Get 9070 or 9070 XT
175 (0.37/day)
Processor 5900x
Motherboard MSI 570s
Cooling AIO 240
Memory 32 GB G.Skill @ 3200MHz
Video Card(s) 6800 xt
Storage Many
Display(s) Two QHD
Power Supply SilverStone Hela 1200W
I am hesitated which is a better card ? I saw in reviews of 9070 XT over none XT has 15+ ~ 30+ FPS in games but worried about vram temperature 9070 in Asus tuf sample is 78°C but Sapphire RX 9070 XT Nitro OC is at 90C
7,815 (3.30/day)
California
System Name His & Hers
Storage lots of SSD.
Depends on price, if they are less than 100 usd apart 9070xt 100 times out of 100.
241 (0.06/day)
Processor Ryzen 7 5800x3D
Motherboard Gigabyte B550 Gaming X v2
Memory Corsair Vengeance LPX 2x32GB 3600Mhz C18
Video Card(s) XFX RX 6800 XT Merc 319
Storage Kingston KC2500 2TB NVMe + Crucial MX100 256GB + Samsung 860QVO 1TB + Samsung Spinpoint F3 500GB HDD
Display(s) Samsung CJG5 27" 144 Hz QHD
Case Phanteks Eclipse P360A DRGB Black + 3x Thermalright TL-C12C-S ARGB
Audio Device(s) Logitech X530 5.1 + Logitech G35 7.1 Headset
Power Supply Cougar GEX850 80+ Gold
Mouse Razer Viper 8K
Keyboard Logitech G105
Sapphire nitro looks to be one of the worst (based on HUBs reviews). Check/wait for other partner cards and of course, wait for actual pricing.
229 (2.60/day)
Missouri
System Name The
Processor Ryzen 7 5800X
Motherboard ASUS PRIME B550-PLUS AC-HES
Memory Silicon Power 32GB (2 x 16GB) DDR4 3200
Video Card(s) RTX 2080S FE | 1060 3GB & 1050Ti 4GB In Storage
Display(s) Gigabyte G27Q (1440p / 170hz DP)
Case SAMA SV01
Power Supply Firehazard in the making
Mouse Corsair Nightsword
Keyboard Steelseries Apex Pro
Another factor to consider is efficiency and price to performance. Which matters to you more?
Undervolting seems really promising on the 9070XT, and at the other extreme, both OC like monsters (which is actually nice to see cards OC above 10% for once)
I'd wait for street price to come out, and see what the stock is like though first.
1,191 (0.19/day)
System Name KOV
Processor AMD 5900x
Cooling H100i iCUE link LCD liquid cooler
Memory Corsair 3600kHz 32GB
Video Card(s) RX 7900XT
Storage Samsung 970 evo 500gb, Corsair 500gb ssd, 500GB 840 pro & 1TB samsung 980pro. M2.SSD 990 pro 1TB
Case Corsair 680x with new ICUE link installed
Power Supply RM850x Corsair
Software windows 11
The more I hear about these cards the happier I get
43,927 (6.80/day)
wolf
Better Than Native
8,511 (1.31/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
Cheapest (hopefully MSRP) XT for sure would be what I'd do.
7,789 (5.08/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
XT. The regular one needs a price cut.
29,522 (6.93/day)
There are a few things to consider. Power usage and price. The 9070 is very competitive with the new NV gen and falls inbetween the 5070 & 5070ti for a very attractive price. If the power usage of the 9070XT doesn't concern you and the price something you can afford. Go for it. It'll be the one that lasts in the long run.
The only question will be what version of the GPU do you like? There will be a number of different styles of cards to choose from.
297 (0.89/day)
System Name Crapostrophic
Processor AMD Ryzen Z1 Extreme
Motherboard ASUS Custom PCB
Cooling Stock Asus Fan and Cooler Design
Memory 16GB of LPDDR5 running 6400mhz with tweaked timings
Video Card(s) AMD Radeon 780M APU
Storage 2TB Aorus 7300 Gen 4
Display(s) 7 Inch IPS Display @120hz
Case Plastic Shell Case designed by Asus
Audio Device(s) Asus ROG Delta
Power Supply 40WHrs, 4S1P, 4-cell Li-ion with a 65W PD Charger
Mouse Asus ROG Keris Wireless
Keyboard AKKO 3098B hotswapped to speed silver pro switches
Software Windows 11 Home (Debloated and tweaked)
Both cards are competent IMHO, choose whatever your wallet allows you too, though that 50$ difference (in reality you won't find it) is pretty much a no brainer..
2,326 (1.14/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
1,027 (0.17/day)
System Name HTPC whhaaaat?
