GeForce GTX 580 Expected to be 20% Faster than GeForce GTX 480
SNICK
85 (0.02/day)
System Name Good as Hell
Processor intel core i7 950
Motherboard asus p6t
Cooling stock
Memory Corsir TR3X6G1600C9 6GBKit
Video Card(s) nvidia geforce 9300ge
Storage 500gb seagate
Power Supply corsir 650hx
FYI, Fermi cards are based only on 2 type of clusters, GPC and ROP partitions, every card is just a conbination of the two. .
GPC = SPs + TMUs + rasterizers + setup engines + tesselators (Polymorph) + L1 cache
ROP partition = ROPs + memory controllers + L2 cache
When something increases everything increases by the same amount as long as the GPC is equal. GF100 and GF104 GPCs are different.
You want me to speculate power consumption based on ROP partitions?
GF104 = 2 ROP partitions = 155 W
GF110 = 3 ROP partitions = (155 x3) / 2 = 232 W
Other than silicon increase the only thing that affects power consumption is clock speed which I speculated is going to be the same more or less, and that it won't affect too much: as can be seen on the chart I provided @820 Mhz (quite an OC) the power is 176 W.
your whole mathemetics based on unitary method is not supposed to be used on electricals components.TDP of FULL gf100 is around 204 watts more than gf100.based on your mathematics can you explain why the TDP OF FULL GF100 IS QUITE MORE AS EXPECTED?
DarkMatter75
13 (0.00/day)
Do i have to buy a dedicated AC unit from APC to use the new card???
Bye bye NVidia...
Benetanegia
2,680 (0.47/day)
Reaching your left retina.
Do you really believed that to be real? That was not coming from Nvidia. How naive can you be? First of all the revision code (A1, A2, A3) was not shown so that card if it was real was probably an old prototype card using A1 or A2 silicon and why did Nvidia use A3? Ah yes, because A1 and A2 were broken. Other posibility is that they re-enabled a normal GTX480, and oh yes, there was a reason that SM was disabled...
If you want to know more exactly how enabling SPs/ROPs trully affect power consumption on real cads, then look at GTX470 vs GTX465, because they both have the same clocks. And how much is that then again?
GTX465 = 199 W
GTX470 = 232 W
Let's experiment with that:
GTX465 = 352 SP ; GTX470 = 448 SP
GTX465 = 4 ROP Partition ; GTX470 = 5 ROP partition
Ficticial GTX470 = (199 W x 448) / 352 = 253 W hmm
Second Fictional GTX470 = (199 W x 5) / 4 = 248 W hmm
wow so it looks like actual power consumption of actual GTX470 is lower than my math. I knew that from the beginning, my assumptions above are for worst case scenario.
GF100 consumed a lot, everybody knows that. Everybody should know by now too, that it was a problem with the fabric (interconnection layer between the different units within a chip) and that the problem has already been fixed. It was mostly fixed for GF104 as can be seen by its power consumtion and is probably even better for other future releases.
1Kurgan1
The Knife in your Back
10,421 (1.75/day)
Duluth, Minnesota
System Name My Comp | Fiancees Comp
Processor i7 5820k @ 4.6Ghz 1.285v| i5 2500k
Motherboard MSI x99 SLI Plus | AsRock Z77 Pro 3
Cooling Watercooled
Memory 16GB DDR4 2400 @ 2666 | 12GB DDR3 1600
Video Card(s) AMD R9 290x | MSI 5850 OC
Storage 128gb SSD + 2x 2TB | 2TB
Display(s) Asus 27" LCD | 25" Hanns G
Case CM Storm | CM Elite 430
Audio Device(s) Creative Recon 3D PCIe
Power Supply Enermax Galaxy 1250W | Rosewill 630w
Mouse Logitech G700s | Logitech G100s
Keyboard Logitech G901 | Logitech G105
Software Win 8.1 Ultimate x64 | Win 8.1 Ultimate x64
Benchmark Scores 3D Mark - Fire Strike Extreme - 4403
Panic news to make ATI's new cards not get so much attention, makes me sad, not a real NV fan myself, but some better competition on releases would be better for price drops.
