GPU-Z won't open after installation.
59 (0.06/day)
Processor AMD Ryzen 9 7900X3D
Motherboard ASUS ROG Crosshair X670E Hero
Cooling ASUS ROG Strix LC III 360
Memory G.Skill 48GB(2x24) TZ5 Neo RGB EXPO 6400mhz CL32
Video Card(s) ASUS TUF RTX4070TI SUPER
Storage Adata XPG SX8200 Pro 2X2TB, Adata XPG SX8100 3X2TB,
Display(s) Dell 34" Curved Gaming Monitor S3422DWG
Case Corsair 5000X
Power Supply Corsair RM1000x SHIFT 80 PLUS Gold
Mouse Asus ROG Gladius II Core
Keyboard Asus ROG Strix Scope
Hello everyone. I am having an interesting problem with GPU-Z.
I download and install GPU-Z. After the first installation, it opens without any problems. However, after turning the computer off and on or after trying to open it after a while, it does not open at all.
I could not find the reason for this problem. I am using Windows 11 Pro version.
My system components are as in my signature.
W1zzard
Administrator
27,970 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Do you see any kind of error message? What if you run download and run the portable version?
59 (0.06/day)
Case Corsair 5000X
I don't get any error messages.
Let me put it this way, I used to use a system with a 5900x processor and an x570hero motherboard. Now I have a new system with a 7900x3d and an x670e hero motherboard. I have been experiencing this problem since I switched to this new system.
1. I install GPU-Z. After installing it, I open it and it works.
2. Then I close the system.
3. I open the system again and click to open GPUZ. There is no response.
It doesn't open.
The same problem occurs in the portable version. It does not open after the first opening.
W1zzard
Administrator
27,970 (3.71/day)
Memory 48 GB
If you check in Task Manager -> Details, do you see a GPU-Z process even after closing it?
3,126 (4.67/day)
Russian Wild West
System Name DLSS / YOLO-PC / FULLRETARD
Processor i5-12400F / 10600KF / C2D E6750
Motherboard Gigabyte B760M DS3H / Z490 Vision D / P5GC-MX/1333
Cooling Laminar RM1 / Gammaxx 400 / 775 Box cooler
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333 / 3 GB DDR2-700
Video Card(s) RX 6700 XT / R9 380 2 GB / 9600 GT
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 / 500 GB HDD
Display(s) Compit HA2704 / MSi G2712 / non-existent
Case Matrexx 55 / Junkyard special / non-existent
Power Supply Thermaltake 1000 W / Corsair CX650M / non-existent
Software Windows 11 / 10 / 8
I'm kinda green in this regard so I might be way off but I see you use a lot of ASUS ROG hardware. Do you also have their software running in background? What if you remove everything ASUS (software, not hardware) and try again?
59 (0.06/day)
Case Corsair 5000X
Windows Firewall perceives Gpuz as a threat and blocks the application.
I downloaded different versions of gpuz and they did the same.
Even though there is no virus on my computer, it perceives the gpuz application that I downloaded and installed as a threat.
I don't use any rog apps.
Despite that, I still have this problem.
42,635 (6.68/day)
So put an exception in the firewall...
98 (0.31/day)
Canucksland
System Name Main / HTPC / Server
Processor i5 14600K / Ryzen 5 2400G / i7 7700K
Motherboard Z790 PRO RS / B450M Mortar / Z270 IX Code
Cooling AS500 PLUS WH / Wraith Stealth / NH-D15
Memory 32GB 6000 C30 / 8GB 2666 C16 / 32GB 3000 C15
Video Card(s) GTX 780 (temporary) / iGPU / iGPU
Storage (OS) 1600X 118GB / V200 120GB / 850 EVO 250GB
Display(s) Predator XB271HU / KDL-55W950B / VH238H
Case Eclipse P400S / LC13-BU / Define R5
Audio Device(s) Xonar U7 (HD 598) / Xfi Titanium (Azur 851A)
Power Supply Prime Titanium 750W / M12II EVO 620W / AXi 860W
Also easy to verify you’ll have a yellow triangle icon with an exclamation mark within if you go into Security - Windows Defender or if you launch the Windows Security app and look at the Firewall tab.
59 (0.06/day)
Case Corsair 5000X
Do you have a log entry or similar?
It gives the warning Virus:Win32/Jeefo.A
and blocks GPU-Z and does not open again after installation.
Since I use Turkish, the screenshot is in Turkish but the virus it found is exactly what I shared.
W1zzard
Administrator
27,970 (3.71/day)
Memory 48 GB
99 (0.33/day)
So, it's a safer bet to download GPU-Z here at TPU. There is a related thread on this already:
Good Luck!
59 (0.06/day)
Case Corsair 5000X
Good Luck!
Hello. I have this problem even though I downloaded it from Techpowerup. And I couldn't solve it.
Can you right click the exe, properties, digital signature, details, check if it's OK?
I downloaded and installed it again from Techpowerup US-3 Server.
In the Digital Signatures section, it shows "This Digital Signature is OK".
I had previously downloaded it from Techpowerup DE and Techpowerup NL servers.
I am getting a virus warning in the files I download from these servers.
99 (0.33/day)
IMHO - given that it checks out - perhaps at this point you should just whitelist the application. I have had to do this in the past, just because bitdefender was a paranoid AV suite (dropped it because of all the false negatives positives).
Also - make sure you have a backup (I always have multiple backups). That way if you get a virus, you can return you system to a previous state.
W1zzard
Administrator
27,970 (3.71/day)
Memory 48 GB
bug
13,844 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
IMHO - given that it checks out - perhaps at this point you should just whitelist the application. I have had to do this in the past, just because bitdefender was a paranoid AV suite (dropped it because of all the false negatives).
False positives ;)
False negative is when it passes the verification, but it's actually infected.
59 (0.06/day)
Case Corsair 5000X
Submit as false positive here, Microsoft is usually pretty quick fixing this
There doesn't seem to be a problem at the moment. It works normally. But if the virus warning comes again, I will notify Microsoft as you said.
I always have a second backup.
I think some versions of gpuz on the internet have a trojan. It doesn't seem to be a problem at the moment.
5,847 (0.81/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
