GPU for 4K
inter2010
28 (0.04/day)
hi guys, i need to buy a gpu !
maybe it's the worst time to buy a video card, but sadly my 2080 ti broke after 4 years of heavy use.
I wanted a gpu that does stable 100fps in 4k with ultra details. RT is not a priority, I prefer a gpu that consumes little and has low temperatures. I live in a hot place and having a gpu that heats up a lot is not fun.
unfortunately I know very well that it takes more than 1k dollars, but it doesn't matter, unfortunately the world goes like this.
thank u !!
2,485 (0.52/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Case Corsair 275R
Mouse Logitech G Pro (Hero)
I like the Sapphire Nitro+ Radeon RX 6750 XT. It's easily a 220W card when running the latest/hardest stuff, but if you raise the fan RPM and disable zero-RPM, it shouldn't get too hot.
Unfortunately, I don't know how it will hold up with no air conditioning at all. Maybe the RX 6650 XT is the best bet.
inter2010
28 (0.04/day)
i probably prefer something from the latest generations. i wish i didn't want to buy a gpu for the next 3 or 4 years. so if i go too far back with the generations i might have problems later
1,005 (0.69/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
the latest generations are 4070/80/90 and 7900XT/X
4070 Ti is a 1440p card that sometimes suffers 10-20% penalty in 4K depending on the title because of its 192 bit bus, RX 6800 is the minimum requirement ~$500
Or you could wait the cutdown 4070 sitting between 3070 Ti and 3080 that is rumored to soon enter production.
53 (0.01/day)
Los Angeles
Processor i9 13900KF @ 6GHz
Motherboard Gigabyte Z790 Aorus Master
Cooling Corsair H150i Elite LCD
Memory 32GB G.Skill Z5 A-Die @ 7000 CL34
Video Card(s) Zotac RTX 4090
Storage 2x Samsung 980 Pro 2TB Gen 4 NVMe
Display(s) 48” Gigabyte FO48U OLED
Case Hyte Y60
Power Supply Corsair RM1000e
Mouse Corsair M65 Ultra
Keyboard Corsair K60
VR HMD Pimax 8KX
Benchmark Scores https://www.3dmark.com/sw/198235 https://www.3dmark.com/spy/34048773
4080 or 4090 for 4K this gen. A 3080ti can also do 4K 100fps in many titles (no RT). However these are all hot cards
388 (0.42/day)
Ohio, USA
System Name Trackstar
Processor AMD Ryzen 7 5800X3D -30 All Core CO (on Corsair XC5 block)
Display(s) Dell S3222DGM 32" 1440p/165Hz FreeSync
Mouse Corsair Nightsword RGB
Keyboard Corsair K60 RGB PRO
VR HMD N/A
Benchmark Scores https://www.3dmark.com/sw/1131940 https://www.3dmark.com/fs/29315810
Yeah and I want the tooth fairy to deliver a giant bag of money to my doorstep. What you're asking doesn't make sense. The more performance you want out of your card the more power it takes and more heat it produces. Best you could do might be a 6650XT or 3060Ti if you're super concerned about power/temps.
tabascosauz
8,182 (2.36/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
thank u !!
I sure hope you're okay with 300W, because all of the GPUs that can come close to or exceed 100fps at 4K are all going to be 300W or more. Obviously 40 series and RX7900 are new so not that much is known about how far they'll reliably undervolt, but if the XT and XTX are any indication, don't expect miracles.
It's all a matter of perspective, you may need to adjust yours. Without A/C in the summer, I would be uncomfortable after just one hour of gaming with a 5900X and 2060 Super. That's a 180W card. You may have to either accept the consequences of performance, or install air con.
The 4090 would probably be the most efficient and still the fastest out of all those cards if heavily undervolted and underclocked, but even then you'd probably still be at what, 250-300W? I don't think the efficiency you're asking for is simply possible at the moment.
inter2010
28 (0.04/day)
I'm sorry, maybe I expressed myself badly.
I don't want a supersonic jet that consumes 50w.
