EVGA GTX 1070/1080 Overheating Issues - Company Says Thermal Pads A Solution
5,393 (0.93/day)
Carrollton, GA
System Name ODIN
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling Dark Rock 4
Memory G Skill RipjawsV F4 3600 Mhz C16
Video Card(s) MSI GeForce RTX 3080 Ventus 3X OC LHR
Storage Crucial 2 TB M.2 SSD :: WD Blue M.2 1TB SSD :: 1 TB WD Black VelociRaptor
Case Fractal Meshify C
Audio Device(s) Onboard Audio
Mouse Corsair M65
Keyboard Corsair K70 RGB Lux
I am literally waiting for an EVGA 1070 SC to arrive on Wednesday. Now I have to check to ensure there are thermal pads or did they confirm that this only affects the FTW line?
919 (0.21/day)
System Name White Shark
Processor 9800X3D
Motherboard MSI B650 Tomahawk
Cooling Artic Freezer iii 360 Black
Memory TeamGroup T-create 32GB (16gbx2) 6000mhz cl30
Video Card(s) RTX 3080 12gb Asus TUF OC
Storage Samsung 980 Pro 1TB OS / 860 EVO 500 GB /860 EVO 1TB/ Seagate 1TB
Display(s) LG 34GP83A-B 3440x1440p 144hz nano-ips ultrawide
Case Phanteks P500A (White/Black)
Audio Device(s) HyperX Cloud Alpha Wireless
Power Supply Seasonic Vertex GX 1000w gold 80+
Mouse HyperX Pulsefire Haste
Keyboard HyperX Alloy Origins Core - Tenkeyless
Software W11 24h2
The more i read posts here the more i cry :( i think i will have to cross my fingers and hope my card doesnt fu.... And i was thinking on grabbing the msi gaming z b t decided for evga cuz was evga of course.... And ended in a curse
5,393 (0.93/day)
Carrollton, GA
System Name ODIN
Cooling Dark Rock 4
Mouse Corsair M65
If it makes you feel any better, The EVGA 1070 SC was the one Wiz reviewed and the pictures clearing show thermal pads everywhere. Hopefully this was a line manufacturing issue with the FTW batches only.
716 (0.13/day)
Finland
System Name RGB-PC v2.0
Processor AMD Ryzen 7950X
Motherboard Asus Crosshair X670E Extreme
Cooling Corsair iCUE H150i RGB PRO XT
Memory 4x16GB DDR5-5200 CL36 G.SKILL Trident Z5 NEO RGB
Video Card(s) Asus Strix RTX 2080 Ti
Storage 2x2TB Samsung 980 PRO
Display(s) Acer Nitro XV273K 27" 4K 120Hz (G-SYNC compatible)
Case Lian Li O11 Dynamic EVO
Audio Device(s) Audioquest Dragon Red + Sennheiser HD 650
Power Supply Asus Thor II 1000W + Cablemod ModMesh Pro sleeved cables
Mouse Logitech G500s
Keyboard Corsair K70 RGB with low profile red cherrys
The shown burnt cap usually isn't caused by temperature but defect and leak, thus it shorts out, wrong markings lover real voltage ratios.
It could be totally digging the wrong way.
Most SMD caps are rated at 85 degrees C, the good stuff is rated at 105C. What do you think running them past their maximum rating would do other than cause defects, increase leakage current, finally short out and burn?
Combined effect of both voltage and temperature derating and there you go. Marginally OK caps go boom sooner, rest later. Heat kills caps. Not just the electrolytic kind.
7,607 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Mouse Razer Basilisk
Software FEDORA 41
This particular one in the pic looked more like a dud. Actually there are no problems getting ceramic caps that hold +200C, usual ones are +125C... those are not lytics exactly...
307 (0.06/day)
Processor Ryzen 2700X
Motherboard Asrock X470 Master sli/ac
Cooling Raijintek Themis Evo
Memory Team Dark Pro 3200 cl14
Video Card(s) GTX 1080
Power Supply Seasonic Focus Gold Plus 850W
Does it matter if they can survive 1000C if other components nearby melted due to high temps? It's just bad, no need to discuss further.
