GPU usage 99% idle
AETM132
19 (6.33/day)
Good afternoon, I have a RX 6800 xt from GIGABYTE that seems to be in good condition but I have a problem. At idle it remains at 99%. I already did a clean installation of Windows and the problem continues.
7,094 (3.07/day)
California
System Name His & Hers
Storage lots of SSD.
Does it perform normally when gaming?
AETM132
19 (6.33/day)
He seems fine but I'm worried about this behavior. In the task manager, between 1 - 5% is out of use in idle but the minimum consumption is reflected high in rest, including the use in other applications such as adrenalin or even in the MSI afterburner @oxrufiioxo
Cheeseball
Not a Potato
2,073 (0.35/day)
Pittsburgh, PA
System Name Titan
Storage Crucial T500 2TB x 3
Power Supply Corsair SF1000
VR HMD Meta Quest 3 512GB
What monitor(s), resolution and refresh rate are you running on this?
1,604 (0.74/day)
London, UK
Software ❶ Win 11 ❷ 10 ❸ 10
On your fresh windows install, if this problem occurred after installing AMDs radeon software, go into settings and disable 'desktop recording' and see if that solves the issue. If not, in the same settings page disable 'instant replay' and 'in game replay'. See if that helps.
42,954 (6.71/day)
Anything related to xb crap?
AETM132
19 (6.33/day)
i tried but it doesnt work
Cheeseball
Not a Potato
2,073 (0.35/day)
Pittsburgh, PA
System Name Titan
LG 144 hz 24GN60R connected with a displayport cable, i had a 6700 xt before and it never happened this problem
Could you try turning off the VRR/FreeSync/Adaptive-Sync function on the monitor, check the usage and report back to us here.
Also can you share your settings from your Adrenalin app:
483 (0.35/day)
Processor AMD 7600x
Motherboard Asrock x670e Steel Legend
Cooling Silver Arrow Extreme IBe Rev B with 2x 120 Gentle Typhoons
Memory 4x16Gb Patriot Viper Non RGB @ 6000 30-36-36-36-40
Video Card(s) XFX 6950XT MERC 319
Storage 2x Crucial P5 Plus 1Tb NVME
Display(s) 3x Dell Ultrasharp U2414h
Case Coolermaster Stacker 832
Power Supply Thermaltake Toughpower PF3 850 watt
Mouse Logitech G502 (OG)
Keyboard Logitech G512
Anything in task manager showing GPU load?
42,954 (6.71/day)
What other things have you done so far?
Cheeseball
Not a Potato
2,073 (0.35/day)
Pittsburgh, PA
System Name Titan
937 (0.62/day)
System Name 1. Glasshouse 2. Odin OneEye
Processor 1. Ryzen 9 5900X (manual PBO) 2. Ryzen 9 7900X
Motherboard 1. MSI x570 Tomahawk wifi 2. Gigabyte Aorus Extreme 670E
Cooling 1. Noctua NH D15 Chromax Black 2. Custom Loop 3x360mm (60mm) rads & T30 fans/Aquacomputer NEXT w/b
Memory 1. G Skill Neo 16GBx4 (3600MHz 16/16/16/36) 2. Kingston Fury 16GBx2 DDR5 CL36
Video Card(s) 1. Asus Strix Vega 64 2. Powercolor Liquid Devil 7900XTX
Storage 1. Corsair Force MP600 (1TB) & Sabrent Rocket 4 (2TB) 2. Kingston 3000 (1TB) and Hynix p41 (2TB)
Display(s) 1. Samsung U28E590 10bit 4K@60Hz 2. LG C2 42 inch 10bit 4K@120Hz
Case 1. Corsair Crystal 570X White 2. Cooler Master HAF 700 EVO
Audio Device(s) 1. Creative Speakers 2. Built in LG monitor speakers
Power Supply 1. Corsair RM850x 2. Superflower Titanium 1600W
Mouse 1. Microsoft IntelliMouse Pro (grey) 2. Microsoft IntelliMouse Pro (black)
Keyboard Leopold High End Mechanical
DDU remove the driver and do a minimal reinstall.
42,954 (6.71/day)
Cheeseball
Not a Potato
2,073 (0.35/day)
Pittsburgh, PA
System Name Titan
I'm not a fan of webbrowsers using the gpu, makes it seem like trojan miners,
LOL yeah Microsoft Edge is annoying in this regard. But to its slight defense I do have 42+ tabs open with around 15 or so recently active.
The game is minimized. but here in the task manager it is always low on idle of course, which is the strange thing
So it only shows high GPU usage within GPU-Z and the Adrenalin app? Your first GPU-Z screenshot in the first post shows the GPU core itself is doing some work but not loading the VRAM at all (although maybe its only loading around 1 GB of data).
AETM132
19 (6.33/day)
Only HWMonitor, GPU-Z and Adrenalin shows the 99% usage and high core clock on idle. I don't know if im running a good vbios. this is the vbios and a picture of hwmonitor.
  • Navi 21.rom
AETM132
19 (6.33/day)
I try to hibernate the pc for 30 seconds, then i turned on and the usage turns down to 0 - 3% with the power consumption at 14w (before was more than 40w), I dont know that is the problem lol
393 (2.79/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
Just a hunch to try. Disable ASPM for pci-e in bios. worth a try. I've seen it cause all kinds of weird stuff.
Won't hurt anything, and you can always turn it back on if you desire.
AETM132
19 (6.33/day)
I just turn on the resize BAR on the BIOS and that seems to fix the problem. I Will test for a few days, thank you guys
Nvm, the problem continues
3,641 (1.86/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3667MT/s 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
Tried to use HWiNFO64 for more information on the GPU?
42,954 (6.71/day)
Pull the card and reseat it firmly and squared in the slot, make sure the motherboard is exactly parallel on the back edge of the case , any improperly aligned component can be making weak contact.
Have you even updated the motherboard bios?
AETM132
19 (6.33/day)
Yes, I already checked that it was well connected. The motherboard has the updated BIOS
