EVGA Intros Power Boost Gadget to Improve PCI-E Power Stability
190 (0.03/day)
VT
They didn't give the board more connectors because they followed power spec. Not that EVGA is totally free of blame in this but IMO they shouldn't be held accountable for nvidia and ati making cards that draw to much power and fry boards.
As for the price I'm sure once you factor in the labor to make these, costs for making them, free shipping, and all the other costs associated with making these adapters they are close to the break even point.
1,334 (0.23/day)
Did evga expect people to use four 4/5/6450s in crossfire?
Mussels
Freshwater Moderator
58,413 (7.87/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Apparently, some ATI cards drew too much from the slots, which was causing problems with the 24pin connector overheating.
I don't know. Doesn't seem to me this has a very big niche to fill.
Ok, so that begs the question: Why didn't they give the board more power connectors for the PCIe slots to begin with? I mean, they had to know 4 heavily OCed cards might overdraw on the slots.
This is one of those things where I see the point, but at the same time, feel we probably shouldn't need to resort to this.
And the price is retarded.
so my comment about helping to compensate for multi railed PSU's has been ignored/discredited? :(
W1zzard
Administrator
28,122 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
so evga goes over spec for like every overclocker related feature and is not responsible for slacking on the pci-e power front?
who would you blame if evga sold you an enthusiast board with a bios that has no fsb adjustments ? (we followed the spec). you can buy a new bios for $69.99 to unlock fsb increases.
190 (0.03/day)
VT
The thing is that this is happening on systems that are not massively overclocked on ln2 or dice. Or even quadfire or tri SLI setups. The cards are so massively over spec that they are melting plastic on the 24pins. If this only happened when you were running some extreme overclocking scenarios I would say EVGA is at fault since that is what this board is designed for.
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
It has nothing to do with the cards being over specced. The problem can happen on cards that are within spec as well.
You pop 4 cards in a motherboard that pull 75w a piece though the PCI-E slot and that is 300w through the two 12v wires on the 24-pin connector. I don't believe that connecter was ever specced for that much power, or really any more power than a single PCI-E slot would draw.
Mussels
58,413 (7.87/day)
Oystralia
thats correct. just because a motherboard has 7 PCI-E slots doesnt mean they ever intended you to run 7 video cards, especially not 24/7 like some folders do.
adding in a few extra wires to even the load COULD help, but that doesnt mean i think this little doodad is the way to achieve that.
W1zzard
Administrator
28,122 (3.72/day)
Memory 48 GB
The ATX 24-pin connector has 2x 12V with 16 or 18 AWG. A 5.25" Molex type connector adds one more 16/18 AWG wire.
So the current through the ATX power connector 12V lines is reduced by 33%.
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Exactly, that is actually a pretty big difference. Instead of 150w per wire, it is now 100w per wire. That could easily be the difference between melting the insulation/frying the connector and not.
Wile E
Power User
24,318 (3.63/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
This has nothing to do with multi rail psus. Multi rail psus do not need any form of compensation.
Mussels
58,413 (7.87/day)
Oystralia
it could help split the load up.
Wile E
Power User
24,318 (3.63/day)
No need. Buy a quality psu, and it doesn't matter at all.
Mussels
58,413 (7.87/day)
Oystralia
while i agree with wile, i'm just reaching for situations this MIGHT be useful :p
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Multi rail PSUs are just single rail PSUs with multiple OCP circuits. So the only thing this device would help would be preventing the OCP circuit connected to the 24-pin from tripping and shutting down the PSU if it was overloaded. Though a lot of PSUs have the 24-pin and molex connectors sharing the same OCP circuit anyway...
Mussels
58,413 (7.87/day)
Oystralia
yeah exactly, it COULD help prevent that exact scenario.
you're right on molex and 24 pin often sharing a rail, but its not always the case.
WarEagleAU
Bird of Prey
10,812 (1.59/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
I dont get this product and it seems unsafe. Put it in wrong and your warranty is voided,,,,,odd.