7,607 (1.46/day)
Rīga, Latvia
Software FEDORA 41
Could you be reasonable and READ??
They should operate normally... I suspect a bad batch(or a human error) of parts not some missing tapes or bad thermals(like putting a patch to a corpse). 100C in VRM section isn't something uncommon(R9 290)... not that have died much from that being a fire spitting monster and being constantly farming in bitcoins...
919 (0.21/day)
Processor 9800X3D
Software W11 24h2
And i have the ftw only.....
872 (0.14/day)
Copenhagen, Denmark
System Name Ryzen/Laptop/htpc
Processor R9 3900X/i7 6700HQ/i7 2600
Motherboard AsRock X470 Taichi/Acer/ Gigabyte H77M
Cooling Corsair H115i pro with 2 Noctua NF-A14 chromax/OEM/Noctua NH-L12i
Memory G.Skill Trident Z 32GB @3200/16GB DDR4 2666 HyperX impact/24GB
Video Card(s) TUL Red Dragon Vega 56/Intel HD 530 - GTX 950m/ 970 GTX
Storage 970pro NVMe 512GB,Samsung 860evo 1TB, 3x4TB WD gold/Transcend 830s, 1TB Toshiba/Adata 256GB + 1TB WD
Display(s) Philips FTV 32 inch + Dell 2407WFP-HC/OEM/Sony KDL-42W828B
Case Phanteks Enthoo Luxe/Acer Barebone/Enermax
Audio Device(s) SoundBlasterX AE-5 (Dell A525)(HyperX Cloud Alpha)/mojo/soundblaster xfi gamer
Power Supply Seasonic focus+ 850 platinum (SSR-850PX)/165 Watt power brick/Enermax 650W
Mouse G502 Hero/M705 Marathon/G305 Hero Lightspeed
Keyboard G19/oem/Steelseries Apex 300
Software Win10 pro 64bit
i thought evga had better quality standards.. pitty.
307 (0.06/day)
The thing is the VRM might not care about the high temps, but not the components nearby. High temp in anything is bad in general, especially when the memory is being cooked.
1,009 (0.18/day)
Michigan
System Name Daves
Processor AMD Ryzen 3900x
Case Phanteks P600S
Audio Device(s) N/A
Power Supply Corsair RM 750
Mouse EVGA
Keyboard Corsair Strafe
You really have to wonder, who's bright idea was this, whoever it was he/she should be fired.
EVGA should be replacing these cards with a brand new unit..
4,367 (1.10/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
That is unfortunate and unacceptable for a premium version of the card to have that issue especially from EVGA no less. I mean, its not the end of the world, but for a high overclocking card (At least thats what they used to intend) I expect the cooling to be top notch.
Again, an easy fix but it seems like something that should have been avoided to begin with.
919 (0.21/day)
Processor 9800X3D
Software W11 24h2
i dont think is an easy fix since you may lose your warranty on the card.... for me was $459 at newegg so my opinion on EVGA was destroyed by themselves. Since ive had a line of good cards (gtx 570 SC-670 -970 SSC)
9,252 (1.57/day)
Montreal, Canada
System Name Homelabs
EVGA is still a good brand despite their fu ... This seems to be only on their FTW line and they are admitting their fault and trying to give users a solution. Better yet , you know that kind of issue will be absent in the future as there will be more scrutiny around that etc.
Around here, they are usually the best bang per buck cards. I can safely say I'll still be recommending EVGA cards
Seems paranoid to think that they will void warranties for people trying to install the supplied thermal pads.
19,378 (3.49/day)
I mean... stuff happens...
To put them on a public trial like I see some are doing for a simple mistake (which they are correcting), is more disconcerting than EVGA's mistake here.