4,686 (0.75/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
They must be upping the clock speed a lot. We already saw that going to 512 shaders alone only adds 5%, and I don't think the memory bandwidth is going to add the other 15%. Managing that in the same power consumption as the 480 might actually have taken a lot of work.... assuming their claims aren't total BS.
MxPhenom 216
ASIC Engineer
13,143 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
Wait, 20% faster than a 480 is like a 5870 oc'd (well something more) but it is definetly slower than a promised 6870... They are not even getting even on paper now?
what are you on? can i get some of that?? the hd5870 cannot even hold ground against a non overclocked GTX480. a 20% faster GTX480 will annihilate the HD5870 and HD6870. remember the 6870 isnt a hd5870. its basically a 5850. amd naming is relaly messed up with this generation
And for people who are obsessing over the potential high heat and consumption. Just wait and see, its not worth getting all worked up about it now. Maybe nvidia has new strategies to over come this. Better reference coolers perhaps
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
Woot, TPU's heavy bias comes out the wood work again! *fist pumps*
Hopefully they can up the performance when it actually comes out, it's still WAY to early to tell anything.
Benetanegia
2,680 (0.47/day)
+1
It's really sad tbh, sadder every day. Every day that passes is more difficult to talk about tech.
If only GTX460 had never been released, then maybe, maybe, the comments wouldn't be so baseless. But the GTX460 was released and it's faster than the GTX465 while consuming 50 W less... Is it posible for Nvidia to repeat that achievement with GF110, or maybe even... take a sit AMD fanboys... further improve the efficiency a little bit?
- No, because I'm so biased I cannot even see what's in front of my eyes.
- No, because AMD has apparently improved power efficiency further with NI, but there's no way on Earth or otherwise for Nvidia to catch up. Imposible! I mean, Nvidia never had better power efficiency than AMD/Ati. Never, never, never... hmm well... hmmmmokey "only" before Evergreen/Fermi. :rolleyes:
bear jesus
1,534 (0.29/day)
Britland
System Name Gaming temp// HTPC
Processor AMD A6 5400k // A4 5300
Motherboard ASRock FM2A75 PRO4// ASRock FM2A55M-DGS
Cooling Xigmatek HDT-D1284 // stock phenom II HSF
Memory 4GB 1600mhz corsair vengeance // 4GB 1600mhz corsair vengeance low profile
Storage 64gb sandisk pulse SSD and 500gb HDD // 500gb HDD
Display(s) acer 22" 1680x1050
Power Supply Seasonic G-450 // Corsair CXM 430W
+1
You just need to laugh at the stupidity and remember thats all it is, if the amd fanboys are so interested in power draw why are they not complaining about the over 300w tdp of the 5870x2 cards? (no not the 5970 i mean the ones with the speeds fo the 5870) things with 2 8 pin and one 6 pin?
I'm no fan boy for either side as they both suck in their own special ways and are both awesome in the ways as well, and although stupidity annoys me i can ignore the stupidity in the fanboy comments for both amd and nvidia..... how about you 2 join me in laughing at the stupidiy? :roll::laugh::roll:
Back on topic i'm really excied about seeing what nvidia will be bringing out, i just hope its very close to the 6970's release date as im sick of waiting for my gpu upgrade and im starting to think i would want something more powerful than 1gb 460 sli so hopefully either amd or nvidia can give me something that fits the bill and before the end of the year.
396 (0.07/day)
System Name Just A Gaming Rig.
Processor AMD FX-8320 @4.1GHz, 1.268V
Motherboard ASUS M5A97 Evo R2.0
Cooling Cooler Master Hyper 212 Evo
Memory 8 GB Crucial Ballistix Sport 1600MHz
Video Card(s) Club 3D R9 280X 3GB royalQueen, @1115/1615MHz
Storage OS+Often used stuff: Kingston SSDNow V300 120GB, Mass storage: WD Blue 1TB
Case Zalman Z3 Plus
Audio Device(s) Integrated
Power Supply Corsair CX600M
Software Windows 8.1 64-bit
I believe this is just Nvidias PR trying to damper AMD's launch. I sure hope Nvidia could put something out there to compete with Cayman, because it would definitely help bring the prices down. But somehow it's hard to believe Nvidia has got anything to counter Cayman and Antilles... Well, we'll see.