I was referring to the same performance, I prefer the one that consumes less and produces less heat. I hope I was clearer.
the 4090 is beyond all logic, I'm oriented towards a 4080 or an xtx. in raster they go beyond 100 fps and in rt the 4080 is better, even if for now I'm not particularly interested in RT, since I don't have such a sensitive eye to see a ghostly shadow on a wall.
I also ask another thing, all of you have talked about air conditioning, what would be the temperature range of the room to make a PC work in optimal conditions and make it last even longer over time?
45 (0.03/day)
System Name Gaming
Motherboard MSI X570 Unify
Cooling TR Phantom Spirit 120 EVO w/ two NF-A12x25 chromax.black, and TG Kryonaut Extreme
Memory 2x32GB G.Skill Trident Z Neo DDR4 3600 (CL 16, F4-3600C16D-64GTZN)
Video Card(s) PowerColor Red Devil RX 6950 XT
Storage 2x2TB SK hynix Platinum P41
Display(s) Razer Raptor 27" (165Hz, 2560x1440)
Case GAMDIAS NESO P1 B w/ 4x Silent Wings Pro 140mm, and 6x Grand Tornado 120mm
Audio Device(s) Klipsch ProMedia 2.1 THX, Audio-Technica ATH-AD700X, Razer BlackShark V2, Sound BlasterX G6
Power Supply FSP Hydro Ti PRO 1000W (HTI-1000M-GEN5)
Mouse Zowie EC3-C
Keyboard 8BitDo Retro Mechanical Keyboard, and Retro 18 Mechanical Numpad. C64 Edition.
836 (0.46/day)
If you don't want RT it's 4070 Ti or 7900xt per this chart.
You might have other considerations, if you're used to one brand or the other, multi monitor etc.
They're both riduc expensive of course.
2,395 (1.52/day)
Bulgaria
Hmm, +3-4 years and 4K with sustainable gaming with not les than 100 FPS. Include next generation AAA titles from 2026-2027? Mission impossible with card below rtx 4090, 4090 Ti, or even future Titan ADA with 48GB VRAM
998 (0.65/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 24 GB @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
thank u !!
3070ti, 3080 for budget. I don't know much about team red, so won't advise one for these reso.
2,937 (2.07/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
998 (0.65/day)
Memory 24 GB @ 3200
Mouse Logitech G604
6650 and 3060 ti are 2K cards lmfao... but yeah, 3060ti could 4K in old games lol
inter2010
28 (0.04/day)
Honestly it seems like a flip of the coin decision.
I'd get the RTX 4080 if I had the money. Although the RTX 4080 has less VRAM than the 7900 XTX. AIB's seem to have decent coolers for both (YMMV).
AMD acknowledged some of the Made by AMD (MBA) 7900 XTX cards have a cooler defect. So don't get that unless you're going to put an aftermarket cooler on it.
https://www.tomshardware.com/news/amd-vows-to-replace-overheating-radeon-rx-7900-xtx-boards
both have their strong points, the 4080 is better with RT on, the xtx is better in raster. consumption and temperatures are almost in the same situation. the xtx, however, costs less. I've heard of the problem, if I take it I'll take one custom.
I had 2 gpu, the 280 gigabyte and the 2080 ti msi x trio.both probably dead due to the temperature of the room.but now i will solve this problem with the next one.amd intrigues me,the 70 series is not bad,too bad the price is as usual high
I know that the mission is almost impossible, but with the 2080 ti (card of over 4 years ago) I played mw2 in 4k all ultra with rt off at about 85/95 fps. I was on 100 fps when I played on the 3440x1440 monitor. in theory I could do them even with the latest generation cards.
4090 out of economic reach
bug
13,844 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Unfortunately that's not how it works. If the average is 100fps, half of the games (more, realistically speaking) will NOT be getting steady 100fps. Ironically, a 4070Ti would do just fine, thanks to DLSS3.
42,635 (6.68/day)
6800XT, 6900XT, 7900XT and call it a day.
