GDDR6 GeForce RTX 4070 Tested, Loses 0-1% Performance Against RTX 4070 with GDDR6X
Kasy21
13 (0.03/day)
G6 uses less power than GDDR6X because its slower
Not really, the GDDR6X on my 4090 sits at like 60-65C in demanding games, meaning 100% gpu usage
yeah a 4090, but I was refering to the cooler on something like a cheap aib model of a 3060ti, in the case of some cheap 4070, that are made by some companies they have weaker cooling solutions, is not un common to have some companies to skimp in the colling departement, like not having thermal pads in the memory modules
las
1,693 (0.38/day)
System Name Meh
Case Fractal Design North XL
Audio Device(s) FiiO DAC
Not a problem at all - https://www.techpowerup.com/review/msi-geforce-rtx-4070-gaming-x-trio/37.html
3060 Ti did not use GDDR6X, only 3070 Ti did in the 3060/3070 range
TjMax for GDDR6X is like 95-100C some even list 110-120C but most cards runs them in the 60-80 range
6,124 (0.84/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
This begs the question: why did Nvidia release the 4070 with GDDR6X and not non-X in the first place? Artificial price markup? Bragging rights?
Wasn't G6X significantly faster (in terms of clock speeds) at the time, and G6 has only recently caught up?
14,440 (6.48/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
Maybe. As G6X is just a slightly faster spinoff version of G6, I never paid much attention to it.
418 (0.36/day)
Denmark
Processor AMD Ryzen 7 3800X
Motherboard ASUS Prime X470-Pro
Cooling bequiet! Dark Rock Slim
Memory 64 GB ECC DDR4 2666 MHz (Samsung M391A2K43BB1-CTD)
Video Card(s) eVGA GTX 1080 SC Gaming, 8 GB
Storage 1 TB Samsung 970 EVO Plus, 1 TB Samsung 850 EVO, 4 TB Lexar NM790, 12 TB WD HDDs
Case Corsair Obsidian 550D
Audio Device(s) Creative X-Fi Fatal1ty
Power Supply Seasonic X-Series 560W
Keyboard Glorious GMMK
Seems like nVidia saves some money on this. Probably the manufacturers as well. The ones who won't benefit from the cost savings are the consumers. But hey, at least LJM can buy a couple more jackets...
99 (0.11/day)
Power efficiency should be checked at the same memory clock speed, otherwise, people might get the wrong assumption that GDDR6 is more efficient when it's only about the GDDR6X clock much past the efficiency sweet spot.
9,679 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Didn't GDDR6X run hot AF, I heard that in 3000 cards this memory type run much hotter
They also just had crap cooling for the memory.
3,506 (1.12/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
As expected. The main question is how this affects power efficiency. Can you squeeze even more FPS per W with G6?
It's 4% in HWUB's bench, which turns out to be almost as much as the reduction in bandwidth:
To me this indicates that the 4070 is definitely memory bottlenecked in some titles, because if it wasn't you wouldn't have seen a near 1:1 drop-off in performance.
Mind you the performance difference is really besides the point, the fact remains that Nvidia is using cheaper, slower memory while not passing the savings onto the customers or making it clear in the model name.
The 4070 GDDR6 model consumes 1.52% less power while being 4% slower. It also consumes more power at idle. So overall a small reduction in efficiency.
3,598 (4.96/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
That's because they can get away with it. Too obvious to discuss.
Not great. At least I know what GPU to avoid, unless the price is really good.
1,202 (0.72/day)
System Name Gamey #1 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 ProVDH M
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) Ventus 3060 / Challenger B580
Storage 4TB Team MP34 / 2TB WD SN570
Case Corsair 4000Air / TT Versa H18
Power Supply EVGA 650 G3 / EVGA BQ 500
They tested a Gigabyte AIB card vs the Founder's Edition 4070 (as there's no Founder's of this DDR6 version of course) and if you look at W1zz's tests of various AIB models, the idle power usage can vary model-to-model by around the 2W listed here. Same goes for the load power usage, these are both within model variation so there's little to conclude here.
Also the fps reduction at 1440p where this card's likely to be used is only 3% in their testing. 4% is at 1080p, not really a primary use case for this GPU.
Still with seemingly no price reduction from the GDDR6X model, this provides consumers with a slightly lower value product.
3,506 (1.12/day)
Mouse PMM P-305
VR HMD Valve Index
Software Win 10
The 4070 GDDR6 tested in the video is a mere 15 MHz higher clocked than a reference 4070: https://www.gigabyte.com/Graphics-Card/GV-N4070WF3OCV2-12GD/sp#sp
So for all intents and purposes it is a good comparison to the reference model.
FYI a small difference doesn't mean there's nothing to conclude. You are throwing shade on every model variant review with a comment like that. You could perhaps advise waiting for a larger sample size but small doesn't inherently mean the data isn't informing of a genuine difference.
1,202 (0.72/day)
Yes, I'm very much pointing out that every model variant is subject to variations that are larger than shown in the HUB video. For example, Asus Dual 4070 Super vs the FE 4070 Super, both use stock Nvidia clocks:
4W difference in idle. And I wouldn't be surprised if 5 different samples of both the FE and the Asus Dual overlap in idle power. Same goes for load power. Too little data in any of these examples to make conclusions so IMO all within normal variance until proven otherwise. I'd love to see a HWInfo chart of the GDDR6 vs GDDR6X power use difference in the two 4070s though so see what the actual difference in power draw is.
1,084 (0.68/day)
System Name Laptop ASUS TUF F15 | Desktop 1 | Desktop 2
Processor Intel Core i7-11800H | Intel Core i5-14600K @ 95W P-Cores only | Intel Core i3-10100
Motherboard ASUS FX506HC | Gigabyte B660M DS3H DDR4 | MSI MAG B560M Bazooka
Cooling Laptop built-in cooling lol | i9-12900 stock box cooler | Intel black stock box cooler with copper
Memory 24 GB @ 3200 | 16 GB @ 3600 | 16 GB @ 3200
Video Card(s) Nvidia RTX 3050 Mobile 4GB | Nvidia GTX 1050 Ti | Nvidia GTX 960 2 GB
Storage Adata XPG SX8200 Pro 512 GB | Samsung M2 SSD 256 GB & 1 TB 2.5" HDD @ 7200| SSD 250 GB & SSD 240 GB
Display(s) Laptop built-in 144 Hz FHD screen | Dell 27" WQHD @ 75 Hz & 49" TV FHD | Samsung 32" TV FHD
Case It's a laptop, it doesn't need case lmfao | Deepcool Mattrexx 55 MESH | Aerocool Cylon PRO
Audio Device(s) laptop built in audio | Logitech stereo speakers | Logitech 2.1 speakers
Power Supply ASUS 180W PSU | SeaSonic Focus GX-550 | MSI MAG A550BN
Mouse Logitech G604 | Corsair Harpoon wired mouse| Logitech G305
Keyboard Laptop built-in keyboard |Razer Blackwidow | Steelseries APEX 7 TKL
VR HMD Quest 2 sold out and don't need VR anymore lol
Software Windows 10 Enterprise 20H2 | Windows 11 24H2 LTSC | Windows 11 24H2 LTSC
Benchmark Scores good enough
