FPS Monitor (Ingame hardware monitoring overlay)
43,813 (6.79/day)
Some games have a built in fps monitor, enable it for those games
apraetor
2 (0.00/day)
Hi everyone!
I read the rules and I know that for new users the opportunity to talk about their project is limited. But unfortunately I do not know another way to tell about the project which can be useful to the forum participants. This is not spam, and I will be grateful if the forum administration allows me to talk about our program. Thank you.
I'd like to present new app for everyone who likes to monitor stats of hardware while gaming! FPS Monitor - friendly and easy to use application for displaying FPS and other sensors (CPU/GPU/RAM/NET/DRV and 100+ others) in game overlay. The program is ready to use right after installation and always allow you do some precise configuration.
Paid or free? All functionality is free if you use software from our site, and it is only one limitation - we will show a reminder to support developers.
Website: https://fpsmon.com
Steam: https://store.steampowered.com/app/966610/FPS_Monitor/
Basic Functionality:
- FPS (including minimum/average/maximum and frame time).
- Real-time information about CPU, video card, memory, network activity, disks activity and more than 40 other sensors.
- Show sensors information as numbers and/or graphs.
- Notifications about the critical values of all important parameters (like overheat) - you will not miss it.
- Energy consumption sensor (in the presence of a UPS or power supply with such a function).
Easy to use:
- You can customize the interface directly in the app window - add and remove sensors, set limit values, change colors, sizes, fonts, alignment and position of any displayed data.
- Configure the interface before entering the game and check how it looks on top of screenshot or directly in the game.
- Take screenshots plus use hotkeys, picture or text overlays.
- Switch between several ready-to-go presets and create them yourself.
Our solution is so optimized that is using only up to ~0.5% of your CPU power!
Right now, we already have more than 200,000+ users. We continue adding some new cool functionality, so stay tuned!
I will follow the topic, questions and suggestions are welcome!
Thank you!
Ok I bought a copy, looks great! Can I gave a copy of the layout used in the screenshot in the main body of the post? It's perfect, and I'm not very talented at making pretty things ;)
22 (0.01/day)
System Name R7GE PC
Processor CPU: Intel Core i7 6950x @4,3Gz
Motherboard ASUS ROG RAMPAGE V EXTREME/U3.1
Cooling Corsair Hydro Series™ H115i
Memory Corsair Vengeance LED 32Gb DDR4
Video Card(s) GTX 1080 Gigabyte Xtreme Gaming
Storage m.2 Samsung 960 Evo (2Tb), 22Tb HDD's.
Display(s) 27' BenQ XL2720T (1920x1080@120hz)
Case Corsair Graphite 780T (white)
Audio Device(s) Creative X-Fi Titanium HD
Power Supply Corsair AX1200i (1200watt)
Mouse HyperX Pulsefire fps
Software Win10x64
Benchmark Scores World Top 18 in 3DMark Firestrike Extreme in 2017 :)
Thank you for support :)
New scenes are coming in one of future upgeades soon!
22 (0.01/day)
System Name R7GE PC
Software Win10x64
We have created amazing new charts that will help you keep track of the most important data even more clearly than anywhere else!
5,731 (1.06/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
So can you tell me, why when removed through add and remove programs, the program folder stays intact, fpsmon continues to load at startup and the program folder cannot be manually deleted because of fpsmon64.dll and fpsmon32.dll. Also the reason I decided to remove it in the first place is the constant popups on every startup asking me if I want to try or buy it, I did want to try it, I don't want it to constantly force me to close 2 popup notifications every time I boot my PC during that trial. It is time and funtion limited that should be enough. Looks like adware, acts like adware, hopefully the rep can explain.
22 (0.01/day)
System Name R7GE PC
Software Win10x64
Probably you tried to remove the program without exiting it and adding it to the autoload (check it in the settings). What you describe should not be if you correctly remove the program. Try again, if it does not work out - reboot your PC and remove it without launching the program.
In the first versions, we limited the functionality if the program was not purchased and, due to numerous requests from users who wanted to try all the functions, we redid it, removing all restrictions and leaving only a reminder that the program could be bought to support its development.
5,731 (1.06/day)
West Midlands. UK.
