GeForce RTX 5090 Power Excursions Tested: Can Spike to 901W Under 1ms
3,611 (4.93/day)
Russian Wild West
Processor i5-12400F
Cooling Laminar RM1
Memory 32 GB DDR4-3200
Storage Yes.
Display(s) MSi G2712
Audio Device(s) Yes.
Software Windows 11 / 10 / 8
So you are buying a 3000 usd video card and not getting a new PSU…
The fact you have money doesn't mean you must be robbed. Please don't be an enabler. 450 W was horrendous as it is, 575 is nVidia just throwing another "not my problem" card right in our face.
NB: I am okay with GPUs consuming this much power (or even more) under XOC but at stock, sanity must remain. I have not yet concluded where the sanity and insanity meet each other but it's right around 260 to 320 W.
11,028 (1.75/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
It's physically uncomfortable gaming next to the rig at full blast. Like the right side of my body being 5 degrees warmer than the left is a bit immersion breaking.
699 (0.23/day)
System Name Unimatrix
Processor Intel i9-9900K @ 5.0GHz
Motherboard ASRock x390 Taichi Ultimate
Cooling Custom Loop
Memory 32GB GSkill TridentZ RGB DDR4 @ 3400MHz 14-14-14-32
Video Card(s) EVGA 2080 with Heatkiller Water Block
Storage 2x Samsung 960 Pro 512GB M.2 SSD in RAID 0, 1x WD Blue 1TB M.2 SSD
Display(s) Alienware 34" Ultrawide 3440x1440
Case CoolerMaster P500M Mesh
Keyboard Corsair K75
Benchmark Scores Really Really High
You guys think a 1ms spike will cause the cable to spontaneously combust? Get real.
If the cable/conductors aren't losing heat faster than they're gaining, they'll eventually runaway under sustained load. -Regardless of peaks.
Not to mention, physical migration/movement from thermal expansion/contraction...
The spec is designed for 600W continuous load. No cable is melting. If the spec is designed for 600W continuous, that means there's probably a 20% buffer built in, so the cable can support 720W.
122 (0.06/day)
But do you remember the RX480 that melted the mobos for peak consumption? good times of terrible misinformation against AMD, Nvidia is the Intel of the 2000s with the press in favor and everyone silent.
Ruru
S.T.A.R.S.
13,445 (3.02/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
So basically you need a 1.2kW PSU to be on the absolutely safe side. I still remember when those were mostly for HEDT rigs with SLI/CF or something similar.
Remember that issue but did it even cause anything else than negative PR? I guess that PCIe has some headroom over its 75W spec.
201 (0.07/day)
Germany
Cooling MO-RA3 420 LT | 4x NF-A20
Memory F5-6400J3239G16GX2-TZ5NR
Video Card(s) Asus 4090 TUF
Storage 1TB NM790 | 2TB SN850X | 1TB SN750
Display(s) AW3423DW | S2721DGFA
Case Hyte Y70
Audio Device(s) FiiO K11 | DT1990 Pro | Rode NT-USB
Power Supply FSP Hydro Ti Pro 1000W
Mouse G502 X Plus | GPX Superlight 2
Keyboard Keychron Q6 Max
Guys...
Stop panicking. This is all well within ATX 3.0 spec.
3,520 (1.12/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
A good 1k or 1.2k psu should be able to without triggering ocp without the atx specification required.
1,000 watts is the bare minimum with an efficient CPu I believe. TechYesCity was getting full system shutdowns with a 850w unit and a 7800X3D. With an Intel CPU 1.2K is minimum.
Max rated wattage is 684w: https://en.wikipedia.org/wiki/16-pin_12VHPWR_connector
That said the cable is designed to carry 600w. Anything above that is iffy depending on manufacturing variance. Ironically the 5090 astral does exceed 600w...
Look at the margin compared to the 8 pin, world of difference.
4,552 (2.65/day)
System Name Mean machine
Processor AMD 6900HS
Memory 2x16 GB 4800C40
Lol, ok man. My 9800x 3d draws more power in gaming than my 12900k, but sure, you do you.
699 (0.23/day)
Cooling Custom Loop
600w is too much for a room without air conditioning. This is an oven. I don't want to know how someone doesn't have air conditioning and has 28'C in the room in the holidays playing on a 200-250 watt graphics card like me.
The card is not putting out 600W of heat. This is not a heater. The energy is used to do work. A 600W resistive heater doesn't even put out 600W of heat, it has losses.
3,924 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
With electronics, the energy used to do work is effectively theoretical. For practical purposes all the consumed energy goes into heat output.
3,853 (1.74/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
699 (0.23/day)
Cooling Custom Loop
Surprised it only has a 1.1 safety factor instead of 1.2 like in home electrical wires.
1,077 (0.61/day)
System Name S.L.I + RTX research rig
Processor Ryzen 7 5800X 3D.
Motherboard MSI MEG ACE X570
Cooling Corsair H150i Cappellx
Memory Corsair Vengeance pro RGB 3200mhz 32Gbs
Video Card(s) 2x Dell RTX 2080 Ti in S.L.I
Storage Western digital Sata 6.0 SDD 500gb + fanxiang S660 4TB PCIe 4.0 NVMe M.2
Display(s) HP X24i
Case Corsair 7000D Airflow
Power Supply EVGA G+1600watts
Mouse Corsair Scimitar
Keyboard Cosair K55 Pro RGB
Guys...
No technically it's not it's 901 watts, it's 1 watt over it. lol
239 (0.07/day)
New Zealand
System Name Katzi
Motherboard Asus Strix B550-A
Cooling Phanteks Glacier 360
Memory G.Skill Trident Z Neo F4-3600C16-16GTZNC (Dual Rank 32Gb)
Video Card(s) MSI Gaming X Trio RTX 3080
Storage Samsung SSD 980 1TB, 970 512GB Evo Plus, 1TB 870 QVO, 960 Pro
Display(s) LG 27GS75Q-B
Case NZXT H6 Black
Audio Device(s) Creative Soundblaster X3
Power Supply Corsair RMx850
Software System76 Pop!_OS, Windows 11 23H2
The RMA's are going to be *Wild*
Stephen Colbert Popcorn GIF
38 (1.15/day)
Morrisville, NC, USA
Lots of pre-ATX 3.0 power supply units are likely to prematurely fail due to not being designed to handle these high magnitude power spikes if they are connected to an RTX 5090.
How will power supply reviewers have to modify their methodologies to account for new video cards which routinely generate ridiculously large power spikes like RTX 5090 video cards are prone to doing?
When these power spikes eventually destroy the power supply units that were not designed to ATX 3.x standards, how would those power supply units fail, and what effects should we expect when they do fail? Will they just be unable to start and be dead, or would they spark, smoke, or catch fire? I am not an expert in how power supply units fail.
4,552 (2.65/day)
Why would they fail? There is 0 reason for a well built PSU to fail, especially not because of power spikes. It will trip the over current protection and shut down. As long you are not running your PSU at 100% capacity all day long (so probably you should avoid an 850w PSU with a 5090) youll be fine.
118 (0.06/day)
they getting around twenty 4090 cards for repair every week, plenty of other hardware repair channels report the same