5,689 (1.10/day)
System Name Space Station
Processor Intel 13700K
Motherboard ASRock Z790 PG Riptide
Memory Corsair Vengeance 6400 2x16GB @ CL34
Video Card(s) PNY RTX 4080
Storage SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB
Display(s) LG C3 OLED 42"
Case Corsair 7000D Airflow
Audio Device(s) Yamaha RX-V371
Power Supply SeaSonic Vertex 1200w Gold
Mouse Razer Basilisk V3
Keyboard Bloody B840-LK
Software Windows 11 Pro 23H2
thank u !!
Well, if you want to look forward and consider trends, vs just averaging 100 FPS and ending up with a LOT of games not managing that going forward, the 4090 is currently your best option.
dgianstefani
TPU Proofreader
5,095 (2.00/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper V3 Pro 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape, Razer Atlas
Benchmark Scores Legendary
4080 is the most efficient choice for you.
We have several reviews of different models.
129 (0.03/day)
Surprised no one objected to this. The 4070 ti despite its 192-bit bus demolishes not only the 6800, but the 6800xt in the chart. Cannot compare older gen bit-bus to newer cards with more advanced architectures and specs. Also has DDR6x a opposed to DDR6 which compensates in bandwidth for the slightly smaller bit-bus. Cannot see any evidence that a 6800xt would outperform the 4070ti in a single scenario at 4k due to its bit-bus.. It doesnt necessarily scale best at 4k vs the newest cards, but certainly leaves all older gen cards in the dust.
1,005 (0.69/day)
Memory 32 GB
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
there is nothing to object, for all intents and purposes 4070 Ti is a 3090 Ti on a 192 bit bus with 48 MB cache that has to saturate the same 40 Tflops, therefore in 4K it just craps up.
As for the other camp, 6800 is a better deal overall compared to the weaker version. the regular 6700 Xt goes for 359, but I wouldn't use it in 4K.
311 (0.22/day)
System Name Office,Home and Game PC
Processor Intel Core i5 12600k Up to 4.9 GHz
Motherboard Z690 Gaming X Gigabyte DDR4 Version
Cooling Fuma 2 Air Cooler
Memory 32GB DDR4 2x16 3600 MHz Patriot Viper Steel RAM
Video Card(s) NVIDIA GeForce GTX 1080 and RTX 3070
Storage 512 GB M2 PCI Ex 3.0 NVMe SX6000 Pro, 1TB NV2 Kingston M2 PCI Ex 4.0 and 4TB WD Blue SATA 3.0 HDD
Display(s) 27 inç 75 Hz LG
Case Cooler Master MB511
Audio Device(s) Creative 2+1
Power Supply 750W 80+ Bronze PSU High Power Element
Mouse Logitech Wireless
Keyboard Microsoft
VR HMD N/A
Software Windows 10-11
the most ideal would be the RTX 3080 Ti-3090 or 4080 AMD RX 6900 XT or 7900 XT.
8,340 (3.91/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
If you want 100fps in all of today's games at 4K ultra settings, nothing exists that will do that yet. The 4090 gets close but there are a handful of games like BL3, CP2077, Dying Light 2, Warhammer III which even a 4090 cannot achieve 100fps averages in.
You were right that now is a bad time to buy a new GPU - we're right in the middle of a generational transition. The midrange cards that usually shift the price/performance curve for the whole market aren't out yet, and the halo cards are shockingly expensive still, coming with early-adopter tax.
If I were in your situation I'd pick up a used 3070 on ebay as a stopgap and reassess the new GPU situation in 6-12 months. You're unlikely to lose much money on a 3070; If you buy one now for under $400 you should be able to get the majority of your money back by selling it on again in 6+ months.
inter2010
28 (0.04/day)
a question that I hope is not a stupid question, my monitors only have g-sync, could I still get a radeon?
8,340 (3.91/day)
Case Veddha T2
Mouse MX Anywhere 2
If they are old-school dedicated G-Sync modules, then Freesync won't work, no. Freesync (and new G-Sync) use the proper VESA VRR standard. Original G-Sync was some kind of bastard FPGCA module that worked only with Nvidia cards.
What exact model of monitors do you have?
