[expert][tip] Using a RAMdisk to speed up your HDD - and/or reduce SSD trashing
1,972 (0.34/day)
Bulgaria
System Name penguin
Processor R7 5700G
Motherboard Asrock B450M Pro4
Cooling Some CM tower cooler that will fit my case
Memory 4 x 8GB Kingston HyperX Fury 2666MHz
Video Card(s) IGP
Storage ADATA SU800 512GB
Display(s) 27' LG
Case Zalman
Audio Device(s) stock
Power Supply Seasonic SS-620GM
Software win10
Great thread. I got 24GB of RAM on the way. Going to make some "tweaks" to my primary workstation. I'm having some great results using Dataram's RAMdisk application. Throughput rates are simply ridiculous. I'm getting around 25 to 30 times faster overall performance compared to stuff you can find in retail, SSD-wise.
RAMdisk setups seem pretty rare. Anyone got info to share on best ways to utilize such setups aside from obvious ways? I plan to run a tweaked and modified version of Windows straight off of it. With some symlink trickery I should be able to utilize such a small amount to a farthest degree.
You can't install windows on a ram-drive for a couple of reasons. It's not gonna work with the current programs on market because they load after windows boot and because they can only format your ram as FAT and not NTFS meaning that a logical drive partition can't be sored permanently :(
5,123 (0.89/day)
North of Germany
System Name Nexus PC
Processor Intel Xeon E3-1231 v3, 3600 MHz
Motherboard Gigabyte GA-H97-HD3
Cooling Thermalright Macho V2
Memory 24GB DDR3, 1400MHZ CL8
Video Card(s) Sapphire Radeon R9 290
Storage Samsung EVO 960 250gb, EVO 850 250gb, Vertex 3 128gb. 2 TB of Rotational.
Display(s) 1xAsus MX299, 2x Asus MX239, Oculus Rift CV1
Case Sunflower Tower
Audio Device(s) C-Media CMI8738/C3DX
Power Supply Corsair TX850
Mouse Cyborg R.A.T. 7
Software Win7 64Bit Ultimate
Romex can do NTFS;)
But of course, they still wont work due to what you said:D
OneMoar
There is Always Moar
8,815 (1.62/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
win pe > ram disk > windows
OR get a ssd
3,565 (0.65/day)
By the Channel Tunnel, Kent, England
System Name Benny
Processor Phenom II 1055t @ 3.3GHz; 300x11; 1.380v; NB 2700; HT 2400
Motherboard ASUS Crosshair IV Formula (2002 BIOS)
Cooling Thermalright TRUE 120 Black + 2 Xilence Red Wing PWM 120mm (push/pull) + polycarbonate fan holders
Memory 8GB GeIL Ultra 2133MHZ C9 running at 1600MHz @ 7-7-7-21 1T 1.5v
Video Card(s) MSI Twin Frozr II GTX470 @ Stock w/CPU fan cable-tied on, as one of the GPU fans broke.
Storage 60GB OCZ Agility3 (OS);500GB WDC Grn; 1x1TB WDC Blk (Backup)
Display(s) ASUS PA823Q
Case Silverstone Raven 2 (all cables custom sleeved with velcro mod on side panel...)
Audio Device(s) X-Fi (Onboard) + Harmon Kardon HK6100 amp powering JVC HA-RX700's with Zalman mic
Power Supply Corsair HX650W
Software Win7 Pro x64
Benchmark Scores No benchies so making this space useful! Corsair M90, Logitech G19. Phobya FlexLight LED's (gawjus)
Just to add to HAH's comment: moving a pagefile to RAM will also help save writes to your precious SSD. So IF your pagefile is being used, moving it to RAM will speed it up and save you writes. With modern workstations with 8GB and more memory, you might as well fix the pagefile to 1GB and stick it in a ramdrive.
There is another good reason to have your pagefile on a RamDISK:
If you're a video editor. Keeping your HDD as empty as possible is a must for a video editor who can't afford/accomodate a decent rig/extra HDD's. If a video editor's HDD performance is low, but RAM usage is also low, performance may be gained through ramdisking your pf to free up the vital space on your HDD.
I know it's an old-ish thread, just wanted to expand on why Ramdisk pagefile's have their uses IMO.
