GK104 Board Draws Power From 6+8 Pin Connectors, 3+2 VDD Phase Power Supply
2,516 (0.47/day)
Canada
6 + 2 connector can't be that special if you can use a molex adapter to power it :eek:
brandonwh64
19,542 (3.48/day)
It is special in its own way. It is made of higher gauge wire and on its on phase/block/rail It is meant to be used on PCIex cards only. If you use a molex adapter, you are sharing it with other molex plugs such as HDD/DVD/fans. This applies on most PSUs
2,516 (0.47/day)
Canada
99% of PSU's use the same gauge wire's from what i have seen :eek:
I was saying that because most (from what i have seen) of the molex > 6 + 2 run a dual molex (3 wire ea) into a single 6 + 2 so ya :confused:
12,057 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Most 12V single rail have all the yellows soldered in together. All of the same gauge. So really a 6 pin is capable, its just how thick the wiring is and how many amps it can carry.
I just took apart another PC power & cooling 750 to use as a 12V power supply, and it is all the same inside it. Reviews tested it up to a total of 60 Amps on the 12V rail.
brandonwh64
19,542 (3.48/day)
Yea those are very strong PSUs and the main reason is the single rail. Most of these multiple rails are the ones I was talking about.
I have had great luck out of single rail PSU's
2,585 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Hmm... OK.
All I will say is the 6-pin and 6+2-pin cables for my PSU both use 18AWG conductors.
2,516 (0.47/day)
Canada
Most 12V single rail have all the yellows soldered in together. All the same gauge
That's why they are called single rail unit's, multi rail unit's split the load across several rail's but the source is still the same IIRC
Dunno if i make any sense, looooong weekend :roll:
I would never buy a multi rail PSU
2,516 (0.47/day)
Canada
I say some not all
Now that the cog's are turning i think i recall something in my OCZ literature (or a review i read) mentioning increased wire size for certain connector's on my new PSU zx850w, i actually think they are the 6 + 2 pin's for the GFX card's and the main ATX!! :laugh:
2,198 (0.44/day)
So. Cal.
GTX 670 Ti[/URL], is reported to use a 5 NVVDD phase power supply (VRM) design that draws power from 6-pin and 8-pin power connectors. The card will hence have 300W of power at its disposal.
In all probably what’s exactly demanded for such Uber/FTW versions to get above the 7950. That PCB and power section doesn't come cheap normally, so definitely a $400+ price tag. If true it kind of tells us the Kepler is still not any more power efficient than Fermi.
Here the problem those type of expensive to manufacture boards aren’t normally a long standing production offerings that don’t ever see the price breaks. So it means to me they’ll make a presence short term then disappear as soon a prices start to adjust. Nvidia and their AIB’s will get pressed in price and then they’ll be gone from the market in a few months.
Sure there will be the more "generic" GTX 670 Ti's that might have both 6/8pins, but that will be for the more DIY OC’r, but those more generic OC versions (more or less competing with 7950) will hold to a 225W TDP and not offer as robust power sections.
2,972 (0.57/day)
System Name Old Fart / Young Dude
Processor 2500K / 6600K
Motherboard ASRock P67Extreme4 / Gigabyte GA-Z170-HD3 DDR3
Cooling CM Hyper TX3 / CM Hyper 212 EVO
Memory 16 GB Kingston HyperX / 16 GB G.Skill Ripjaws X
Video Card(s) Gigabyte GTX 1050 Ti / INNO3D RTX 2060
Storage SSD, some WD and lots of Samsungs
Display(s) BenQ GW2470 / LG UHD 43" TV
Case Cooler Master CM690 II Advanced / Thermaltake Core v31
Audio Device(s) Asus Xonar D1/Denon PMA500AE/Wharfedale D 10.1/ FiiO D03K/ JBL LSR 305
Power Supply Corsair TX650 / Corsair TX650M
Mouse Steelseries Rival 100 / Rival 110
Keyboard Sidewinder/ Steelseries Apex 150
Software Windows 10 / Windows 10 Pro
You mean the 7950?
2,516 (0.47/day)
Canada
