GPU Clocks spikes when idle.
nathz94
4 (0.01/day)
What I said in the title, attached image. At idle every 1 minute timed there are spikes in the gpu clocks. I have tried: Update Drivers, Reinstall Drivers, No viruses (multiple tests found 0 viruses), I have no programs like MSI Afterburner or any other running. The only difference is that before it didn't do it to when it does is that I updated the BIOS from F3 to F62 (Gigabyte).
Is there a problem with this what the gpu is doing? It didn't do it before and I don't know if it can be dangerous.
Thank you all for help.
3x0
967 (1.17/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
nathz94
4 (0.01/day)
Thanks for replying, I have tested it and when the gpu clocks go up, the gpu usage is the same (0.43% ~ 0.46% usage).
I really don't know whats happening. o_O
I am out of ideas.
3x0
967 (1.17/day)
Do you have automatically switching Windows backgrounds enabled?
1,936 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Close ALL internet browsers (preferably with disconnecting internet/network card), and check if it's still doing it.
43,006 (6.72/day)
hwinfo64 please
43,006 (6.72/day)
Fresh OS drive
43,006 (6.72/day)
I'll try that. Thank you for all the help!
Do not copy existing data over till you notice problem is gone or not. The drive must have a virgin os on it
2,207 (0.79/day)
I think the issue is AMD software. Install driver only & see if that fixes it. You do not need to de-install, just run the same driver version & select driver only from the option menu.
43,006 (6.72/day)
Only way to truly know is cleanslate it
nathz94
4 (0.01/day)
SOLVED! it was the AMD Software.
Thank you all for all the help!!
  • Like
Reactions: mo.
2,207 (0.79/day)
Let that be a lesson to all.
No matter how many cores you have, any software you can remove from task manger will make your computer run faster. This is why I have always run driver only & use an external program such as Afterburner to change card settings. AMD software can sometimes introduce stuttering, it depends on the interaction between driver & the rest of the software running in the background.
Overall your computer is better off with driver only install.
EDIT: Can't speak for user's with Nvidia cards as I have never own one of they cards, but it will be interesting for a user(s) to try driver only & post result.
EDIT2: OP fault was most likely the software checking for updates. Turning off automatic check for update may have fixed the original issue.
43,006 (6.72/day)
Yeah I turn off any autoupdate bs as it puts a load on the network, that stuff lives to be in the task scheduler even
Im thinking Radeon Pro for Enterprise would be fine
2,207 (0.79/day)
I turn off autoupdate on most of my programs. The only ones that are active are windows update & antivirus. Some programs are deactivated at startup. These are programs that are built into windows or part of a program that's needed to run games. With a simple tick box they can be reactivated.
Example Below: Windows 7 Last two program are disabled. ...Windows 10 list is different
43,006 (6.72/day)
I leave Windows update completely disabled (I might even gut it from windows) and am considering using powershell to install only updates I need (Vetting them)
43,006 (6.72/day)
2023 and AMD still have this problem. I just install the latest update and I got the same problem, thanks for the solution
You ever think to report the problem to AMD???
62 (0.03/day)
17 August, 2023
AMD Adrenalin Software: 23.7.2
The same issue happened to my RX 580 and was fixed by uninstalling Adrenalin Software. I guess AMD doesn't care about their GPU customers anymore.