5,966 (0.93/day)
New York
Processor AMD Ryzen 9 9900x / AMD Epyc 7773x
Motherboard Gigabyte B850 Gaming X/ ASROCK ROME
Cooling Be Quiet Dark Rock Pro 4(Custom) / Custom Air
Memory 64GB Crucial Pro 6400 / 384GB
Video Card(s) Gigabyte RTX 3080 / Radeon Instinct
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Lian Li A3 Mini
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus/ Quest 3
damn, im truly disappointed to hear this
but it should make it so both companies have cards with similar performance at least, somewhat unlike now.
+1
http://tpucdn.com/reviews/MSI/N480GTX_GTX_480_Lightning/images/perfwatt_1920.gif
wow that review shows that the HD5450 is the fastest card O.O
did you change that yourself
43,627 (6.38/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Love it. Just because a majority of people (pretty much across the internet) feel one way, it's bias. Of course, you're just a "fanboy" for pointing that out. It's all tounge and cheek, but it's either bias or the unwillingness to accept the truth from one "side" or the other. Fact of the matter is, Nvidia has failed to impress many.
bear jesus
1,534 (0.29/day)
Britland
That's performance per watt, so not really relative to what card is fastest.
wolf
Better Than Native
8,654 (1.32/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
Again a thread full of smack talk for a GPU we know next to nothing about, bar a few who actually have something to contribute. ohwell, can't say I'm not dissapointed.
I have a feeling this will just be a GF104 + 50% of it again, making it 576sp, back to 48 ROPS, and still 384-bit GDDR5, they just need to improve the memory controller, and make sure they hit a good power consumption target.
50 (0.01/day)
Los Angeles, CA
System Name Akuma, Iluminati
Processor 2 x Intel i7 4930K @ 4.6GHz
Motherboard 2 x Asus Rampage IV Gene
Cooling 2 x Corsair H110 Push-Pull
Memory 2 x Mushkin Ridgeback Redline 16GB @ DDR3-2400
Video Card(s) 2 x EVGA GTX 670 FTW SLI, EVGA GTX 650 Ti Boost
Storage 2 x Intel 320 120GB RAID0, 2 x Intel 520 180GB RAID0, TOO MANY MORE TO LIST!
Display(s) Asus PB298Q, 2 x Asus VH236H
Case Custom Tech Bench, Antec 300 Illusion
Audio Device(s) 2 x Onboard Soundblaster X-Fi III
Power Supply Corsair HX1000, Rosewill 1000w
Can you read? It says "Performance per Watt"! That has nothing to due with total performance. Geesh!
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
Cooling Corsair H70
Offering constructive criticism is no issue at all, everyone should be able to point out mistakes and criticize it in hopes of future improvements. Look around, nothing but nonsensical counterproductive comments yet again from a site that i frequently visit, the majority can say whatever BS they want, but i honestly expect more out of sites like this.
cadaveca
My name is Dave
17,232 (2.48/day)
No doubt. Considering all the problems I've been complaining about on here, you'd think nV would be "my best friend" at this point, however, the Fermi launch put a big damper in thier hype, and nothing since then has really done much to improve consumer confidence, as evident in the shift in gpu marketshare.
They need a killer product. 20% over GTX480 doesn't cut it....they need 33% or so...then they'd have a real chance.
Mind you the current rumour about price drops is definately gonna work in thier favor.
bear jesus
1,534 (0.29/day)
Britland
To be honest i don't understand how you don't hate AMD at this point :laugh: i'm pretty sure i would by now if in your position.
43,627 (6.38/day)
What BS? A lot of it is not false, though a lot of it is quite short-sided or just blunt. I can say that I'm not particularly impressed with certain things on both sides of the coin.