1,333 (0.28/day)
South-Africa
Processor AMD Ryzen 9 5900X
Cooling Noctua NH-D15 G2
Storage SAMSUNG 990 PRO 2TB
Display(s) Dell S3220DGF
Case Corsair iCUE 4000X
*Sigh* After getting a screwed up MSi card; this was the last thing I wanted to read after I swapped to the EVGA FTW. :*(
1,703 (0.26/day)
Oshkosh, WI
System Name ChoreBoy
Processor 8700k Delided
Motherboard Gigabyte Z390 Master
Cooling 420mm Custom Loop
Memory CMK16GX4M2B3000C15 2x8GB @ 3000Mhz
Video Card(s) EVGA 1080 SC
Storage 1TB SX8200, 250GB 850 EVO, 250GB Barracuda
Display(s) Pixio PX329 and Dell E228WFP
Case Fractal R6
Audio Device(s) On-Board
Power Supply 1000w Corsair
Benchmark Scores A million on everything....
So, no replacement cards? F that! Who knows what kinda damage has already been done to the card.
Here, burn your card up for 6 months then dismantle the entire thing and put these thermal pads on. It's on the house.
Where's everybody's $75 an hour for labor? After all you have to be an "expert" to take your card apart without voiding your warranty, right?
I feel bad for you guys that bought one.
bug
14,182 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Frankly speaking, this should kill the FTW brand like exploding batteries killed Samsung's Note.
Also, anyone still remember s how EVGA screwed Unwinder over RivaTuner code? It seems the brand has been going downhill for a while. I've just got my card from them, but I'll be sure to look at alternatives first for my next upgrade.
cdawall
where the hell are my stars
27,683 (4.07/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
$75 an hour to do menial labor? Where do I sign up. I also bet these cards are not failing under normal use, the failures reported are probably the batch that thinks they need to run furmark on everything for no reason.
21,912 (3.42/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (2x 32GB) G.Skill Flare X5 @ DDR5-6200(Running 1:1 @CL30 1T no GDM)
Case Thermaltake Core X31
Software Gentoo Linux x64
This is piss poor on EVGA's part. I'd expect a free replacement offer/exchange program from EVGA.
It's sad, because I had a really good RMA experience from EVGA's mobo department. But then again, they did blow up half my rig with a defective card. :p
drewskidrewsgv
1 (0.00/day)
It's funny how people don't understand that these "tests" by the German Tech Power up site were done using Furmark for AN HOUR AND A HALF. That's why those temps got so high and also Furmark isn't even supported by Pascal and Maxwell GPU's. EVGA didn't even say this was a solution, they just did this to stop the whining from people about a non existent issue.
3,505 (0.60/day)
Me stopped reading when me spotted "furmark".
That thing is used only when a user wants a replacement card, periold.
2,229 (0.43/day)
Yeah, furmarking your card to pieces is the way to go.
It puts an unrealistic load to your VRM's, GPU and Memory, causing the thing to heat up. It's not bin tested for QC-standards like this.
63 (0.01/day)
Processor i7 3770k
Motherboard ASUS P8P67 Pro Rev 3.0
Memory Corsair Vengeance DDR3 16GB
Video Card(s) Gigabyte GeForce GTX 980Ti G1 Gaming
Display(s) ROG Swift PG278Q
I simply cannot trust EVGA again. Remember when they did a similar thing with the ACX 2.0 and ACX coolers on the 7 and 9 series from Nvidia and they claimed it was deliberate that only 2 of the 3 heatptipes touched the GPU core? The third heatpipe was not even sealed off.
And now this? You can say that Furmark is not realistic and all that but the rest of the competition still made sure they'd provide a proper cooler, even for unrealistic scenarios.
TPU 970 pic:
TPU 760 pic:
Notice the third heatpipe:
Shame on you EVGA.
1,742 (0.35/day)
Asheville, North Carolina
System Name Red Giant
Processor Intel Core i7-12700K
Motherboard MSI Pro Z690
Cooling Corsair H100i elite
Memory Corsair Vengeance Pro 32GB
Video Card(s) MSI 4070TI Super
Storage 960 GB Sandisk SSD
Display(s) 27 inch Predator 144 hz 2k
Case CoolerMaster HAF X
Power Supply Corsair AX1200
Keyboard Corsair K95 Platinum
Anyone besides me have a 1070 SC they could conveniently check or am I gonna end up being the only one with one :(
