- Oct 30, 2022
- 247 (0.30/day)
- Australia
System Name | Blytzen |
Processor | Ryzen 7 7800X3D |
Motherboard | ASRock B650E Taichi Lite |
Cooling | Deepcool LS520 (240mm) |
Memory | G.Skill Trident Z5 Neo RGB 64 GB (2 x 32 GB) DDR5-6000 CL30 |
Video Card(s) | Powercolor 6800XT Red Dragon (16 gig) |
Storage | 2TB Crucial P5 Plus SSD, 80TB spinning rust in a NAS |
Display(s) | MSI MPG321URX QD-OLED (32", 4k, 240hz), Samsung 32" 4k |
Case | Coolermaster HAF 500 |
Audio Device(s) | Logitech G733 and a Z5500 running in a 2.1 config (I yeeted the mid and 2 satellites) |
Power Supply | Corsair HX850 |
Mouse | Logitech G502X lightspeed |
Keyboard | Logitech G915 TKL tactile |
Benchmark Scores | Squats and calf raises |
Hey peeps, just completed my mostly upgraded build
B650E Taichi Lite
Ryzen 7 7800X3D
Coolermaster HAF 500 (2x 200mm front intake fans, 1x120mm rear exhaust
Deepcool LS520 acting (2x 120mm as exhaust into the top mount grill.
Questions I've got (now it's running)
1. Is there a preferred config of what connectors (fans, aio pump, aio fans) to connect to the motherboard ? (I assume the system is smart enough to realise something is connected to it)
2. What software would be the best fan tuning given the variance of manufacturers. Looking to keep it cool but ramp the fans down a little.
3. Other than PBO in bios, is Ryzenmaster the best way to tune the cpu (looking to get a little boost but reduce the temps a decent amount if possible - the standard up to 200mhz then a modest undervolt)
4. Lastly, what software would you guys use to control the rice lights (RGB)
I know this is reasonably ambiguous, but there might be some blatant obvious choices I'm unaware of, my last build was on an Asus X370 and I just let Q-fan do the work and tuned off the RGB since it wasn't what I was after.
B650E Taichi Lite
Ryzen 7 7800X3D
