GELID Introduces Icy Vision Rev. 2 Cooler, Supports GeForce GTX 460 and GTS 450 GPUs
46,877 (7.62/day)
Thermal Solutions specialist GELID Solutions has launched the 2nd revision of its multi-award winning VGA Cooler "ICY VISION" of its GAMER product line. In comparison to the previous edition the "2nd rev. of ICY VISION" is now compatible to NVIDIA's promising GTS 450 & GTX 460 card. The "Rev. 2 ICY VISION" cooler contains 5 power heatpipes in a unique heatpipe constellation. The heatpipes are interlaced into 85 optimized high-quality Aluminium fins. Together with a flat stack fin soldered Copper base, they enable the most efficient heat transmission and dissipation from GPU core in its class.
Besides the heatsink, two 92mm UV-reactive fans with 11 blades in S-shape generate 20% more air flow than traditional fans. The fan contains a high-quality ball bearing to ensure a longer lifetime in high temperature environments. The "Rev. 2 ICY VISION" is both CrossFire and SLI compatible on a number of cards. Screws were optimized to enable a proper SLI in the 2nd revision. To ensure a better cooling more RAM and Voltage Regulator Module (VRM) heatsinks are created to cool down the components around the GPU. The high performance GC-2 thermal compound is also included in the package.
The "Rev. 2 ICY VISION" VGA cooler is available now and has a MSRP of USD 55 or Euro 46. This cooler is RoHS, WEEE conformed and carries a 5 year warranty.
107 (0.02/day)
Romania
Processor intel i7 4770k @ 4.6ghz
Motherboard asus maximus vi hero
Cooling noctua nh d14
Memory 16gb gskill 2400 mhz
Video Card(s) MSI gtx 780ti
Storage 512gb samsung 840 pro + 2x 1tb WD caviar black sata 3
Display(s) 3x Benq XL2720Z 144hz surround
Case cooler master storm stryker
Audio Device(s) asus xonar dx
Power Supply corsair ax1200
Software windows 7 ultimate 64 bit
it won't sell. those cards have already low temperatures, even heavily overclocked
435 (0.08/day)
United Arab Emirates
System Name The Fouth Light
Processor i7-2600K @ 3.80GHz (1.35voltage)
Motherboard GA-P67A-UD4-B3
Cooling Corsair H50
Memory 8GB DDR3 Corsair Vengence 1600MHz (8-8-8-24)
Video Card(s) 2x GTX460 @ Stock
Storage Cosair GTX Neutron 120GB + 2xWD Carviar Black 640GB RAID0
Display(s) Samsung S27B970D 27 Inch
Case Thermaltake Element V Full tower
Audio Device(s) Asus Xonar Essense STX
Power Supply Corsair HX1000W
Software Windows 7 64bit Ultimate
I disagree with you.
You see these cards are so damn noisy compared to the previous 200 series. I've two GTX 460, one of them has a faulty fan which sounds like a jet engine and the other doesn't have the same sound but it's still noisy.
If this cooler is not as noisy as the reference design coolers then I may consider buying one or two.
2,824 (0.52/day)
Midwest USA
System Name My Gaming System
Processor Intel i7 4770k @ 4.4 Ghz
Motherboard Asus Maximus VI Impact (ITX)
Cooling Custom Full System Water cooling Loop
Memory G.Skill 1866 Mhz Sniper 8 Gb
Video Card(s) EVGA GTX 780 ti SC
Storage Samsung SSD EVO 120GB - Samsung SSD EVO 500GB
Display(s) ASUS W246H - 24" - widescreen TFT active matrix LCD
Case Bitfenix Prodigy
Power Supply Corsair AX760 Modular PSU
Software Windows 8.1 Home Primeum
It still looks like it takes up 3 slots with fans installed. Sigh..... Scythe has the right idea! We need more coolers designed with closer PCIe slots in mind!
13,791 (1.90/day)
Interesting, HD5850 with reference cooler is perfectly silent even under heavy load. And that's in my uATX case where the fan is almost sticking out of the mesh side and every noise change is noticeable.
In normal case i'm sure i wouldn't be able to hear it. Are GTS 450 and GTX 460 really that noisy?
DeadManVL
2 (0.00/day)
Zagreb, Croatia
no, not by default (for most models), but if you overclock than temps go up and so does the fan speed and hence the noise :)
ebolamonkey3
773 (0.15/day)
Atlanta/Marietta, GA
System Name Norbert
Processor Intel Core i7 920
Motherboard Gigabyte X58A-UD5
Cooling Corsair H50 with 2x Scythe GT AP-14
Memory 3x 2gb G.Skill 1600Mhz C9 DDR3
Video Card(s) MSI Twin Frozr II GTX 465 GE & EVGA GTS 450 SC
Storage 2x 1Tb Samsung Sprinpoint F3 7200rpm
Display(s) Dell U3011, Dell 2408WFP, Samsung 2693HM
Case Lian Li V1020R
Audio Device(s) Creative X-Fi Titanium
Power Supply Seasonic X-750
Software Windows 7 Ultimate 64bit
All the aftermarket fans that are worth buying take up 3 slots. It's just so much easier b/c thicker fans give you better cfm and static pressure for the size and speed. The only instance where I've seen a slim fan work is w/ MSI's twin frozr design and Gigabyte's dual fan design (which is like a carbon copy of MSI's twin frozr).
132 (0.02/day)
No thanks. I haven't come across a noisy GTX 460, and I certainly don't need to convert the video card into a three-slot product.