Processor 2600k @ 4500mhz
Cooling Noctua NH-C14
Memory Gskill Ripjaw 2x4gb
Display(s) Vizio P 65'' 4k tv
Case Lian Li pc-c50b
Audio Device(s) Denon 3311
Power Supply Corsair 620HX
IMHO the current price of 9070 makes it a stupid product period; just buy a cheaper raster card if you want that level of perf.
If people think it's a stupid product when it's like...I don't know...under $400, I guess people have the right to either opinion.
9070 is a RT card without enough performance to really do it (at any decent resolution) in newer titles going forward imho, hence, it's kinda bunk...not unlike 5070, but with some extra ram.
It essentially replaces the 7800xt/6800xt (which are/were very good pure raster cards and been a lower price for a very long time).
9070 xt can actually use those features in a meaningful way, and is kind of a breakthrough in it's price class.
Again, it won't be as high-end as it appears forever, but will have a MUCH longer life than anything below it.
If you're going to make the jump, buy a 9070xt. If you're not, buy a cheaper card IMHO capable of similar raster performance.
Frick
Fishfaced Nincompoop
19,911 (2.87/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
We don't actually know how much they'll sell for, so it's impossible to say.
43,927 (6.80/day)
1,027 (0.17/day)
That's your opinion. Doesn't meet with much merit.
It is $50 less than a much superior product, and cannot for all practical purposes meet decent performance requirements for this new era.
No merit? Ha. Go look at it's performance and where it falls short. Now imagine that going down a whole tier, where it would also fall short.
29,522 (6.93/day)
If someone can't afford the extra $50 or any number of other factors, then no the XT is NOT the better option and the 9070 would be the best option for those buyers.
You are looking at the situation with tunnel vision. Seeing a bigger picture is key.
The 9070XT is not automatically the best option. That is YOUR narrow opinion. The OP needs to choose for themselves what fits best for them.
1,027 (0.17/day)
Read what I actually wrote, rather than be self-righteous. That is not at all what I said.
I know that people don't always have that extra money. I in-fact said I believe there are better values for a similar performance class...The point of that is to save money.
It is in-fact my opinion. That is correct. I did in-fact say that more than once in that post.
157 (0.03/day)
Puerto Rico
Go for the XT .
29,522 (6.93/day)
Oh?
This is what you said.. I glossed over the rest as your statement. Couldn't care less about such a narrow opinion.
If you're going to make silly statements and give bad advice, you can't be surprised when someone calls you out on your nonsense.
1,027 (0.17/day)
Do you not understand what IMHO means? It means: in my humble opinion. You're taking things wayyyy too seriously. Chill out.
How is it a silly statement to suggest either buying one tier or the other? I personally (<- this means opinion) don't believe in buying products split between tiers, as they have a reduced lifespan for any purpose.
This has always been true. I have now hopefully explained it to your satisfaction. This is also why AMD has not made many, and why they are priced as they are. That is not opinion, this is what happened.
2,982 (6.41/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
I will wait and see what the price difference will actually be in the real world (and different locations). Something tells me that the “50 dollar more” for the XT will not actually keep anywhere other than the MSRP listed in the reviews. Which should make the 9070 an actually interesting product - a sub-250W with a 16G frame buffer and plenty enough grunt for mostly anything sane. I doubt that most well-specced AIB models of the 9070XT will actually exist below 700, which makes the 9070 more interesting too. Can also get away with lesser models - 100W difference is nothing to sneeze at in terms of cooling. 250 you can easily cool with a dual slot dual fan, maybe 2.5 slot. 350 - not so much.
29,522 (6.93/day)
Yeah, there is this and it's very much a "wait-and-see" situation.
184 (0.29/day)
Holy Roman Empire
System Name DeathStar /// DeathStar II
Processor AMD Ryzen 7 7700 /// AMD Ryzen 9 5900X
Motherboard Asus ROG Strix X670E-E Gaming /// Asus ROG Strix B550-E Gaming
Cooling Noctua NH-D15S chromax.black /// Thermalright Royal Knight 120 SE
Memory Kingston Fury Beast RGB 6000C30 2x16GB /// G.Skill Trident Z RGB 3200C14 4x8GB
Video Card(s) Zotac GeForce RTX 4080 Trinity 16GB /// XFX Radeon RX 6600XT 8GB
Storage Kingston KC3000 2TB + Samsung 970EVO 2TB + 2x WD Red 4TB /// Samsung 970EVO 1TB + WD Red 4TB
Display(s) Gigabyte M27Q /// Dell U2715H
Case Fractal Define 7 Black /// Fractal Define R5 Black
Power Supply Seasonic SS-750KM3 /// Seasonic SS-660KM
Mouse Logitech MX Master 2S /// Logitech MX Master
Software Linux Debian 12 x64 + MS Windows 10 Pro x64
9070XT all the way. 9070 is an upsell leik it was 7900XT when it was launched. But again, it depends on street price. If they are in 100 EUR/USD, XT all the way.