I exited the program before I uninstalled it, it might have been added to auto load, that's regardless, when I exit the program and click uninstall I don't expect to have it start up again as normal upon next restart, surely you should have something written into the uninstaller to end all of the related processes and delete autostart entries when an uninstall takes place?
I'd defo prefer a time limited trial, even 7 days would be sufficient.
847 (0.35/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
Nice app. Will be nice to use something more sophisticated than the aging Fraps, which can cause issues in some games. Will try it out later. :)
Fraps? What kind of old man ancient tech is this????? :laugh:
22 (0.01/day)
System Name R7GE PC
Software Win10x64
Each user may have their own preferences, we understand that. But after 2.5 years of the program’s existence, I’ve heard for the first time the opinion that any restrictions (especially in terms of time) are good :) And yes, I don’t know about the problem with deletion either, although I have read thousands of reviews from 600,000+ thousand of our users. Sorry you had a problem.
Did you manage to remove the program?
3,364 (1.02/day)
Buenos Aires
System Name Ryzen Monster
Processor Ryzen 7 5700X3D
Software Windows 11 Start 11
I had to reinstall Windows a few weeks ago and all I'm getting now is 'Waiting for hardware initialisation' from FPS Monitor, so no info is being shown.
22 (0.01/day)
System Name R7GE PC
Software Win10x64
Win7?
Q: I have problems with FPS Monitor on Windows 7.
Most likely you need to install an update for 64 or 32bit Windows 7:
Or maybe you will find anser in F.A.Q.: https://steamcommunity.com/app/966610/discussions/0/2521353993645195444/
Deleted member 24505
How come it is £9.29 on steam and only $9.95 on the website? surely both prices should be the same.
22 (0.01/day)
System Name R7GE PC
Software Win10x64
Steam takes 30% :(
3,364 (1.02/day)
Buenos Aires
Win7?
Windows 10 x64
The problem is with an HWInfo conflict. If I quit HWInfo, the sensors show.
Is there a workaround, because I simply don't want to lose my HWInfo system tray sensors every time I run FPS Monitor?
1,092 (0.20/day)
Essex, England
Processor Ryzen 5900X OC 5150Mhz
Motherboard Asus ROG Crosshair VIII Formula
Cooling Custom EKWB for CPU, VRM's & GPU with 2x 480mm Rads
Memory Gskill TridentZ 3600 Mhz C17
Video Card(s) Powercolor RX 6900XT Liquid Devil Ultimate
Storage Samsung 970 Evo Plus 2TB x 2 Raid0
Display(s) MSI Optix MAG272CQR 27 1440p x2
Case Corsair 1000D
Audio Device(s) onboard 7.1 HD Audio
Power Supply Seasonic PRIME Ultra 1300w PSU
Mouse Logitech G300s
Keyboard Logitech G19s
Software Windows 10 64Bit
Benchmark Scores R20 : 9329 Timespy: 21455
Any news on G19s support?
Steam takes 30% :(
Guess that's why Valve don't make games anymore. It looks nice but i'm not paying nearly a tenner for something i probably wouldn't use much. I'm not really fussed about my temps anymore.
1,092 (0.20/day)
Essex, England
Case Corsair 1000D
Seems a bit unfair that you pass the costs of using steam as a distributor to your customers. Usually in business those would be costs you'd absorb :-/
22 (0.01/day)
System Name R7GE PC
Software Win10x64
I will ask about it :)
Windows 10 x64
We are working on it, but you can use FPSMonitor's vidget on your desktop.
We are just a small team of 3 people who are trying to make good software and at the same time feed their families. Prices are selected in such a way that the existence of the program would be justified and we could develop it further. And as you can see, in addition to the development, we support the huge (more than half a million) army of our users, most of whom use the program for free.
So the cost for me is about £3 more on steam than the website, I'll pass. It seems after you said was it 300,000 users, you must be doing more than enough to feed your families.
22 (0.01/day)
System Name R7GE PC
Software Win10x64
So the cost for me is about £3 more on steam than the website. I'll pass, it seems after you said was it 300,000 users, you must be doing more than enough to feed your families.
There are much more users, but this is the total number, not the number of those who purchased the license :)
3,364 (1.02/day)
Buenos Aires
I'd rather you fixed the HWInfo conflict, to be honest as I really don't want another vidget to play with.
14,376 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Nah, normal business practise, pass on all costs to the end user, nothing to see here.
