Gigabyte GA-X58A-UD7
JohnHunter
17 (0.01/day)
Greetings dear friende. I have a question about a faulty board that i cant manage to power up. Im i in the right place? Thanks
19,366 (3.66/day)
Theres a motherboard section this likely fits in...but just ask the question...staff can move it (report your own post amd ask it to be moved).
JohnHunter
17 (0.01/day)
I got this mobo rom a lost storage and i managed to pick up a 500w new psu, a i7 920 and some 8gb compatible ram and tried o fire it up and i just got cristmas tree light all over the board and post code 88 for a 2 seconds and then shuts down with only power and cmos button lights on.
Tried to fire it up with power button but no avail, only disconeting and reconecting psu and fires right up with same issue.
Tried some combinatios to see if it changes something but it only got worse. Now it onli has the power aod cmos lights on with PSU atatched and nothing else happens. is ti dead? any sujestions? thanks in advance.
19,366 (3.66/day)
What psu? Tried a different psu.
What ram? One stick? Three?
Tried resetting the cmos?
FreedomEclipse
~Technological Technocrat~
23,491 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
35 (0.01/day)
Motherboard MSI MAG B460M Mortar
Cooling Cooler Master Hyper 212X (Dual Fans)
Memory Kingston HyperX Fury DDR4-2666 CL16 2x8GB
Video Card(s) MSI GeForce RTX 3060 12GB Gaming X
Storage 1x Samsung PM991 256GB NVMe; 2x Samsung PM991 512GB NVMe
Display(s) Samsung LF24TF350
Case Cooler Master CM590 III
Audio Device(s) Logitech G332 Wired Headset
Power Supply Cooler Master V650 Modular
Mouse Logitech G102 Prodigy
Keyboard CM Storm Devastator III
I would start by checking the power connectors to the CPU. Normally 4 pin but in your case it should be a 8 pin connector. Also check if your board needs auxiliary power eg. a molex connectors on the board.
JohnHunter
17 (0.01/day)
The psu is a recent coolermaster 500w, i only have one stick of ram in the white slot near the cpu and tried reseting cmos (i think i did it right, must check post #6), the psu has the 2x4 12v conector in place. As for the auxiliary power i dont know what does it mean so im still trying to solve this without sending it for repair. I just liked to know if it has any salvation.
EDIT: i dont have any case avaliable for this monster, only for microATX :)),
EDIT2: and i know the psu is good, it works on another computer.
19,366 (3.66/day)
When you say 2x4... that is the one by the CPU... what about the 20+4? Are these seated properly?
Is the white slot the slot memory should be in when only running a single stick (not a good idea btw... you will lose performance there)? Confirm this in your manual which slot a single stick of RAM should be in.
These are typically for mGPU setups.
JohnHunter
17 (0.01/day)
All the connectors are seated properly, even without anything on the board it does not do anything.
can it be lack of power?
can it be a corrupted bios?
EDIT: saw someone say its lack of gpu? can it be it? i have one but i dont know if it works...
19,366 (3.66/day)
So the PSU works in another machine... cool. Should work here. It isn't a lack of power.
Confirm what slot a single stick of memory should go in through the manual...
JohnHunter
17 (0.01/day)
i dont think thats the problem but i will check
check here, it says on ddr3_1, its the white one nearest to the cpu, where mine is.
  • mb_manual_ga-x58a-ud7_v.2.0_e.pdf
19,366 (3.66/day)
It says DDR3_1 or DDR3_3... try both...If you have another memory stick that will work, try that one too.
But brotha... feels like this thing is junk. Sorry. Not even sure i'd take it into a shop. Its going to cost you twice as much as getting another motherboard..
JohnHunter
17 (0.01/day)
i will keep trying other options, some shops here do a free budget for repairs.
anyone else got any advice? thanks
The thing is that it started with some action from the board and now it does nothing. Can it be BIOS/CMOS issue?
19,366 (3.66/day)
It can be... but who knows...the symptoms don't really pinpoint much.
JohnHunter
17 (0.01/day)
yeah i still have faith.
what about recovering bios. it has double bios.
EDIT: and i dont really have much harware to work with, i junt need to see if i can use it or trash it.
19,366 (3.66/day)
If it has a dual BIOS, logic says to try the other, sure!
But since you can't seem to get into the BIOS in the first place, unless the board has a switch not sure how you can try the other BIOS (check the manual) or flash it.
JohnHunter
17 (0.01/day)
Got some update about my board and i think i got the guilty chips, although i dont know what they are. I started over from scratch, hoocked everything tightly, conected the power and nothing. Started to get nuts and banged the cpu cooler and she came alive again as the first time, all leds lid up and 88 post error, alive for about 5 seconds, even the hard drive kicked started and it died. Didnt manage to bring her back to live again.
I did find 2 chips on the board that were blazing hot, it almost burnt my finger, and noticed that their surface had some sort of hole in them. Perhaps these chips are fried might guess. I posted some photos of them 2. One near the power button, another near the pci-ex slots.
Sujestions?
19,366 (3.66/day)
The holes dont mean much but it looks like a couple of those have bulges/bubbles/blister on them.
Junk board is junk.
Regeneration
NGOHQ.COM
3,080 (0.45/day)
Those chips are suppose to be hot. Code 88 is a generic error.
Install just a single RAM, take off the CMOS battery for a few minutes, and try again.
JohnHunter
17 (0.01/day)
Like as they cannot be touched? It seems wierd that they are the only ones with irregular surface. I only have one ram but i will try.
What are their function? Do you know?
847 (0.39/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
As long as pin's aren't bent, likely needs a CMOS reset or RAM replacement
951 (0.29/day)
System Name The Banshee
Cooling CM Hyper 212 Plus
Memory 16GB 2x8 G.Skill Trident Z 3600 CL16 1.35V
Video Card(s) RTX 3060M 6GB @ 1750-2100MHz Core / 1875MHz Mem
Storage 1TB Kingston NV2 & 1TB Mass Storage HDD
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 10 Pro 64-Bit
No they're not. Nothing should be getting that hot other than the CPU & NB. Likely a sign that they have a dead short. Especially since it looks like they've blown up.
Hard to tell for sure though without probing them with a DMM.
