G.Skill Launches 24 GB Memory Kit with DDR3-2000 MHz, CAS 8T
43,060 (6.72/day)
bet ya these are much more stable than the ones Corsair have recently launched.
cauby
121 (0.02/day)
Brazil
System Name The New One
Processor Intel Core i5 750@2.67 GHz
Motherboard MSI-P55-CD53
Cooling Intel HSF
Memory Kingston 4GB (2x2GB) 1333MHz DDR3 CL9 Value
Video Card(s) Sapphire HD5770 1GB GDDR5 Vapor-X
Storage WD 1TB Green 64MB Cache
Display(s) Samsung SyncMaster 2233 1920x1080 21,5"
Case CoolerMaster CM 690
Power Supply 500W OCZ SXS
Software Windows 7 Ultimate Edition 64-bit
while I may not even como close to one of those kits ever in my life,it's still very,very impressive.Decent latency,frequency and quantity!
Mussels
Freshwater Moderator
58,413 (7.89/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
technically 32bit can address 2^32 = 4,294,967,296 bytes of memory, or 4 gb of ram
its limited further in windows operating systems.
ebolamonkey3
773 (0.14/day)
Atlanta/Marietta, GA
System Name Norbert
Processor Intel Core i7 920
Motherboard Gigabyte X58A-UD5
Cooling Corsair H50 with 2x Scythe GT AP-14
Memory 3x 2gb G.Skill 1600Mhz C9 DDR3
Video Card(s) MSI Twin Frozr II GTX 465 GE & EVGA GTS 450 SC
Storage 2x 1Tb Samsung Sprinpoint F3 7200rpm
Display(s) Dell U3011, Dell 2408WFP, Samsung 2693HM
Case Lian Li V1020R
Audio Device(s) Creative X-Fi Titanium
Power Supply Seasonic X-750
Software Windows 7 Ultimate 64bit
650w was overkill as it was...
An HD5870 is only going to consume at most 145w, the 980x will consume 130w, the 2TB drives consume less than 20w max. Full load your looking at maybe 450w max.
And there really isn't a point to a $100 case, the $40 case cools similar rigs without issue.
Alright, well who's up for a $3500 virtual server w/ 24gb of uber fast ram then?
mdsx1950
2,064 (0.37/day)
In a gaming world :D
System Name Knight-X
Processor Intel Core i7-980X [4.2Ghz]
Motherboard ASUS P6T7 WS
Cooling CORSAIR Hydro H70 + 2x CM 2000RPM 120mm LED Fans
Memory Corsair DOMINATOR-GT 12GB (6 x 2GB) DDR3 2000MHz
Video Card(s) AMD Radeon HD6970 2GB CrossFire [PhysX - EVGA GTX260(216SP) 896MB]
Storage 2x Corsair Perf. 512GB | OCZ Colossus 1TB | 2xOCZ Agilities 120GB SSDs
Display(s) Dell UltraSharp™ 3008WFP [2560x1600]
Case Cooler Master HAF-X + NZXT Temp LCD
Audio Device(s) ASUS Xonar D2X | ONKYO HTS9100THX 7.1
Power Supply Silverstone ST1500 1500W [80 PLUS Silver]
Software Windows 7 Ultimate X64 (Build 7600)
Benchmark Scores Heaven 2.0 with Extreme Tessellation at 1080p - 96FPS
Its time to get rid of 1600Mhz ram and switch to 2000Mhz :D
Mussels
58,413 (7.89/day)
Oystralia
What 1T can't handle it or what? it has support for that so...
1T never works with all slots occupied on a motherboard. (or if it does work, its bloody uncommon/JEDEC clocks only)
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
That depends on the memory controller and RAM. My main rig has all the slots occupied, and runs 1T just fine at 1600MHz(which isn't a JDEC standard). I even have one stick that is rated for 2T, and it still works I just have to force it. This is because the IMC on the i7 processsors can handle the 1T with all the slots filled, usually even with 6 slots filled on the 1366 sockets(though sometimes not at higher speeds than 1600MHz).
On the other hand, AMD's IMC is known for being weaker, and does struggle to run memory at 1T when all 4 slots are filled, in fact in the past it stuggled to even run the memory at full speed when all 4 slots were filled. I remember the 939 processors IMC was notorious for dropping the RAM down to 2T and 333MHz when 4 sticks were present. I seem to remember even their recent processor having issues with running RAM at proper speeds when all 4 sticks are present, but I'll have to check on that.
My 780i/P45/P35/965P boards, with the memory controller on the chipsets, could run 1T with 4x1GB sticks of RAM rated for 1T, but not with 4x2GB sticks rated for 2T.
I've got a client that is very close to using the 12GB in their server right now, but I don't think they will be buying this kit, as it would be too expensive, and the extra speed wouldn't really benefit them. I think they are going to have me order another 12GB 1333MHz kit here in the next few weeks.
Mussels
58,413 (7.89/day)
Oystralia
i've never managed all slots with 1T before, not since the socket A days. you may well have it working, but i said it does, sometimes. Congrats on getting a good IMC + great ram.
You do make a good point on 1GB sticks vs 2GB sticks, the lower the density the easier it was to achieve.
4,267 (0.67/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Not many? Most would be disappointed by the limitations in even the most advanced GPU virtualization offered today. (but it is getting better)
Take 3D out of it and a multi-user box can be done pretty cheaply. At my last job I wrote up a proposal for a machine to replace our five aging training stations. Xeon L3426, 8GB, two cheap video cards (+onboard) for five outputs, some hard drives, Linux host, and we had some leftover XP licenses so the total was under $1200. Would have sipped power and been incredibly fast for it's purpose.
$3500 could buy a fairly beefy server for dozens of remote virtual clients or one with some 3D support.
newtekie1
Semi-Retired Folder
28,473 (4.07/day)
Indiana, USA
Have you used a lot of Intel stuff? Because I've never had a problem getting 1T with all the slots filled on the Intel side w/ Intel Chipsets when the RAM supported it. I've only had major issue with AMD managing 1T(and correct clocks) with all the slots filled.
AMD's memory controller has been plagued with issues when running 4 sticks, it has been since the regular DDR IMC on the 939 socket, actually even the 754 socket IMC had issues.
Mussels
58,413 (7.89/day)
Oystralia
yeah i was heavily intel until this current system. maybe i just have access to lower end stuff than you :p
wolf
Better Than Native
8,333 (1.29/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte X650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
PCpraiser100
1,062 (0.18/day)
System Name REBEL R1
Processor Core i7 920
Cooling Stock
Memory 6GB OCZ GOLD TC LV Kit 1866MHz@1.65V 9-9-9-24
Video Card(s) Two Sapphire HD 5770 Vapor-X Xfire'd and OC'd (920/1330)
Storage Seagate 7200.11 500GB 32MB
Case Antec Three Hundred
Audio Device(s) ASUS Xonar D1 PCI Sound Card
Power Supply OCZ StealthXStream 500W
Benchmark Scores 16585 Performance Score on 3DMark Vantage
