Fury X Display Corruption under low load
5,717 (0.94/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
You have my sympathies. Have you tried all the fixes suggested? Including HW accelerations etc
EDIT: unrelated but my Kingpin didn't work when I installed it but it was a mobo BIOS issue. Thought I had a £700 RMA on my hands
Yes. Disabling browser HW acceleartion along with ULPS completely stopped the problem. Also as OneMoar suggested. Manually set the card to 3D freq while enabling firefox HW mode also prevent the situation from happening again. So I am certain this problem has something to do with AMD's voltage scaling for the 2D clocks.
5,717 (0.94/day)
Are you on 15.9? Try a different driver. 15.9 seems to be especially prone to this.
When I first installed the card using Windows 7 Pro I never had any problem. That was with 15.20 driver. It has become more and more frequent after upgrading to Windows 10 Pro. Right now I am using 15.9.1.
1,927 (0.44/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
Try 15.8. I suspect this to be a win 10 thing. But nothing solid since I'm still on win 7 ultimate. Maybe try play with windows power settings for the GPU? It's obviously a power management issue of some kind.
4,286 (1.11/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
Well, if you have the problem solved for now I would say just wait and see what more sapphire can offer since you can at least use the machine normally. They may also get an updated bios that fixes the problem for you from them.
Another option, if you have a store that sells the cards nearby you can buy another and do a swap and return it.
3,802 (0.75/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
15.9 and 15.9.1 are the same sans the browser leak fix. Did you read the link I posted? Disabling hw accel in the browser won't stop the browser from using hw accel. You have to do it from rtss.
v12dock
Block Caption of Rainey Street
1,976 (0.34/day)
Same thing happens to mine. Plugging into a different display port seems to fix it everytime.
3,802 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
^^You can also change the desktop refresh rate to reset the ports, probably easier than physically moving the cable.
232 (0.07/day)
Dominican Republic
System Name Old but Gold
Processor A10-6800k : 4,700GHz@1.4v
Motherboard Asus F2A85 V-PRO
Cooling CoolerMaster Gemin 2 S524 with a modded crazy fan on it :D
Memory 8GB G.Skill RipJawZ @2400MHz Dual Channel; 10-12-12-31
Video Card(s) Clud3D R9 290 RoyalAce core@1077 mem@1350
Storage Dual 500GB Seagate Barracuda
Display(s) Asus VH198T Res 1440x900@75Hz, Aspect Ratio 16:10, 10000000:1 Contrast Ratio
Case Diablotek Predator
Audio Device(s) Onboard Realtek ALC892 Unlocked DTS and DD :) !!!
Power Supply Corsair CX750M
Keyboard Logitech Generic PS/2 Keyboard !
Software Win 10 Pro 64-Bit
Benchmark Scores 2,810 on Valley 1.0 Custom Preset: Ultra DX11 1080p 4xAA.
Something like this happens to me with my r9 290 at stock, i would get black screens at low loads (youtube videos, video players in general) and what i did to fix it was bumping voltage a tiny bit thou i dunno if that would help and it wouldn't hurt you try it out :)
Kanan
Tech Enthusiast & Gamer
3,517 (1.04/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
Well at least the Fiji cards are pioneers with HBM tech, so I wouldn't overly critizize them for it. It's normal that new tech isn't perfect at the start.
I switched from AMD to NVIDIA years ago and never looked back, since their products just worked better, with very little hassle.
I was a long(est) time NV user myself and had a HD 5850 after that and NEVER any problems with it or the GeForce cards (other than 2 being broken but thats normal I guess). I even used a HD 5970 for 2 years and despite it being a old crossfire card it worked good for me WITH overclocks. There's an old saying in germany: the problem is not the pc but the person sitting in front of it. Not saying you're an idiot or something, but more expertise clearly helps to not have any problems with any electronics or PC hardware. That said, AMD hardware is probably for the more experienced or skilled user, NV is more suited to the mass and since software like GeForce experience, even more.
I've since heard about enough issues like this with AMD products to never want to touch them again and there's been lots of talk lately on TPU and elsewhere about this company being driven into the ground. Put all this together and I wouldn't spend hundreds of dollars on their products just to get the shaft with crap like this.
You heard it and read it up? Wow. Such statements are clearly made to damage a company and boost your own ego. What you write has nothing to do with the topic and is of no help. Its just the same Fanboy-crap like the 15 year olds are doing, just that you sound a bit more mature, but thats just words. Plain sense of your words is the same - "AMD sucks, NVIDIA IS THE BEST!". And btw. I'd bet against you any day if AMD will survive or not. You and your behaviour is just bad and helps no one. Keep what you think and want to do, to yourself, at least until someone asks you about your opinion of AMD vs Nvidia, I'd say. Even after moderator deleted your posts you didn't stop, wow.
Sorry for offtopic. @OP: good luck with fixing it / geting a new card.
580 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Creative AE-9 w/ Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
I am making this post from my laptop since I can't use my desktop atm. I had this issue since launch when I bought my card locally. I tried the drivers, swapped cables, and even did the mentioned tweaks in this thread and the others. The issues are just all over, it happens on the desktop, it happens when using a web browser, I have had it happen in CS:GO sitting at the main menu, and now the latest issues I am having is with FFXIV, I will get randomly black screen flickering or a steady black screen while the driver is trying to recover itself. When I am watching a video with XBMC, I will get weird flickering horizontal lines through the screen.
