Gaming laptop frametime ms and intermittent micro-stutter
Snooze_88
6 (1.50/day)
Happens in virtually every game. The stutter also happens on another high-end laptop I own. What's going on? Is this normal?
Here's some examples:
This reddit post is also pretty similar to what im currently experiencing: https://www.reddit.com/r/GamingLaptops/comments/1c7v9e3
42,836 (6.70/day)
They all suffer
Are you using afterburner?
Snooze_88
6 (1.50/day)
They all suffer
I ditched the laptop and built a desktop instead. Thanks anyway.
13,396 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Wise move. Despite the marketing hype suggesting otherwise, it is just that, hype. If you consider even a decent tower case is challenged to keep the internal components properly cooled, it is no wonder a tiny laptop case would be inadequate. A similar argument can said for the PSU.
IMO, there just is no such thing as a good "gaming laptop" (for serious gamers of the latest, demanding games) or "desktop replacement" laptops. Manufacturers can pack the horsepower of a PC into those tiny cases, but not the necessary cooling to keep them running at full throttle.
Then of course, there's the issue of a full size keyboard, mouse and multiple large screens - but that's for a different discussion.
10,863 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 1:1 CL30-36-36-76 FCLK 2200
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
That stutter @eidairaman1 showed looks exatly right, and will do the same thing on a desktop, so good to know either way.
Snooze_88
6 (1.50/day)
Ok, so, I tested games on my new desktop and it's does THE EXACT SAME THING WITH THE STUTTER. what is going on!?
Snooze_88
6 (1.50/day)
I already disabled Afterburner's power monitoring as well as resizable bar, HAGS, bitlocker.
Can somebody please explain? Is it windows 11? I'm desperate at this point....
13,396 (1.99/day)
Nebraska, USA
Mouse Logitech M190
If it does this with multiple computers in the same house, I would be looking at the network and/or internet connection.
4,693 (0.95/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
not win 11, is this the only game you tested so far on the new desktop?
85 (0.21/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4300
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative P580 speakers, Sennheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
UE5 engine. Yeah, it sucks.
13,396 (1.99/day)
Nebraska, USA
Mouse Logitech M190
My computer is connected through ethernet.
That does not eliminate the possibility of network issue. It only means wifi is not the problem.
