Fake 4GB Radeon R7 350, 1GB Firmware Fix Needed
Deleted member 163934
@memphisobrien I'm glad I managed to help you. :)
@MrGenius figure it out that the module VRAM_Info is where the amount of ram is stored. I opted to find a proper donor for your vbios (same module size (kinda implies same supported memory type)).
I have an idea about what value is actualy controling the amount of ram installed (in this particular bios case, no clue about others) but well I'm not sure it's only what I believe it is (i see no point for more than 1 value for the amount of ram, but there might be data regarding how that amount is obtained).
No clue why AMD decided to keep the amount of ram in the vbios and not use auto-detect for it.
Test one of the gpu with 3dmark or/and unigine valley (valley should be enough for your gpu). 1 hour max, if there are problems you will see them fast (crash or anomalies).
Check the temps.
Also if you play games look for texture anomalies (with amd it can easily be the drivers...) and/or artifacts.
If you see texture anomalies ( something like random white/black lines (or block(s)) ) try an older driver. (With my hd 7750 on Win 8.1 I can't use drivers newer than 15.6, 15.7 and newer result in random texture corruption, I can actually reproduce it easily in Dota 2 menu..., funny part is that I don't experience it with 15.6 and older or in Linux... so I put the blame on AMD drivers).
I have no clue what they actually do when they make the fake vbioses... so there can be other things that are not right in the vbios :( . (But what do I say here... I've seen new gpus from well known manufactures that had problems...)
muslumturkmen
12 (0.01/day)
What card? Im flash bios and dont work gpu. Which bios?
Its fake r7 370 4gb.
43,813 (6.79/day)
Zoom in on the scratched out numbers please, take pics of every ram chip on the card too. Get a gpu-z screenshot aswell. Attempt to upload the bios to the vga bios collection through gpu-z: click arrow by uefi check box, you may or may not receive a prompt with a link, copy the link regardless and post here.
Start looking
Q375513729
3 (0.00/day)
Hi
I have the same problem.
R7 350 (don't know the manufacturer.)
GPU AMD 1619 TCY648.00 216-0834044
RAM 4xSKhynix H5GQ2H24AFR T2C
I've tried all versions of this post, it doesn't work,black screen.
Only the fake version work.
But when use AIDA64 GPGPU Benchmark test Memory Copy, it crashes.
  • Fake 4G BIOS.zip
14,376 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Try this 1GB version:
1,491 (0.91/day)
System Name Chip
Processor Amd 5600X
Motherboard MSI B450M Mortar Max
Cooling Hyper 212
Memory 2x 16g ddr4 3200mz
Video Card(s) RX 6700
Storage 5.5 tb hd 220 g ssd
Display(s) Normal moniter
Case something cheap
VR HMD Vive
NECROOOOO
Just so you know
Deleted member 209281
hello i have the same problem
I used msi kombustor 4 cpu stress test 3200 mb to see if it really has 4 gb video memory and when it reached 2048 mb video memory, crash radeon software, it has 4 chips elpida w2032bbbg-60-f on one side, 4 on the other side ..I think they are 256 mb each, can someone help me with a modified bios to detect correct my 2 gb video memory?
-cape verde.rar is my vbios
-my video card have vga,hdmi and dvi
  • Cape Verde.rar