I have been a long time AMD guy and this is the first time I have ever spent +$600 on a single card. Needless to say this is leaving a rather sour taste in my mouth. Suppose that's the way it goes when you are an earlier adopter.
Contacted my local store today about this and since they aren't getting any new Fury X's in anytime soon and Sapphire RMA is still a bit out, they made an exception and will let me exchange my card tomorrow.
I hope they do get this figured out but just knowing at any moment something can happen and they haven't locked down what it is exactly it is just yet. I am going to roll the dice with the Green team. I could downgrade but I mean when you pay X amount for any hardware, you shouldn't have to mess with it so much to get it stable and working.
Like a good majority here, I am all for tweaking, testing, and trying new things but it gets to a point where you just have to say enough it enough.
Working on PCs and other IT related issues all night at work, the last thing I want to do is come home and screw with my own stuff.
5,717 (0.94/day)
Did a clean install of Catalyst 15.10 beta. Screen distorted in less than 10 mins after installing new driver. After disabling ULPS the symptom is gone for now. I just forced 3D clock via the Sapphire Trixx.
This sucks. I was doing work, not browsing web, and this shi*tty problem just popped up again. I have to turn off the monitor, wait ~10 seconds and turn it back on for the screen to return to normal.
The strange thing is I can never find any dirver related issue in system log. If this happens more and more often I will press Sapphire for a replacement definitely. Spent $650 and I am not happy.
60 (0.01/day)
Processor AMD Ryzen 5 2600
Motherboard MSI B450M Mortar
Cooling BeQuiet! Dark Rock 4
Memory 16 GB DDR4 3333 MHz Kingston
Video Card(s) Sapphire RX Vega 56 Pulse
Case Fractal Design Define Mini C
Power Supply Seasonic Focus Plus 650W Gold
Correct me if I'm wrong but ULPS is for CF configs to disable the secondary GPU when idle/desktop, right ? So it won't make any difference with one card.
I have the artifacting issue with all drivers I even increased the lowest Powertune state voltage by 25 mV (0.9V -> 0.925V) and still the same....
3,802 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
Correct. ULPS is only for crossfire cards. Your artifacts, that is on the desktop I presume? Have you tried checking to see what app is calling for hw accel at the time of the artifact?
60 (0.01/day)
Yes, idle desktop or in a web browser.
Well, I've had it with Chrome, Steam and when none of them ran :D So I guess HW accelaration makes it happen more frequently but it's not the only reason.
3,802 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
Check this link out. It's a walkthrough for setting up AB and using it's RTSS server to control/disable hw accel. I've found that certain drivers can be more or less resistant to powerstate changes, so a lot of the time you have to take matters into your own hands. And you can also backup your profiles so you don't have to re-input settings with each new version, in the case that you have to wipe first, etc.
The AMD How To Thread
60 (0.01/day)
I've modded my bios/ccc settings to limit the power states, here are the PowerTune states with the default bios/settings:
DPM0: GPUClock = 300 MHz, VID = 0.90000 V
DPM1: GPUClock = 508 MHz, VID = 0.93100 V
DPM2: GPUClock = 717 MHz, VID = 0.93700 V
DPM3: GPUClock = 874 MHz, VID = 1.03700 V
DPM4: GPUClock = 911 MHz, VID = 1.07500 V
DPM5: GPUClock = 944 MHz, VID = 1.11200 V
DPM6: GPUClock = 974 MHz, VID = 1.15300 V
DPM7: GPUClock = 1040 MHz, VID = 1.25000 V
My custom profil for desktop tasks:
And still artifacting, I guess it's not an issue with the GPU power states or it's more complex.
3,802 (0.75/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
I think it's more productive avoiding the constant switching of states than to try to band aid it.
5,717 (0.94/day)
Got a new version of vBIOS from Sapphire today with UEFI support. It seems it has fixed my problem.
396 (0.08/day)
System Name potato
Processor Ryzen 9 5950X
Cooling Custom WC Loop
Memory 2x16GB G.Skill Trident Z Neo 3600
Video Card(s) RTX3090
Storage 512GB, 2TB NVMe + 2TB SATA || 32TB spinning rust
Display(s) XIAOMI Curved 34" 144Hz UWQHD
Case be quiet dark base pro 900
Audio Device(s) Edifier R1800T, Logitech G733
Power Supply Corsair HX1000
Mouse Logitech G Pro
Keyboard Logitech G913
Software win 11 amd64
would you upload it to tpu? i ordered my fury x and it should arrive at my door step soon, but i hope i wouldn't need to update the vbios
5,717 (0.94/day)
I tried, it said it already has this version. Weird. When I try to upgrade from the BIOS here at TPU none of those work.
Kanan
3,517 (1.04/day)
Europe
VR HMD Still nope
Glad your problem got fixed. Have fun with the card.
I think this has to do with the naming. You need to upload it under a different name if possible, then it could work. I think the Sapphire bios found on TPU are the older ones and the system thinks you're trying to upload the same one.
60 (0.01/day)
I think it's too early to tell... My Sapphire Fury "once" worked fine for 2 weeks.
5,717 (0.94/day)
So far so good. I like the UEFI secure boost function. It boots up way faster now.
396 (0.08/day)
System Name potato
i have received my card and all seems good - it's msi, non UEFI
60 (0.01/day)
Can you upload the new vBIOS file ? I asked Sapphire support about a new bios but they keep sending me registry files to reset my CCC settings instead :D
