Guide to running multiple GPU work units
[Ion]
WCG Team Assistant
13,391 (2.35/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
Need help.. installed newest version of boinc, used the utility for multiple gpu units, checked the xml file and it looks the same as op, but I can't get any hcc wus at all. Tried resetting multiple times, no good. This is on a fresh install of windows with a fresh install of 7.0.44. The manager also reports an error of: app hcc1 not found in app_config.xml. I'm confused?
Try removing app_config.xml, letting BOINC download work and the executables, and then adding it back.
johnspack
Here For Good!
6,069 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
Well, did that, and after resetting a few more times it finally kicked in. Back to crunching hcc gpu wus! My poor cruncher only has 2gbs ram in single channel as I had to lend 2 sticks to a friend, but seems to be doing okay anyways. My mother comes back from the cancer clinic in a week, seems most of her cancer is gone now. Got to find an answer before it comes back again!
the54thvoid
Super Intoxicated Moderator
13,539 (2.42/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
...Got to find an answer before it comes back again!
I've not been active much but I'm back crunching here and there so we'll get that answer soon!
[Ion]
WCG Team Assistant
13,391 (2.35/day)
2GB single channel is fine--I'm running my i7-920 like that :toast:
I wish her the best! :)
Norton
Moderator - Returning from the Darkness
14,104 (2.90/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
manofthem
WCG-TPU Team All-Star!
10,960 (2.10/day)
Florida
Processor 3900X @ 4.0
Cooling DeepCool Castle 360EX
Storage Sabrent Rocket Q 1TB
Display(s) LG 34UC88
Case Thermaltake P3
Mouse Logitech G900
Norton
14,104 (2.90/day)
Northeast USA
Mouse G300s
VR HMD N/A
Great, the first time I shut down since these HCC WUs and this happens :banghead: :banghead:
The major shutdown isn't due to start until Tuesday AFAIK so you should have plenty of time to fill up your buffer when you get back on Sunday.
FYI- I opened up my buffer and the wu's started flowing in like crazy!!! I must have added 1000 of them to each rig over the last 15 minutes :pimp:
stinger608
11,250 (1.88/day)
Wyoming
System Name 2023 Ryzenfall
Processor AMD Ryzen 5800X
Cooling SilverStone AH240 AIO
Case Corsair Air 540
Audio Device(s) On board
How do you open up the buffer?
Also, I am currently running the Catalyst 13.1 drivers. WU's are running about the same, 8 to 10 minutes each for 8 at a time, however what I have noticed is my video card is running 3 to 4C cooler than it was!!! :rockout:
Norton
14,104 (2.90/day)
Northeast USA
Mouse G300s
VR HMD N/A
Just increase the Minimum and Maximum in the network settings tab:
manofthem
10,960 (2.10/day)
Florida
Case Thermaltake P3
Mouse Logitech G900
That's what I'm talking about, thanks. Looks like Sunday I'll start stocking up on WUs :toast:
stinger608
11,250 (1.88/day)
Wyoming
4,541 (0.81/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
johnspack
Here For Good!
6,069 (0.95/day)
Nelson B.C. Canada
Keyboard Ducky
Just to be certain, I also set the buffer in Workunit Cache Settings to 4 days in the device manager. Not sure if it does anything or not.
4,541 (0.81/day)
Denmark
Left from previous versions. Minimum buffer is the important one according to SekeRob (take a look at WCG forum for more information).
Edit: Didn't get my sig right. Any suggestions to do it correct?
751 (0.16/day)
System Name My PC
Processor i7 4790k @4.4ghz
Motherboard Gigabyte z97m-d3h
Cooling Corsair H105
Memory 4x4GB Corsair Dominator Platinum 2133-9-11-11-31-1T
Video Card(s) GTX970 Stric oc
Storage Samsung 840Pro 512GB
Display(s) Asus ROG SWIFT
Case Lian Li 359
Audio Device(s) Denon DA-300USB / Denon AH-D5000
Power Supply Corsair AX860
Mouse Roccat Kone Pure Optical
Keyboard Corsair K70
Software Win10 64-bit home
It is the first time I hear that something like this exist. I did some fast reading on wikipedia.
So is this all about giving away your computer's GPU power (when idle) to the benefit of scientists doing projects around the world (and that cant afford to buy a computer themselves) ? Or am I missing something?
Norton
14,104 (2.90/day)
Northeast USA
Mouse G300s
VR HMD N/A
That's basically what we do- distributed/grid computing for research on humitarian issues (clean water, clean energy, cancer research, etc...). The gpu project is new but the results have been tremendous, especially for Radeon 7xxx cards. All of the other projects currently run on cpu power.
Follow this thread if you're interested in joining the Team:
http://www.techpowerup.com/forums/showthread.php?t=93395
Thanks for showing interest in this! :toast:
751 (0.16/day)
System Name My PC
Case Lian Li 359
So are you (or anyone in the forum here) part of the research team/teams?
I'll gladly give it a go with my 7970 in 2-3 weeks when im done with the heavy university workload i got atm. Hopefully I will have my system available for this program from now until summer.
702 (0.14/day)
Where the hand of man has never set foot
Processor AMD Ryzen 5 3600X
Motherboard ASUS TUF GAMING X570-PLUS
Cooling Noctua NH-D15 SE-AM4
Memory 2x8GB G.SKILL Ripjaws V DDR4-3200MHz CL16 1.35V
Video Card(s) MSI Radeon RX 6600 XT Gaming X 8G
Storage Crucial MX100 512GB + Samsung 870 EVO 2TB
Display(s) MSI Optix MAG24C
Power Supply Seasonic FOCUS GX-550
Mouse Razer Viper Ultimate
Keyboard Corsair K60
4,541 (0.81/day)
Denmark
You got it right including the part of not having the money to buy their own computer. The computer power that WGC (and other projects) get from donors amounts to millions of $/EUR. We are talking about several Pflop/s aka a top 5 super computer. Most of the people that contributes give their free CPU cycles (marginal cost in electricity) and then there are some that invest a little or in some cases a lot in building dedicated PCs to help accelerate the cure of among other cancer.
I was new to this 3 years ago as well but the decision to join wasn't hard. You can contribute with as little as you want. This is a good starting point http://www.techpowerup.com/forums/showthread.php?t=106593
751 (0.16/day)
System Name My PC
Case Lian Li 359
Oh right, so it is about very big projects that are split in very small parts which are then sent to many individual PCs for computing. Very interesting.
HammerON
The Watchful Moderator
8,402 (1.43/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
4,541 (0.81/day)
Denmark
HammerON
8,402 (1.43/day)
Up North
System Name Aki
Software Win 11 Pro
Yes I run it on one rig (my 2x7700/i970). I installed it yesterday and so far no problems but it is a dedicated rig......
I don't think those drivers liked my oc of 1100 on the cards. That is the only thing I can think of....
751 (0.16/day)
System Name My PC
Case Lian Li 359
4,541 (0.81/day)
Denmark
1100 MHz should be a safe OC. I ran my at 1102 until 10 min ago with no other errors then the sync thing. Now it is 1125 (one Asus and one XFX) at auto fan. The Asus is still at 10% and 50 C. I just love that HS.