Mindweaver
Moderato®™
8,425 (1.44/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z790-A Gaming WiFi II / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR - VENGEANCE RGB 32GB (2x16GB) DDR5 7200MHz / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Razer Deathadder V3 Hyperspeed Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (512gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
20% sounds nice... I just wonder how much room was left for overclocking? I mean 20% on a 480 should be achievable on a 480, but how much more can you push it?.. I guess time will tell. A 580 that is 20% faster than a 480 plus being able to push it another 20% would be kickass! I don't know... i hope so for everyone.. We need both to do well to keep price's right. you know?
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
Cooling Corsair H70
In terms of the BS posts that contribute nothing to the discussion yet don't get regulate on. And for some reason always fill up certain threads...
No ones denying Fermi's issues. But as you even said, both sides have their issues.
cadaveca
My name is Dave
17,232 (2.48/day)
Well that's just it, isn't it?
Both sides kinda have issues, and so really, I blame TSMC.
Bear Jesus, while I can afford to just get rid of stuff and start over again, to me, that'd make all the time I've spent trying to get things working a waste of time. As far as I am concerned, either AMD fixes the issues I have, or they fail. I can't truly say that unless is see this out to the end.
But, because my usage(3 monitors) dictates I need a certain level of performance, I'm just plain out of options at this point. The 69xx-series is my last hope, or maybe this GTX580 can pull up nV's socks, and I'll switch over.
I am not "sticking it out" because I'm a fanboy...I need 60+FPS, and @ 5870x1080. A little bit of AA would be nice too. The first company that can do this, gets my cash.
For anyone else...they don't need GTX580. Seriously...a 480 is more than enough power, for anyone with a single monitor.
963 (0.18/day)
System Name Little Boy / New Guy
Processor AMD Ryzen 9 5900X / Intel Core I5 10400F
Motherboard Asrock X470 Taichi Ultimate / Asus H410M Prime
Cooling ARCTIC Liquid Freezer II 280 A-RGB / ARCTIC Freezer 34 eSports DUO
Memory TeamGroup Zeus 2x16GB 3200Mhz CL16 / Teamgroup 1x16GB 3000Mhz CL18
Video Card(s) Asrock Phantom RX 6800 XT 16GB / Asus RTX 3060 Ti 8GB DUAL Mini V2
Storage Patriot Viper VPN100 Nvme 1TB / OCZ Vertex 4 256GB Sata / Ultrastar 2TB / IronWolf 4TB / WD Red 8TB
Display(s) Compumax MF32C 144Hz QHD / ViewSonic OMNI 27 144Hz QHD
Case Phanteks Eclipse P400A / Montech X3 Mesh
Power Supply Aresgame 850W 80+ Gold / Aerocool 850W Plus bronze
Mouse Gigabyte Force M7 Thor
Keyboard Gigabyte Aivia K8100
Software Windows 10 Pro 64 Bits
At least someone who thinks like me.
Bottom line: 20% over GTX480 is not enough, considering Cayman XT will be at the very least 30% - 40% faster than Cypress XT, that would make it go neck on neck(equal performance) with 'GTX580', and as everyone knows, due to amd chips being cheaper to produce, amd can lower prices more, and still make some profit.
107 (0.02/day)
Romania
Processor intel i7 4770k @ 4.6ghz
Motherboard asus maximus vi hero
Cooling noctua nh d14
Memory 16gb gskill 2400 mhz
Video Card(s) MSI gtx 780ti
Storage 512gb samsung 840 pro + 2x 1tb WD caviar black sata 3
Display(s) 3x Benq XL2720Z 144hz surround
Case cooler master storm stryker
Audio Device(s) asus xonar dx
Power Supply corsair ax1200
Software windows 7 ultimate 64 bit
I think that gtx 580 will be a winner if it is slightly cooler than gtx 480 and keeps the same OC potential and perfomance scaling. I own the gtx 480 and I will happily upgrade for gtx 580. many of you speak without knowing the truth. my gtx 480 OC 830/1100 doesnt't get passed 81 degrees Celsius and is almost as performant as ati 5970. and that without facing the retarded ATI drivers. you also get physx CUDA and the best minumum framerate which is most important when you playing games
