsense puts me of.
4,849 (1.50/day)
634 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
@biffzinker How long is the mDP cable that comes with the card? It looks to be less than 1ft or 30cm.
I am considering getting this card and would need to separate the two cards around an EVGA 2080 Super.
I currently have a Sennheiser GSP 600 but am wanting to play with a Razer Tiamat 7.1 V2 that I got stupid cheap the other day.
My Soundblaster AE5 doesn't support the 7.1 analog connections. It is lacking the Side output.
4,849 (1.50/day)
My Nu Audio card is the silver colored single slot version.
