- Apr 18, 2019
- 2,978 (1.31/day)
- PNW, USA
System Name | Metalia |
Processor | AMD Ryzen 7 5800X3D |
Motherboard | Asus TuF Gaming X570-PLUS |
Cooling | ID Cooling 280mm AIO w/ Arctic P14s |
Memory | 2x32GB DDR4-3600 |
Video Card(s) | Sapphire Pulse RX 9070 XT |
Storage | Optane P5801X 400GB, Samsung 990Pro 2TB |
Display(s) | LG 32GS95UV 32" OLED 240/480hz 4K/1080P Dual Mode |
Case | Geometric Future M8 Dharma |
Audio Device(s) | Xonar Essence STX |
Power Supply | Seasonic Focus GX-1000 Gold |
Mouse | Attack Shark R3 Magnesium - White |
Keyboard | Keychron K8 Pro - White - Tactile Brown Switch |
Software | Windows 10 IoT Enterprise LTSC 2021 |
This is a great opportunitly for a transition to a higher voltage (or rather, a non-fixed voltage). It's now or never. But obviously it's going to be wasted.
Because you'll still need 12v for CPUs, fans, ece, so you are only introducing more standards that would need new power supplies, motherboards, and additional VRMs added to already expensive components.
This would make more sense in a new form factor altogether, one that uses blade connectors for the PSU as well, much like data center PCS. It eliminates the cable problem altogether.
Im not just talking for GPUs, Im talking for everything. So everything moves over to 24v. You could design in "compatability" with existing 12V supplies into the newer VRM/voltage controllers similar to how PSUs have active correction for voltages between 100 and 250.
Only have an older 12V supply? It draws double the current up to a set amount. Have a newer supply? Then use things like the sideband connectors in the 12VHPWR or sense capabilities in the regulators.
Hell the current 24 pin ATX connectors has a non used pin that could be a sense/communication pin for that exact purpose as the -5v it was intented for was removed in 2004 from the ATX spec. IMO the AXT12VO was a missed opportunity to move us into the 21st century in this aspect.
In the industrial fan world, +24V fans are as common as +12V fans and more efficient -- the datasheets indicate less power is used to power a +24V fan than a +12V fan of the same model type, but this seems to be only true for really powerful industrial fans that you would never use in PC unless you were deaf.
We are not building industrial PCs. We are building consumer PCs. Why not move to 120v equipment, since that is also used in industrial applications?
so, your suggestion to the cost issue is to design transformers into motherboards to step up voltage from 12v to 24v? Do you know how expensive/ space consuming that would be?
Absolute genius!
Also, hilariously you mention the "21st century" while ignoring that the 24 pin ATX connector is a 21st century occurrence. 1990s machines had either the old 6+6 pin or the 20 pin connector.
I see what TheinsanegamerN is saying, it would have to be a whole new standard to use +24V power. Supposedly switching VRM's are more efficient the higher the voltage differential between source and output and power losses due to i^2*R losses would less at +24V than +12V so maybe it would be better to settle on a newer, higher voltage standard, maybe even higher than +24V. I believe Noctua, Nidec, Delta, Sunon, SanAce already make +24V, PWM speed-controlled fans. At higher voltage you might be able to get away w/less leads too (since the current will be less), so maybe the 24-pin power connector could go back to being 20-pin and the 8-pin supplemental power connector could go back to being a 4-pin.
No. Im saying we design the boards slightly different and source slightly different power stages etc.....
You do realise a LOT of the stuff we have out there is actually fairly wide ranging in terms of voltage input?
AOZ5311NQI-03 - Currently a favoured power stage in 4xxx series GPUs
AOZ5616BQI - A possible drop in replacement to be able to utilise a 24v source.
Same Output ratings, same packaging. PWM signals would have to be reworked from 5V currently to 3V. Which may actually simplify circuitry as there is no 5V source for Graphics cards directly from Mobo or cable currently.
Guess what, both of those above power stages accepts 12 Volts. Only the bottom one would support 24. So its there, just needs a little work from the PSU. Mobo, graphics makers etc etc etc to come to an agreement on a standard to enable a transition from 12V currently to 24V in the future. Maybe the use of sideband connectors on top of existing ones would be viable similar to what Nvidia did in the power delivery of the 4xxx series. No sideband connectors means the board expects 12V, sideband connectors can then be used to confirm voltage supplied from PSU is 24V.
There's a way to avoid changing an ENTIRE industry to get +24V to a single high-wattage device. In fact, we just need to look through
Make "-12V" required, not optional.
just invert an independent +12V Rail, already common in PSUs.
Plus, GPUs already have separate power planes; one from the slot, one from auxiliary 6/8/12-pin input(s)
DC Transmission and Distribution
Though a.c. is extensively used everywhere, there are few applications like operation of d.c. motors, batteries, charging where d.c. suppl...
I may not be a big fan of Thomas Edison, but he (and the big brains w/ big pockets that standardized US Mains Power) already figured this problem out:
Edison 3-Wire Power Distribution - https://pubmed.ncbi.nlm.nih.gov/17757744/
Comparison of Conductor Material in Overhead System
In comparing the relative amounts of Conductor Material in Overhead System necessary for different systems of transmission, similar conditions will be assumed in each case viz.,