Completely Bonkers
2,576 (0.39/day)
Processor Mysterious Engineering Prototype
Motherboard Intel 865
Cooling Custom block made in workshop
Memory Corsair XMS 2GB
Video Card(s) FireGL X3-256
Display(s) 1600x1200 SyncMaster x 2 = 3200x1200
Software Windows 2003
If you are using the RAMdisk to hold internet temps, then please note something I have just seen with Chrome. When chrome updates, it rewrites its links and shortcuts. It therefore overwrites any command line switches you have set, incl. redirecting temps to the ramdisk. Therefore, after each update, you need to add the command line switch again:
Instructions:
1./ Right click on your chrome shortcut
2./ Properties
3./ Edit Target, as follows: "C:\Documents and Settings\...\Local Settings\Application Data\Google\Chrome\Application\chrome.exe" --disk-cache-dir=z:\
Change the last part, z:\, to your ramdrive if not on Z:
Repeat. You have to do this again each time chrome updates.
t_ski
Former Staff
11,941 (1.73/day)
System Name My i7 Beast
Processor Intel Core i7 6800K
Motherboard Asus X99-A II
Cooling Nickel-plated EK Supremacy EVO, D5 with XSPC Bayres & BIX Quad Radiator
Memory 4 x 8GB EVGA SuperSC DDR4-3200
Video Card(s) EVGA 1080 SuperClocked
Storage Samsung 950 Pro 256GB m.2 SSD + 480GB Sandisk storage SSD
Display(s) Three Asus 24" VW246H LCD's
Case Silverstone TJ07
Power Supply Corsair AX1200
Keyboard Corsair K95
Software Windows 10 x64 Pro
Did anybody ever figure out how to load the whole OS to a ram disk?
Mussels
Freshwater Moderator
58,412 (7.84/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
you could run a VMware from a RAMdisk, thats about it. every OS out there needs a reboot after installation, so it wouldnt work for normal use.
5,123 (0.89/day)
North of Germany
just for your information... Romex Ramdisk was renamed and is now called Primo Ramdisk.
Still the most capable tool regarding ramdisks, in my opinion.
1,498 (0.28/day)
canada
System Name INTEL/AMD
Processor I7 4790k stock / 1100T@3.8GHZ(on air)
Motherboard GIGABYTE GAMING 5 / GIGABYTE GA-990FXA-UD3
Cooling Noctua NH-D15 / zalmen 9900
Memory 4x4 GB 1600 / 4x4gb 1600
Video Card(s) GTX670 x2 / ATI 5870 x2
Storage 2xcorsair ssd 120gb raid0 /2x adata ssd 120gb
Display(s) 55Iinch LCD / 22inch acer
Case CM 690 II Advanced (USB 3) / Anteck 900
Power Supply Enermax 800EWT / 750 zalman
Software Win 10
Would this work well on 4 gb if i just use 1 gb for ram disk?
5,123 (0.89/day)
North of Germany
Completely Bonkers
2,576 (0.39/day)
On my 2GB Atom netbook, I have a 256MB RAMdisk to hold temps. Chrome temps are pointed there as are Windows TMP and TEMP. It makes a heck of a difference when browsing the internet or using MS Office. And I don't need to worry about CCleaner on internet temps... since they get shredded on powerdown ;)
2,678 (0.48/day)
System Name Old Gateway
Processor i5 4440 3.1ghz
Motherboard Gateway
Cooling Eh it doesn't thermal throttle
Memory 2x 8GB JEDEC 1600mhz DDR3
Video Card(s) RX 560D 4GB
Storage 240gb 2.5 SSD 3TB 7.2k Seagate
Display(s) Dell @ 1280*1024 75hz
Case Gateway
Audio Device(s) Gateway Diamond Audio EMC2.0-USB 5375U ($15 a long ass time ago)
Power Supply 380w oem
Mouse Purple Walmart special, 1600dpi. Black desk mat
Keyboard SteelSeries Apex 100
VR HMD Lmao
Benchmark Scores It can run Crysis (Original), Doom 2016, and Halo MCC
9,252 (1.57/day)
Montreal, Canada
System Name Homelabs
I found the, IIRC the name is Qsoft to be the fastest
7,228 (1.07/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
There's another ramdisk contender on the block. I've been using it and quite impressed with the results. Compatible with Windows XP, 2003, 2008, Vista, 7 and 8. Works in both 32 and 64 bit editions of Windows. Now the two major pluses: It's fast, and it's FREE. :pimp:
http://www.softperfect.com/products/ramdisk/
9,252 (1.57/day)
Montreal, Canada
hmmm I'll probably try to compare Qsoft to this to see, thanks
so far though Qsoft has always been the fastest for me
voidberg
1 (0.00/day)
hey got a random idea and read about this today at school and came home and tested it tried it out a little and im satisfied with it thank you very much also found if you install java onto it it make java games run amazingly
4,378 (0.93/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
